Old 12-24-2012, 01:58 AM   #29
ill roller
Drives: BRZ/E30/IS300/LS400
Originally Posted by armythug View Post
Thanks for the post OP. So is it safe to say that Stance are made in Japan or JDM? This is importance for me to clear up.
If you contacted Stance I'm sure they could give you a difinitive answer... I never cared enough to ask.
Originally Posted by Justin91M View Post
I just ordered these coilovers yesterday A local shop I got them from is sponsored by stance and has these on all of their track drift cars.
Get Nuts Lab?
RISKY DEVIL // ILL PHOTOGRAHY
ill roller is offline   Reply With Quote
The Following User Says Thank You to ill roller For This Useful Post:
armythug (12-24-2012)
Old 12-24-2012, 03:52 AM   #30
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by crildz View Post
They ride smooth and are built very solid. They are a perfect all around coilovers since you can slam it or do autox or drift without having to adjust much of anything. Many of my frirnds have them and I have never heard anything bad except that the dampening adjustment can be that to reach
Thanks, i was just saying its hard to mention something as being "the best" because there isn't a single best suspension on the market. Whatever is best for you no matter what the cost is what you want, i had Stance on my 240sx because i read reviews and everyone said they ride smooth and i had to sell them in less than a month because i couldn't take it. I switched to a Nismo spring/strut system and was much happier.
I haven't ridden in any FR-S but my own and have only had it stock and with Tein H Tech springs and the ride with them is as good as stock, everything rides good on nice roads but i just don't want people to be disappointed looking for a stock like ride when they get a coilover system like this. Look for somebody local to go for a test ride if at all possible.
I think Stance makes a quality product and i hear the service is good, this type just isn't for me.
Old 12-24-2012, 04:51 AM   #31
ill roller
If you think Stance coilovers ride too harsh, and swapped them out for oe optional spring/struts, then you just shouldn't be buying coilovers. Stances do ride very good on every car I've driven/ridden in, but factory suspension is a completely different thing.
I like a nice firm ride, not harsh, but firm. The FRS/BRZ has a firm ride from the factory, which I liked, and the Stance coilovers definitely feel like coilovers, but they seem much more properly valved then the factory coilovers. They're about as firm, but with less of the harshness. Aside from big bumps, which as I mentioned are definitely worse (but that could be in part due to my height).
Old 12-24-2012, 01:01 PM   #32
silversprint
Drives: Mr2 Spyder, Lexus Is350
Stance ride harsh because they use linear pistons. A koni, bilstein, kw, AST or ohlins will give you the same improvement in handling but won't ride as harsh because they all use a digressive piston.
Stance is made in south Korea by HSD. HSD also makes Buddy club, Powertrix, and Driftworks. If you look closely they are all the same coilovers with difference colors. Spring rate may vary between them.
Toyota MR-S 300hp, 2100lbs. Ohlins, Toyo, BFW,
silversprint is offline   Reply With Quote
Old 12-24-2012, 01:10 PM   #33
Justin91M
Justin91M's Avatar
Drives: Bagged RB8Six
Originally Posted by ill roller View Post
Get Nuts Lab?
Yep thats them.
My Bagged Rocket Bunny FRS!
2013 Asphalt FR-S MT.
IG: itsjay8six
Justin91M is offline   Reply With Quote
Old 12-24-2012, 05:18 PM   #34
ill roller
How is the ride harsh? They ride fantastic.
Yep thats them.
Love that place!
Old 12-26-2012, 12:03 AM   #35
Justin91M
Justin91M's Avatar
Love that place!
Yea that place is awesome. It was my first time going there and Forrest was way cool! Forrest even gave me a ride a long in his 240. Anyways love your setup, thanks for the review. Can't wait for mine to come in.
IG: itsjay8six
Old 01-01-2013, 01:20 PM   #36
dabocx
dabocx's Avatar
Drives: Scion FRS
What settings did you go with front and back?
Mine came in today
dabocx is offline   Reply With Quote
Old 01-01-2013, 01:36 PM   #37
whataboutbob
AutoX-10/10ths every run
...factory coilovers....
Pretty sure you mean struts.
Build thread:Here
Old 01-01-2013, 05:28 PM   #38
Aki
Drives: '96 beater Corolla
Buddy Club I think is made by Bor Chuan.
A good damper will have a digressive shock curve, otherwise it gets too skittish on high-amplitude, low frequency bumps.
I haven't heard bad stories with the Korean KSDs, but coilovers in general are the one area you don't want to go cheap on imo. If you look at OEM dampers, they're a lot beefier--which although is heavier, also means they won't sheer off when you're pushing the car. This Bor Chuan coilover bent and broke on a track, messing up the 240SX:
This Buddy Club coilover just died while driving on the street:
Is KSD/Stance different? Who knows, maybe they are. All I'm saying is there's reason why companies like Ohlins, Koni, Bilstein, Moton etc are trusted.
Aki is offline   Reply With Quote
Old 01-01-2013, 05:49 PM   #39
gmookher
get what you pay for..
Old 01-01-2013, 07:14 PM   #40
kickz
Drives: subaru sti
nice pics were they easy to install
this post def. help with my coilover decision
kickz is offline   Reply With Quote
Old 01-01-2013, 07:36 PM   #41
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Sitting pretty on cheap coils, to each their own.
People can get real picky/technical about suspension, it all depends on your needs/wants. Personally, as an 'upgrade'? No way.
chulooz is offline   Reply With Quote
Old 01-02-2013, 12:37 PM   #42
ill roller
Mine came in today
I forget exactly where I put them, but I've got the dampers about exactly on the middle setting.
Someone is a stickler.
You people just repeated blow this coilover thing way out of proportion. No one is saying that Moton, KW, and such don't make great products. but that's not to say that entry level great products are shit. We're not talking about some NEX or Ksport coilovers here, stance is one of the most widely used and trusted coilovers in drifting.
Really you guys can think what you want about Stance's product, but they keep proving themselves:
D2 RS/K-Sport Kontrol Pro Coilover Review DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 62 04-08-2016 01:32 PM
Stance Super Sport Coilovers FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-28-2015 08:59 PM
►►Stance Super Sport Coilovers◄◄ Free Shipping - Photos and Video FT-86 SpeedFactory Brakes, Suspension, Chassis 43 01-31-2013 09:17 PM
Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers Diego@lutzperformance Brakes, Suspension, Chassis 1 10-04-2012 01:43 PM
