Old 10-03-2012, 08:41 AM   #1
NOHOME
Drives: RAVEN
So, when does the traction/stability control work against you?
Since I am new to all forms of electronic nannies (never even had ABS) I have to wonder in what situations the traction control is going to be a negative.
Certainly in a situation where I need to rock the car out of a snow drift it will require turning the thing off.
What about sudden transitions not involving wheel speed differentials? I am thinking black ice situations. Not that much will save you, but will it become a liability by preventing driver input?
NOHOME is offline   Reply With Quote
Old 10-03-2012, 09:00 AM   #2
Iixii
Drives: NonE
Snow. If you're stuck then, you need to turn the traction control off so that the wheels can spin you out of snow.
Drift or slide. If you want to do this intentionally then turn that off.
Iixii is offline   Reply With Quote
Old 10-03-2012, 09:06 AM   #3
2013GTRNate
2013GTRNate's Avatar
Traction control will beat any novice driver in ALL conditions… Only the pros will be able to react better…
-Nate
2013GTRNate is offline   Reply With Quote
TPMS, LSD and Stability Control FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 11-05-2012 04:12 PM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 07:11 PM
Traction Control / Vehicle Stability VSC kicking in when not necessary? WTF Scion FR-S / Toyota 86 GT86 General Forum 15 08-15-2012 04:24 PM
TPMS and Traction Control Mavrik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-02-2012 01:50 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
