Old 01-03-2013, 05:20 PM   #15
gmookher
isnt there still throttle cut out?
Old 01-03-2013, 05:22 PM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by ROCKETS86 View Post
just pull out the abs fuse its dead easy
Assuming you want to disable ABS. This process leaves ABS functional but allows proper trail braking on the track.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-03-2013, 05:23 PM   #17
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Are you talking about the rev limiter or TCS throttle cut?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-04-2013, 01:48 PM   #18
Captain Insano
This method reads like a video game cheat code...
Captain Insano is offline   Reply With Quote
Old 01-04-2013, 01:50 PM   #19
mashal
DADA
mashal's Avatar
Drives: 2013
Side brake ? You mean e-brake/hand brake ?
mashal is offline   Reply With Quote
Old 01-04-2013, 11:24 PM   #20
g0lden
Drives: 2013 Scion FR-S Argento
Originally Posted by I<3Twisties View Post
Ok, so that's up up down down left right left right b a start?
I think it's A B Start :-)
g0lden is offline   Reply With Quote
Old 01-04-2013, 11:38 PM   #21
chris's fr-s
@theexquisite86
chris's fr-s's Avatar
Drives: 2013 Firestorm FR-S
Ok so after all that code wouldnt it to be easier to just run a toggle of the fuse to turn on and off ?
chris's fr-s is offline   Reply With Quote
Old 01-04-2013, 11:47 PM   #22
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I'm wondering why some people have to do this. I hold the traction button for a few seconds and everything is off completely...did a lot of drifts and donuts in the snow and there's no computer correction to be felt at all.
Rayme is offline   Reply With Quote
Old 01-05-2013, 12:16 AM   #23
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
EBD prevents proper trail braking on track. That's the only reason to do this as far as I can tell. I never had a problem with autocross and don't drift. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Rayme (01-05-2013)
Old 01-05-2013, 10:31 PM   #24
nix
nix's Avatar
Drives: AVO BRZ
This was posted in September by @086A who found it in the repair manual.
http://www.ft86club.com/forums/showt...186#post464598
nix is offline   Reply With Quote
The Following User Says Thank You to nix For This Useful Post:
Sigh-on-Rice (01-06-2013)
Old 01-06-2013, 05:59 AM   #25
gonzo
Drives: frs
"panic brake" functions
What is this? I can guess but do you know exactly what it does?
gonzo is offline   Reply With Quote
Old 01-06-2013, 08:49 AM   #26
iHeartmyFR-S
iHeartmyFR-S's Avatar
Drives: 2013 Scion FR-S (Raven Black :)
Originally Posted by Sigh-on-Rice View Post
1) warm up the engine fully.
2) turn off the engine.
3) the side brake needs to be released.
4) press and hold the brake and start the engine.
5) while holding the brake, pull the side brake and let go of the brake.
6) press the brake 2 or more times and hold the brake.
7) while holding the brake, release and pull the side brake 2 or more times and hold the side brake.
8) while holding the side brake, press the brake 2 times.
9) TC and VSC lights should turn on.
If you can't turn the TC and VSC back on by pressing the buttons, then it worked. You'll need to turn off the engine to turn TC and VSC back on.
Note: I only tried this on MT. I'm not sure if it works on AT.
isnt this just the same as press and holding the TS button for 5 seconds? and it disables TC and VSC and keeps it off til you turn it back on...?? If it is different, could u please explain to me the difference ?? lol thanks
2013 FR-S Raven Black (CURRENT)
2002 BMW 325Ci e46
1991 EF Sedan
1991 CRX Si Built B16 Fully Caged All SiR Interior and Exterior
1993 DA JDM GSR w/ all type r internals/B16 tranny 2way clutch type LSD
iHeartmyFR-S is offline   Reply With Quote
Old 01-06-2013, 09:22 AM   #27
travace
travace's Avatar
Drives: Scion FR-S
i was so gonna post this
travace is offline   Reply With Quote
Old 01-06-2013, 09:47 AM   #28
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I guess the title might be a bit misleading, it disables EBD also (electronic brake distribution)as someone actually told me before. It's not something you'd realize just driving on the road.
The Following 2 Users Say Thank You to Rayme For This Useful Post:
iHeartmyFR-S (01-06-2013), Sigh-on-Rice (01-07-2013)
TPMS, LSD and Stability Control FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 11-05-2012 04:12 PM
So, when does the traction/stability control work against you? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 2 10-03-2012 09:06 AM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 07:11 PM
Traction Control / Vehicle Stability VSC kicking in when not necessary? WTF Scion FR-S / Toyota 86 GT86 General Forum 15 08-15-2012 04:24 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
