Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 12-15-2012, 02:59 PM   #71
lazyluka
Drives: GT86
I have owned the car for less than a week, less than 1000km and my mat is already showing wear
lazyluka is offline   Reply With Quote
Old 12-16-2012, 12:08 AM   #72
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
wow that sucks. how do you treat the mat? do you always brush off your shoes? and not wear sharp heeled shoes? do you fluff the mat after every use?
Surok is offline   Reply With Quote
Old 12-16-2012, 01:45 AM   #73
lazyluka
Drives: GT86
I only drive in Chucks, so the heel is a bit sharp, but there's very few shoes that have a curved heel.
The mat hasn't been out of the car yet, but I did give it it's first vacuum today (6 days of ownership). Didn't do much to fix it.
My dealer offers a free 1000km check-up and seeing as I am very close to that now I may pop by and complain while they check things over.
Old 12-29-2012, 05:34 AM   #74
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
While I like the looks of those Monster Mats 2 things held me back: The price in Aus and the fact that there are front and rear; I only wanted front.
After much searching I found a site that ships these to Aus. I have ordered these in black http://www.carid.com/2013-subaru-brz...ts-161232.html
from here: http://www.carid.com/2013-subaru-brz-floor-mats/
Many choices of style, colour, f&r or fronts only.
I will post pics when they arrive.
MarkMash (12-29-2012)
Old 12-29-2012, 06:51 AM   #75
eckoflyte
Drives: Toyota 86 GTS
Will the US passenger mat fit properly to our drivers side? Also do you know if the mat comes with the plastic hole that is used to hold it in place?
eckoflyte is offline   Reply With Quote
The Following User Says Thank You to eckoflyte For This Useful Post:
Old 12-29-2012, 04:12 PM   #76
Captain Snooze
Drives: Red Herring
Ahhhhh... I did not consider that :/ Mmmmm... interesting question. Having given it about 2 minutes thought on waking just now I don't think it should make a difference ; there is no reinforcement for one's heels under the pedals. I might have to perform surgery.
I do not know about the hole situation either but I seem to remember reading somewhere (could be false memory) that the mats are held in place by the rubber backing.
Oh well, seemed like a good idea at the time lol. I will post pics once they arrive but I can't tell you about fitment for another couple of months. (wooooo!!)
Old 12-29-2012, 09:44 PM   #77
m0nty
m0nty's Avatar
Drives: 86 GT
Different car, but I have the same issue with my Clio. I wear business shoes every day with a hard heel. Thinking about wearing my tigers to work and changing there.
m0nty is offline   Reply With Quote
Old 12-29-2012, 09:52 PM   #78
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
i have 1900km on my car now. only ever work puma driving shoes with the round heel.
no wear on the carpet.. i think it is the sharp heels doing the damage,.
Old 12-29-2012, 09:57 PM   #79
st162celica
Drives: 86 GTS Manual - Tornado Grey
Got the same issue. I wear thongs while driving or barefoot. Put shoes on when I get to work.
st162celica is offline   Reply With Quote
Old 12-30-2012, 11:45 PM   #80
shire1976
Drives: 86 GT MT
I always take my shoes off, drive only in socks or bear feat.
I noticed the mats wearing at 1000km which blew me away given I never have shoes on.
I'm up to 9000 and the wear doesn't seem to getting much worse which is positive.
shire1976 is offline   Reply With Quote
Old 12-31-2012, 10:19 PM   #81
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Drivers heel pad - simple solution to make a heel pad for the drivers stock mat that looks fantastic as below for about $15 in total.
One of our 86 club members here in New Zealand, Peter Sullivan, who is not a member of this forum came up with this brilliant solution and has given me permission to share his DIY writeup with you all.
From Peter:
I purchased a rubber door mat from "The Warehouse" (this is our cheap general purpose big box store like walmart in the USA) for $9.99 and this was sufficient to make 6 heel pads for the 86 drivers mat. It has raised ridges one side and is PERFECTLY SMOOTH on the other - This is important. The backing needs to be smooth without any dimples or non-slip bits. TIP - have a look at the household rubber mats section of the store rather than rubber car mats as most of the rubber car mats will have dimples etc - the household mats won't.
From this I cut a piece measuring 250mm by 150mm using sharp knife. To cut the corners I used an NZ 10 cent piece - the same as an Australian 10 cent piece and similar to a dime in the USA. Use a bigger coin if you want rounder corners and of course feel free to cut into any shape - I just did a simple rectangle.
All the marking and cutting was performed on the smooth side of the rubber.
Velcro is extremely good at attaching itself to carpet fibres as shown in this photo. There is only about 60mm of the "hook" side of the Velcro in contact with the carpet, and yet it is strong enough to suspend the whole carpet in the air.
The Velcro hook is 50mm wide with a self adhesive backing.
Thoroughly clean the smooth side of the rubber with Mentholated sprits to remove any dirt or grease.
Peel off the backing and attach the Velcro. Press firmly on the Velcro for at least 25 seconds. This will give the best adhesion, being a contact glue.
Job done, and it can be moved or removed at any time, but it won't slip underfoot. Thanks Peter!!!
nzer is offline   Reply With Quote
The Following 12 Users Say Thank You to nzer For This Useful Post:
AUmarvin (01-01-2013), BreezinBy (02-18-2013), Chojin9 (01-01-2013), Dadhawk (01-02-2013), evil_1998 (01-01-2013), fuddbutter (01-16-2013), Gums (01-17-2013), Justkiz (01-01-2013), lazyluka (01-02-2013), monkie (01-16-2013), st162celica (01-01-2013), Sutty (01-17-2013)
Old 01-01-2013, 06:52 PM   #82
Justkiz
Drives: WRB BRZ
Oh my..... I was thinking to use a clear chair mat to DIY the heel pad like above but decided to buy a Monster heel pad instead, just could not resist
Using Velcro is a brilliant idea and I have to agree that above method is the most effective yet easy way to fix the problem!
My heel pad is posted from Japan on 28//12/12 and I guess it will be arrived sometime next week, I will post some pics once I install it.
Justkiz is offline   Reply With Quote
Old 01-16-2013, 07:24 PM   #83
Captain Snooze
Drives: Red Herring
Lloyd mats turned up today. I am happy with the construction but I still don't know if my buy was a success or fail. Maybe someone could comment. That is , I purchased them from a U.S. site and I don't know if they will be suitable for rhd.
They do.
Old 01-16-2013, 07:28 PM   #84
nzer
nzer's Avatar
Lloyd mats turned up today. I am happy with the construction but Istill don't know if my buy was a success or fail. Maybe someone could comment. That is , I purchased them from a U.S. site and I don't know if they will be suitable for rhd.
They do.
Looks to me like they won't fit as the angles on the drivers/passengers side are different and they are not really interchangeable.
The post just above yours has the picture of my drivers side RHD mat. You can see the angles are cut the opposite way.
They may fit but not as nicely as the OEM or other JDM specific (ie: RHD) ones.
But you never know - have you not got your car yet?
Bad Drivers jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 7 10-27-2016 04:08 PM
Tall drivers trackmagic Scion FR-S / Toyota 86 GT86 General Forum 91 08-02-2013 10:48 AM
Hell is other drivers Zaggeron Off-Topic Lounge [WARNING: NO POLITICS] 25 09-08-2012 01:30 PM
Any FR-S/BRZ drivers in Los Angeles? FRSjeff Southern California 1 08-30-2012 12:15 AM
Real drivers onemorelap Scion FR-S / Toyota 86 GT86 General Forum 19 07-09-2012 08:17 AM
