| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
| View Poll Results: What Brand of Oil is in your BRZ/FRS? | |||
| Amsoil |
124 | 12.00% |
| Mobil |
303 | 29.33% |
| Penzoil |
59 | 5.71% |
| Valvoline |
28 | 2.71% |
| Motul |
151 | 14.62% |
| Castrol |
89 | 8.62% |
| Redline |
27 | 2.61% |
| Dealer Brand |
235 | 22.75% |
| Store Brand |
17 | 1.65% |
| Voters: 1033. You may not vote on this poll | |||
#71 | |
Drives: '13 Ultramarine
Just sayin'.
#72 |
Drives: Whiteout FR-S
I ran the Motul 8100 on the first change an 300v on the second, next change will probably be 2 liters of 300v and the rest 8100.
#73 |
Drives: White MT FR-S
Not to flame here - oil is a hotly contested subject but I made a couple of charts below with some of the popular and recommended oils from this thread. The first is sorted by Viscosity Index with the highest number being best. The second chart is sorted by KV @ 40*C which is cold starting viscosity. All are within a point at 100*C operating temp. Eneos Sustina clearly is tops in both charts but at a premium price. Idemitsu SN (Subaru oil?) is relatively inexpensive and has very good numbers. I couldn't get any numbers for the Toyota SN except Viscosity Index and the one UOA (used oil analysis) I saw on BITOG (bobistheoilguy.com) showed a marked reduction in Moly from the SM formula. The bottom five share similar numbers. So here is my question to some of the more knowledgeable forum members:
If we are looking at oils that have similar properties (say the bottom 5) what criteria should we be using to distinguish between them. Do we look at the base oil, TBN, Moly and other additives, UOA's on forums? How are you choosing your oil? Motul 8100 is recommended here but based on the chart Amsoil looks better. If there is a list of criteria after VI what would the order of that list be? Currently I'm running Toyota SN because that's what the dealer installed and because I hadn't made up my mind until today what to switch to. I will probably run a UOA for sh*ts and giggles on the ToyoSN just to see. I'm not trying to start a sh*t slinging war just genuinely interested in how people came to their decision on oil.... ![]() Last edited by Amadeus; 12-20-2012 at 08:24 PM. Reason: updated chart with Toyota SN info from BITOG VOA |
| The Following User Says Thank You to Amadeus For This Useful Post: | Sportsguy83 (12-19-2012) |
#74 |
I need to send off the 300v in mine for testing on the next change, i asked someone who had experience with both and he said the Sustina was really good, just not on the level of 300v but i don't have any facts to back it up.
#75 |
I Love custom Turbo kits
Drives: Limited BRZ
Every single time I make my mind on an oil, something new comes up and throws it out the window... Though, this @Amadeus chart looks good. Thanks for sharing!
#76 | |
Drives: 2004 Subaru Forester 2.5XT
http://www.pqiamerica.com/coldcrank.htm If you want to see the actual viscosity at 0C/32F, plug the numbers into a viscosity graph/calculator. http://www.widman.biz/English/Calculators/Graph.html I wouldn't pick any one number when it comes to choosing an oil. It depends on your particular application and even then it may not matter as much. I think a lot of people pick their favorite brand since there isn't much data from these cars. Most of the uoa's are still during the break-in period. -Dennis |
#77 |
Cool links - especially the Widman one - thanks.
#78 |
Drives: Argento FR-S
Just ordered 6 quarts of Eneos Sustina 0w20? $77.92 with shipping
Going to hit 1000 miles sometime this week so I'll change the oil when it and the fumoto valve get here. Also just ordered the Motul 300 75w90 gear oil. I just figure if I'm going to lift the damn car, might as well change out everything. Shaggy |
#79 |
Drives: 2013 Scion FR-S Raven
Where did you purchase from?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#80 |
Captain Cocoa
Drives: CBS BRZ MT
Eneos due to it being the choice of initial d! I'm serious go back and watch the live action and count how many times you see eneos plastered somewhere in the gas station.
| The Following User Says Thank You to SubaSteve For This Useful Post: | Panda Mao (05-20-2014) |
#81 | |
When In Doubt...
Drives: Slowww
So I switched over to Eneos (non sustina) 0W20 a few days ago and I'm kind of worried. I have about 200 miles on my current tank, I put in the Eneos 100 miles ago. Before the Eneos I was on Amsoil SS. My fuel economy said 26.7mpg (over those ~100 miles) I reset that when I changed the oil and now I'm sitting at 29.5mpg...Same driving conditions and over ~100 miles. On cold starts the fuel economy doesn't seem to go down anywhere near as much on the Eneos. Why was the Amsoil so (dare I say) bad? I only had it in for 4k miles. My fuel economy has been declining since I first went to Amsoil but I chalked that up to my winter tires + winter gas.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#82 |
I may switch from the 0w-30 Motul x-lite to the 0w-20 Eneos Sustina next change.
#83 |
Drives: Scion FRS Ht Lva(AT)
Just add to the debate, VI is not really relevant if you don't understand the permanent shear stability or the HTHS of the oil.
| The Following 2 Users Say Thank You to smbrm For This Useful Post: | Amillionoh7 (10-03-2016), rice_classic (01-08-2013) |
#84 | |
Drives: Nevermorange FRS
Also note that only a one point difference at 40C makes a bigger difference in the VI number than a point difference at 100C. That chart above sort of illustrates this as the Sustina has both the lowest 40C and 100C KV. If my engine were (theoretically) designed to run at 100C between 8-9 cSt then the Sustina would be a poor option. I personally take VI cum grano salis and think it's not the best rating to base judgement on. What I find great about these long, entertaining and often educational oil analysis debates is just when we're thinking we've got our fingers on the button the ALMS teams go run 24 hours endurance races on engines that make several hundred horse power on straight 0 weight oil. I love when auto racing does that. Is anyone here obsessing this much about he quality of the food that goes in their mouths as we do about oil? I bet if we all focused on that a little more we, instead of our engines, would all perform better and last a little longer. just sayin'
PRO86 | WTCC | STL
| wax a brand new car? | FRkane | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 07-10-2012 12:26 AM |
