Old 01-09-2013, 07:32 AM   #15
Kodename47
Kodename47's Avatar
Drives: UK GT86
The edges where they connect to the TB and filter box do you mean? They won't matter at all as they are fitted over the existing connections and therefore aren't near the airflow inside.
I can't imagine these will really suffer any heat issues either as silicon is a brilliant insulator.
I wanted to keep the tube as I'm not going to get an exhaust (at least not yet) so quite like some noise in the cabin. I don't find it obtrusive and it's not a daily drive anyway.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-09-2013, 08:48 AM   #16
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Did you have trouble putting the Perrin filter in? I just put my filter in last night but look a good bit of time for the box to close up. Also, can you see any part of the filter once the box is closed? I am asking because I can see a tiny bit of mine. The air box took a while to close because the edges of the Perrin filter are thicker than stock filters. Lemme know your thoughts. Thanks.
ap5512 is offline   Reply With Quote
Old 01-09-2013, 09:25 AM   #17
gmookher
makes for a great seal, 2-3 mm should be visible the whole way around
The Following User Says Thank You to gmookher For This Useful Post:
ap5512 (01-09-2013)
Old 01-09-2013, 10:06 AM   #18
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Originally Posted by bigjake View Post
perrins own silicone tube is much better
Interested to see the flow bench testing you had to perform or some sort of direct dyno testing you did on the two intakes back to back... or really any legitimate proof to back your claim short of your own non-professional subjective opinion.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 01-10-2013, 03:40 AM   #19
bigjake
Drives: 2013 Scion FR-S, Firestorm
i read it on the internet deucethemoose, and as we all now, if its on the internet it has to be true.
bigjake is offline   Reply With Quote
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 08:07 AM
How do you install the mud guards? Moshpit37 Scion FR-S / Toyota 86 GT86 General Forum 11 07-27-2012 11:13 PM
oem headunit install encity5 Electronics | Audio | NAV | Infotainment 4 07-22-2012 10:27 PM
How to install mudguards? FRiSson Cosmetic Modification (Interior/Exterior/Lighting) 2 07-13-2012 07:34 PM
Spoiler Install CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 1 07-07-2012 10:43 AM
