Old 01-02-2013, 10:15 PM   #1
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely
1) warm up the engine fully.
2) turn off the engine.
3) the side brake needs to be released.
4) press and hold the brake and start the engine.
5) while holding the brake, pull the side brake and let go of the brake.
6) press the brake 2 or more times and hold the brake.
7) while holding the brake, release and pull the side brake 2 or more times and hold the side brake.
8) while holding the side brake, press the brake 2 times.
9) TC and VSC lights should turn on.
If you can't turn the TC and VSC back on by pressing the buttons, then it worked. You'll need to turn off the engine to turn TC and VSC back on.
Note: I only tried this on MT. I'm not sure if it works on AT.
The Following 13 Users Say Thank You to Sigh-on-Rice For This Useful Post:
Bonburner (02-01-2013), bpracer (01-02-2013), cebul (06-16-2016), developer (01-02-2013), jliongh (10-08-2016), KAR (01-04-2013), lazyluka (01-13-2013), OmarGC (01-04-2013), oscar_FRS (03-25-2015), Retro86 (02-06-2013), sandman126 (01-26-2013), Scooby South (07-07-2013), softgrip (03-14-2016)
Old 01-02-2013, 10:17 PM   #2
BoostedMKIV
BoostedMKIV's Avatar
Drives: 2006 Pontiac GTO
Good god...that seems like a lot to do. Isnt there a button you can turn off and leave off?
Visit CentexCruises on Facebook for Event Dates and More....
https://www.facebook.com/CentexCruises
BoostedMKIV is offline   Reply With Quote
Old 01-02-2013, 10:27 PM   #3
Sigh-on-Rice
It looks like a lot. But if you memorize it, it only takes like 5 secs. Its like brake, brake, side, side, brake, brake. And holding on that button for 3 secs doesn't turn them off 100% completely.
Old 01-02-2013, 11:18 PM   #4
developer
Drives: BRZ Limited
Actually, it is stupid simple. If I can do it anyone can. As you said it doesn't work when the car is cold, must be to temperature. How did you figure this out? How do you know it completely disables everything? Is it putting the car into maintenance mode?
developer is offline   Reply With Quote
Old 01-02-2013, 11:18 PM   #5
bpracer
Drives: Asphalt FR-S
Does it stay off after restarting the car? Otherwise you don't need to do all this for the same result.
Edit-
OK, just saw the post in the racing section where it is explained further driver aids are turned off by this procedure beyond just VSC and launch control. Good to know for track days.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 01-02-2013, 11:37 PM   #6
chutrain
chutrain's Avatar
Drives: WRB BRZ
This like putting some cars in launch mode. I guess Toyota/Subaru didn't want everyone to turn it off completely. There would be a lot more cars showing up on the junkyard.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 01-02-2013, 11:50 PM   #7
Sigh-on-Rice
I saw a post on how to do this in a forum for 86 in official Japanese Toyota site. And yes, it's in maintenance mode.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
developer (01-03-2013)
Old 01-02-2013, 11:51 PM   #8
Sigh-on-Rice
Edit-
No, it doesn't stay off. You need to do it every time you turn on the car.
Old 01-03-2013, 03:15 AM   #9
I<3Twisties
I<3Twisties's Avatar
Drives: SUBARWD
Ok, so that's up up down down left right left right b a start?
I<3Twisties is offline   Reply With Quote
The Following 29 Users Say Thank You to I<3Twisties For This Useful Post:
20valvewynn83 (07-09-2013), ATL BRZ (01-04-2013), B L U E S L A T E (01-09-2013), Bonburner (02-01-2013), BoostinIX (01-11-2013), Calum (01-04-2013), Dadhawk (02-01-2013), Deepseadiver (03-04-2013), demonpoofball (09-23-2014), g0lden (01-04-2013), gonzo (01-04-2013), Guff (01-15-2013), hippari (01-04-2013), hmong337 (07-03-2013), IBill4You (04-10-2015), IloveBaldEagles (01-21-2013), jazztennor (06-14-2013), Kwaziekeller (02-02-2013), lazyluka (01-13-2013), lbroskee (01-05-2013), ragingSPAM (10-06-2014), raul (01-04-2013), Retro86 (02-06-2013), SkAsphalt (01-07-2013), Snozzberries (01-05-2013), Tagera (11-13-2013), TheGuyWithTheFireStorm (01-04-2013), travace (01-06-2013), wparsons (01-03-2013)
Old 01-03-2013, 03:55 AM   #10
gonzo
Drives: frs
gonzo is offline   Reply With Quote
The Following User Says Thank You to gonzo For This Useful Post:
g0lden (01-04-2013)
Old 01-03-2013, 10:35 AM   #11
86BRZ
86BRZ's Avatar
Drives: BRZ Limited arrived on 9/1/2012
I saw a video on you tube they remove the fuse from the fuse box. That is for sure.
86BRZ is offline   Reply With Quote
Old 01-03-2013, 10:52 AM   #12
aagun
Drives: 86
you can do it on easy way. only press TS bottom for 5 sec and it disconnected the system
aagun is offline   Reply With Quote
The Following User Says Thank You to aagun For This Useful Post:
Trashed675 (01-23-2013)
Old 01-03-2013, 10:58 AM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This "pedal dance" method which has been posted here a number of times now actually puts the car into a diagnostic mode. In this mode, it disabled the Electronic Brakeforce Distribution and "panic brake" functions as well. So technically holding the TCS button down and the "pedal dance" perform some of the same functions, but they aren't identical.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
ATL BRZ (01-04-2013), gonzo (01-04-2013), Sigh-on-Rice (01-03-2013)
Old 01-03-2013, 05:16 PM   #14
ROCKETS86
Rockets
ROCKETS86's Avatar
Drives: Toyota 86 GTS
just pull out the abs fuse its dead easy
ROCKETS86 is offline   Reply With Quote
TPMS, LSD and Stability Control FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 11-05-2012 04:12 PM
So, when does the traction/stability control work against you? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 2 10-03-2012 09:06 AM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 07:11 PM
Traction Control / Vehicle Stability VSC kicking in when not necessary? WTF Scion FR-S / Toyota 86 GT86 General Forum 15 08-15-2012 04:24 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
