go_a_way1
Old 12-15-2012, 10:52 AM   #631
RazorHawk
Drives: 2013 Scion FR-S 6AT Firestor
Originally Posted by DaJo View Post
The difference size in wheels may also affect your speedometer reading.
I'm waiting for the S7:F myself...but won't be getting it unless they bring the size down...
If you just get tires that match the stock total height of the wheel, your speedo will be fine. For instance, you will want to drop approx 10 sidewall series for every inch you go up in wheel size, and you will be close. Then from there, do some math to figure it out.
Sidewall series is percentage of tread width that the sidewall is, remember to multiply that times two for total height of the tire (as there is sidewall on the top and bottom of the tire)
Ex:
Stock tire/rim 215/45R17
225 / 25.4 = ~8.46 in. treadwidth (convert from mm to in, divide by 25.4)
8.46 x .45 = 3.81 in. sidewall height (treadwidth times sidewall series)
3.81 + 17 + 3.81 = 24.62 in. (total height of stocl rim and tire combo)
So, with anything we do, we want to aim for that last number there, to keep our speedo on track. If the final number is lower than 24.62 in, we will be going slower than it reads, if it is higher, faster than it reads
)Please note, per Tire rack's website *no affiliation, I just like to use them for reference) most 215/45 R17 are listed at 24.6 in height, although the stock michelins are listed at 24.7 in total height)
I got some winter tires on 16" rims to give me some more sidewall to protect against all the nasty spring potholes in my area. Heres the math on that:
205/55R16
205 / 25.4 = 8.07 in. treadwidth (a little narrower than stock, good for cutting through snow)
8.07 x .55 = 4.44 in. sidewall height (a little more cushion for potholes)
4.44 + 16 + 4.44 = 24.88 in total wheel and tire height. THis means that my tires are now .16 in taller than stock, about .02% so taller than stock. No noticeable difference in speedo reading.
For any wheel and tire combo, you can take the equation below, which is a simplification of the above steps (starting with the standard tire size way of displaying numbers eg. 205/45R17) and leave one variable out, and you can figure out what you want/need/. My recomendation is to leave out the treadwidth variable, bacause you should be able to get close on sidewall, and that will be the most fine tuneable.
(((T / 25.4) x S) x2) + R = H
T = Treadwidth (in mm)
S = Sidewall series (a percentage expressed as a deciamal in our equation)
R = Rim size in inches
H = Height of total package
For the 19 in option discussed above:
We want 19 in rims, 35 series rubber, and stock tire height, so equation looks like this:
(((T / 25.4) x .35) x2) + 19 = 24.62 solve for T
T = 203.92, 205/35R19 would be very close
For 30 series rubber:
(((T / 25.4) x .30) x2) + 19 = 24.62 solve for T
237.91, 235/30R19 also very close to stock.
So, I hope I have not fried your brain, but there are the numbers for you.
2013 FR-S #04790 Firestorm, AT with:
Beatsonic Shark Fin Antenna
5AD Spoiler
205/55R16 Michelin X-Ice3 winter tires on Motegi MR 107 x 16 Rims (winter only)
Rally Armor mudflaps in black with red logos
RazorHawk is offline   Reply With Quote
The Following User Says Thank You to RazorHawk For This Useful Post:
Estey (12-16-2012)
Old 12-15-2012, 11:21 AM   #632
pjb86
pjb86's Avatar
Drives: 2013 Scion FRS Raven
Go here and type in the tire sizes your looking at and it will tell you the outside diameter without all the math.
http://www.csgnetwork.com/tiresizescalc.html
pjb86 is offline   Reply With Quote
Old 12-15-2012, 11:28 AM   #633
RazorHawk
That will work as well! Thanks!
5AD Spoiler
Old 12-15-2012, 12:15 PM   #634
jchall30
Drives: 2014 Whiteout Monogram FRS
I guess I just need to look around and see what everyone else on here are using on there 19's. I want it to just look good. . Anyone that has these rims please post what tire size you are using.
JC
jchall30 is offline   Reply With Quote
Old 12-15-2012, 01:33 PM   #635
GT86-Ian
GT86-Ian's Avatar
Drives: Toyota GT86
Few cars here for you, but larger the wheel you get worse the ride will be.
http://www.ft86club.com/forums/showthread.php?t=14234
http://www.ft86club.com/forums/showthread.php?t=17039
GT86-Ian is offline   Reply With Quote
Old 12-15-2012, 03:57 PM   #636
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Originally Posted by jchall30 View Post
I'll email Five Axis and ask about the sizes.
Please let us know what 5:AD's reply is! If they have 18's then I would be very tempted... Better yet 17's
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 12-15-2012, 04:42 PM   #637
jchall30
I will post what they reply. I bet it won't be till Monday.
JC
Old 12-15-2012, 07:11 PM   #638
DC-FRS
Drives: Whiteout FR-S
Would like to know if 18x8.75 +35 all the way around will fit with stock height, and also if it will fit with slight drop lowering springs (either Eibach or Tein).
Thanks!
DC-FRS is offline   Reply With Quote
Old 12-15-2012, 07:45 PM   #639
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Thanks!
Yep, easy math:
(Compared to OEM)
9mm less inner clearance
35mm extended outward
Front tire may stick out passed fender w/o a little negative camber.
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
DC-FRS (12-15-2012)
Old 12-15-2012, 09:02 PM   #640
funcheung
funcheung's Avatar
Drives: Subaru BRZ WRB
our car gas little horsepower....18 is good enuf. If ur worried about speed diff, just make sure you use the size that has similar rolling diameter as the stock size. I mounted 225/40/18 and 255/35/18 in the rear. For the track i use 235/40/17.
funcheung is offline   Reply With Quote
Old 12-15-2012, 09:10 PM   #641
jchall30
Just a lot of choices between wheel size and tire size considering I'm only looking at 3 different wheels from 5 Axis. I am seeing the positives to all sizes. Ugg.
JC
Old 12-15-2012, 09:16 PM   #642
ZN6_88
Drives: GTS
Hey guys, would anyone know if the work vs-xx (18 x 9.5 +20) in O-disk would clear the stock calipers?
ZN6_88 is offline   Reply With Quote
Old 12-16-2012, 03:13 AM   #643
stout90
Drives: 2013 FR-S 6MT~FireStorm
how could you miss this thread?
http://www.ft86club.com/forums/showthread.php?t=7535
stout90 is offline   Reply With Quote
Old 12-16-2012, 03:43 AM   #644
JoeBoxer
JoeBoxer's Avatar
Stock suspension I like 18x8.5 +40ish offset with 235/40 tires. Check my build thread I have had a few different setups u can look at.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
