Old 12-23-2012, 10:19 AM   #211
schtebie
Drives: CBS BRZ Limited
Originally Posted by gmookher View Post
I will be doing Uoa when I hit about 20k miles, pointless before that on a tranny, even tho my Uoa will be off a FI car, even better for na guys.
Great recommendation on the Pentosin. Just swapped over two nights ago and the difference in shifting smoothness is very noticeable especially with ambient temperatures just barely over 30 F.
schtebie is offline   Reply With Quote
The Following User Says Thank You to schtebie For This Useful Post:
gmookher (12-23-2012)
Old 12-23-2012, 01:30 PM   #212
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I've been running Pentosin for about 1500 miles now. It honestly took about 1000 miles for me to really see the complete difference. Shifts are incredibly smoother now. I always felt like this was a bit of jerky car no matter how well I clutched but the Pentosin has changed this completely. I picked up a friend of mine to go to a party and it was her first time in this car; she didn't realize it was a manual till we parked. THAT smooth.
If you haven't yet, do yourself the favor and pick up some Pentosin.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following 6 Users Say Thank You to Laika For This Useful Post:
Bonburner (01-09-2013), gmookher (12-23-2012), GoSharks (12-23-2012), LeeMaster (12-26-2012), MasonL1997 (08-28-2017), schtebie (12-23-2012)
Old 12-23-2012, 06:08 PM   #213
bpracer
Drives: Asphalt FR-S
Just changed the trans oil and went for a ride. My transmission was pretty smooth to begin with, but I does seem to shift even smoother now.
I got the Pentosin from O'Reilly Auto Parts, had to go to two of them and ask for it, as it was in the back store room. Not all of them have it in stock.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 12-23-2012, 07:12 PM   #214
OrbitalEllipses
Drives: Attitude
I believe that has more to do with your ability and her inattentiveness/sensitivity than trans fluid.
Now that temps are falling into the low 30s my gearbox has really started misbehaving. Not shifting into 1st at 4mph, being unable to downshift to 2nd at 25mph without SHOVING it into gear...this gearbox certainly doesn't like low temps, that's for sure.
Old 12-24-2012, 08:45 AM   #215
gonzo
Drives: frs
Originally Posted by ADebelius View Post
I'm just confused. The owners manual specs a 75w-90 fluid, not a 75w-85 as mentioned. And the low end range for a 75w-90 fluid at temperature is ~13cst. The Pentosin is almost half that.
Check the manual someone posted on this forum, I believe it specs a 75-90 AND 75-85.
gonzo is offline   Reply With Quote
Old 12-24-2012, 10:13 AM   #216
Esoteric
Esoteric's Avatar
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
Glad it worked out for you! Since we did your car we have done two more and another with the Redline. Everyone noticed a difference.
Esoteric is offline   Reply With Quote
The Following User Says Thank You to Esoteric For This Useful Post:
Laika (12-26-2012)
Old 12-24-2012, 10:21 AM   #217
Dezoris
Dezoris's Avatar
It was 18 degrees car was outside for 8 hours and car would not go into second for about 3 miles.
However no notchiness in gear selection before and after that. This was the first time the Pentosin did not hide the trans issues.
Old 12-24-2012, 06:45 PM   #218
roddy
roddy's Avatar
Drives: '13 Ultramarine
That's for the rear end. Trans spec is 75W90, but many have found that a thinner fluid works better. Pentosin made a very noticeable improvement in mine.
Old 12-25-2012, 01:26 PM   #219
aced86
aced86's Avatar
Drives: 2013 frs asphalt m/t
Will the pentosin , work well for those of us in so cal and under track day use ? What would you suggest on service intervals if tracking once a month and still using as a daily driver ? Also I'm looking into price wholesale on Thursday may be able to save local members some Muuula
aced86 is offline   Reply With Quote
Old 12-25-2012, 09:26 PM   #220
Dezoris
Dezoris's Avatar
The main reason to use Pentosin is for colder weather performance. There are not too many complaints about shift feel from those in hot climates. Or at least that I have read.
Old 12-26-2012, 01:43 AM   #221
gmookher
I use it in phoenix..
Old 12-28-2012, 10:49 AM   #222
GoSharks
GoSharks's Avatar
Drives: BRZ Limited, WRB, 6 MT
39 degrees this morning, shifting into 2nd like butter with Pentosin that was put in on Friday. Thanks gmookher for the tip. Shifting issues was my biggest issue with my BRZ. Switching to Pentosin is a very noticeable change under all conditions at least with my transmission.
GoSharks is offline   Reply With Quote
Old 12-28-2012, 02:07 PM   #223
gmookher
'Welcome bro!
Old 12-28-2012, 06:26 PM   #224
gonzo
Drives: frs
Check it again, it says the tran and diff gear oils can be 75w-85 and/or 75w-90
I'm looking at page RM-3.
Official Australian Toyota 86/Subaru BRZ Owners Thread Maj3sty AUSTRALIA 148 09-02-2017 06:55 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
Must-read for Top Gear fans Sport-Tech Other Vehicles & General Automotive Discussions 16 03-28-2012 09:38 AM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
