| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Size & spec of TRD wheels?
Sorry if this has already been asked, but does anybody know the width and offsets on these 18" TRD wheels? I recall they were just 7.5 inches wide and costs close to $1k each. I want to upgrade over the stock wheels and figured TRD should be the default reference point for wheel size and tire specs. Does anybody know if they're just re-badged versions of some other type of wheels?
#2 |
Drift Specialist
Drives: 180SX,GT86
i believe they where 18x7.5 +35 on 225/40-18
#3 |
Boosted Noob
That sounds like what I remember seeing too. Seems like a lot of people who are taking tracking serious are going with 17x9 wheels and TRD decided on 18x7.5. Just seems kinda funny so many people are choosing to go with 18x9+in wheels deviating from years of Toyobaru R&D and people who track the car. Is it primarily people just want that wide tire stance look from behind? /rhetoric
#4 |
FT86 News Addict
Drives: Toyota FJ
How about similar wheels for less? Love the 10 spoke, evenly spaced, black wheel look on this car.
#5 |
Boosted Noob
The black rims look sweet but I feel the bright red brakes also add quite a bit to the overall TRD look.
#6 | |
Drives: Some rust bucket
1. 18" to fit a big brake kit. Some 17" will fit a BBK, but it will depend on the design of the wheel. It makes more financial sense to produce a wheel that will fit all aftermarket big brake kits than only certain ones with a 17" wheel. For example, if you know you want to run 215 wide tires, then you can get rims that are 7"-8" wide. The wider the wheel, the stiffer the sidewall, but that will also increase the weight of the wheel/tire package. 2. 7.5" wide to keep weight and cost down. A 18x9 cast made wheel may weigh more than the OEM wheels. In terms of performance upgrades, you want to reduce the weight, not increase it. There really isn't a "perfect" wheel size when you take into account cost. If everything else is equal, you want lighter and wider wheels to accommodate for wider tires. I think the tire size should dictate the wheel size IMO. For example, if you want to run 215 wide tires, then you can choose between 7"-8" wide wheels. Fitting wider wheels will increase tire sidewall stiffness but increase weight. However, in general, you can't go wrong with TRD recommended sized wheels. |
| What socket size and what torque amount for stock alloy wheels? | Takeshi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-01-2012 10:25 PM |
| Square Size Tires and Stagered Wheels | BigJyoungblood | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 10-23-2012 07:44 AM |
| FS [WA] 17" GTS wheels with Tyres x 4 - get a full size spare | Z86 | Australia Classifieds | 3 | 10-17-2012 04:24 AM |
| What size wheels do you plan on running? | poormans_LFA | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 51 | 04-28-2012 05:30 PM |
