AVOturboworld
Old 12-14-2012, 04:08 PM   #1891
nonicname
Drives: it has 4 wheels and a motor
Originally Posted by stevo_12v View Post
This might sound a bit ricer-ish.. but any possibility of say an OVAL 'badge' maybe front & back to replace the stock Scion/Toyota/Subaru badge locations for people who have one of your systems fitted into their cars?
One badge would be fine - rearward facing as the back badges always seem to get heaps of soot/dirt stuck behind them from the exhaust.
Maybe an oval design similar to the Subaru badge - ie black background, with just a silver "AVO" logo in your font, but with the clear plastic/lacquer over it.
Or using your current logo, but everything in silver(minus the 'turboworld') with the AVO text and turbo picture.
UGR do a similar thing on their kits.. OEM badge
UGR badge
I think it would be a nice subtle look for any AVO'ed 86/FR-S/BRZ car.
If cost is a factor, maybe make it an 'accessory', I would definitely buy one.
i like this idea.
nonicname is offline   Reply With Quote
Old 12-14-2012, 05:27 PM   #1892
frsvr4
Drives: '13 FRS
I love the look and simplicity of this kit. As of now, this is the one we will be buying in the not-too-distant future.
Couple questions (sorry if they've already been answered, this is a VERY long thread):
1) What is the stock clutch capable of holding? Should I install a new clutch when I bolt on this turbo kit?
2) How does the high-compression factory engine tolerate boost? If we keep the boost level low, is there enough safety margin in this kit to assume long term durability?
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
Old 12-14-2012, 06:55 PM   #1893
Celica00
Celica00's Avatar
Drives: 86
1. clutch started to slip at about 210 ft/lbs tq based off of what another turbo manufacturer said.
2. w/ the high compression ratio, each psi packs more of a punch so low boost is sufficient for nice gains
Celica00 is offline   Reply With Quote
Old 12-15-2012, 12:42 AM   #1894
frsvr4
Drives: '13 FRS
1. Thank you
2. Agreed... just curious about the pistons for when mistakes happen
3. Any issues passing cali type emissions sniffing?
This kit is exactly what I'm looking for, though. I was bummed the wife fell in love with the fr-s instead of the genesis coupe turbo, but this kit makes the hyundai obsolete. I love that this retains the stock fuel system because that will drastically increase reliability. It will be her dd until its my toy in a few years but theres no way we will wait that long to turbo it.
Old 12-15-2012, 09:44 AM   #1895
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
The clutch start slipping at around 270-275 WHP.
Paul, can you please remove the plate on your AVO BOV to vent 50% in the atmosphere an make a little video inside, outside the car so you can hear how sound the avo BOV.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 12-15-2012, 12:12 PM   #1896
Lammie
Lammie's Avatar
Drives: Subaru BRZ
I thought the clutch slips from torque not HP.
Lammie is offline   Reply With Quote
Old 12-15-2012, 01:32 PM   #1897
2forme
This, HP is just a function of torque.
Old 12-15-2012, 01:33 PM   #1898
NoFear99
NoFear99's Avatar
That is possible but HP and torque goes together.
If you have more HP you will have more torque by the way.
Fullblown with 7 psi was at 275WHP and the car had 237TQ at the wheels.
If the Avo Stage 2 comes at 6.5PSI it should be around 220WTQ.
Very close to the limit of the stock clutch but should be O.K. for some time.
Old 12-15-2012, 02:03 PM   #1899
2forme
Not entirely correct. HP is a function of torque.
HP = TQ * RPM / 5252
So if you make a crap load of low end torque, with little up high then you're going to have low HP numbers. Look at the original Hummer. 440 ft lbs and only 205 HP. Likewise look at the 2001 Integra Type R. 205 HP and only 130 ft lbs.
The difference between these two is where the torque is made. On the hummer, the torque is made at 1800 RPM. On the ITR, it's at 7500 RPM. HP really only indicates where the torque is in relation to a motors rev range. It doesn't necessarily reflect the force put out by the motor, which is what causes clutches to fail.
The Following 4 Users Say Thank You to 2forme For This Useful Post:
Alienate (12-15-2012), civicdrivr (12-15-2012), kidgogeta (12-15-2012), WillRacer1jz (12-15-2012)
Old 12-15-2012, 02:10 PM   #1900
Celica00
Celica00's Avatar
Drives: 86
thanks for this. its a very good explanation.
now i know and:
The Following 2 Users Say Thank You to Celica00 For This Useful Post:
2forme (12-15-2012), enjoyminutemaid (12-31-2012)
Old 12-17-2012, 08:17 AM   #1901
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@AVOturboworld, any updates on Stage 2?
Old 12-17-2012, 12:49 PM   #1902
AVOturboworld
Sorry, no updates at the moment. Mainly because everybody is very busy packing up the stage 1 kits to ship out ASAP. Nothing much happening here either, which is good news, the car is trucking right along without any issues popping up.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Sportsguy83 (12-17-2012)
Old 12-17-2012, 12:59 PM   #1903
Celica00
Celica00's Avatar
Drives: 86
so, in this case, no news is good news
Old 12-18-2012, 03:49 AM   #1904
AVOturboworld
The Following 3 Users Say Thank You to AVOturboworld For This Useful Post:
BRZranger (12-18-2012), Sportsguy83 (12-18-2012), vubaru (12-18-2012)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 03:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 02:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 08:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
