Old 12-30-2012, 04:55 PM   #15
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
I had this same problem this morning. The window did not auto-up and only would go down. The reset procedure WORKED and the window goes and up down now correctly with the auto up feature.
NOTE: I had a 350Z before that had the same frame-less window that goes and up and down. This is a known large issue on the 350Z as well. I had to replace the window motor once to remedy the issue.
n8dog11914 is offline   Reply With Quote
Old 12-30-2012, 05:08 PM   #16
JDMenrique
DEEEERP
JDMenrique's Avatar
exact same thing happened to me this morning, sigh...
JDMenrique is offline   Reply With Quote
Old 12-30-2012, 10:17 PM   #17
FRiSson
Drives: FR-S MT
It's not a "issue". It is a safety feature. Toyota designed the window to default to down-only configuration if it detected something blocking the path. The reason is that if someone's extremity is caught in the window, they don't want anyone to mistakenly close the window further.
FRiSson is offline   Reply With Quote
Old 01-03-2013, 05:30 AM   #18
Urka
Urka's Avatar
Drives: '83 Rabbit GTi, '99 G20t
There's some logic. Now other automakers with auto functions + jam protection, does it reset as well after sensing a jam? Thus needing initialization? I believe you have something here...:happy0180:
Urka is offline   Reply With Quote
Old 01-03-2013, 11:53 AM   #19
FRiSson
Drives: FR-S MT
No, you have to reset it yourself. Maybe it resets after you turn the ignition off and on again?
cold weather equals non operational windows Shit Luck Issues | Warranty | Recalls / TSB 45 11-02-2016 12:32 AM
cold weather & remote starter jarviz Scion FR-S / Toyota 86 GT86 General Forum 16 11-10-2012 07:03 AM
Cold-weather morning shifts NetMagi Scion FR-S / Toyota 86 GT86 General Forum 11 11-08-2012 12:05 PM
Cold / Wet weather brake issue? Ingen Scion FR-S / Toyota 86 GT86 General Forum 6 10-29-2012 12:42 PM
Pretty sure car hates the cold weather HuntingtonFRS Issues | Warranty | Recalls / TSB 28 10-21-2012 05:52 PM
