Old 12-11-2012, 02:38 PM   #85
whtchocla7e
Drives: 2013 FR-S Hot Lava
Originally Posted by gily25 View Post
After a couple days I noticed the downshifting to 2nd was just as it always was so must have been placebo effect on that one.
Idle continues to stay strong at 750, the only time I've had a dip is when the fan for the HVAC is on setting 4; it came down to 250 then bounced right back up.
250 dude? That's crazy.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 12-11-2012, 03:00 PM   #86
brianbot5000
brianbot5000's Avatar
Drives: White WRX Hatchback, Toyota Pickup
Originally Posted by brzranger View Post
Got the Following done today at Carter Subaru Shoreline, WA: ECM update, GPS fix and front speaker grill.
Waiting on taillights and DRL replacements due to condensation.
Carter Subaru is awesome btw, quick, friendly and knowledgable.
GPS is working great so far! Don't even notice the ECM update.
How long did that take? Did they make you demonstrate the GPS issue before they would fix it? I bought my car there, and would take it there fore these services if it's not too much of a pain (I live in the south end of Seattle, so it's not too convenient). My GPS issue is hit and miss - sometimes it works fine, sometimes not at all.
2013 Subaru BRZ, SSM Limited
vin: 6007xx
build: 3/2012
brianbot5000 is offline   Reply With Quote
Old 12-11-2012, 05:47 PM   #87
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
Anyone also hear less chirping from the HPFP after the flash?
jacjac3 is offline   Reply With Quote
Old 12-11-2012, 06:37 PM   #88
BRZranger
Probably about 2 hours, but they did quite a few things. Didn't have to demo the GPS, they knew about the poor GPS placement, but they did ask questions about the nature of the problems.
Definitely go to Shoreline Carter, I was lucky and did a walk-in, but I had ongoing scheduling with them.
Carter also has free wifi, treats and coffee!
BRZranger is offline   Reply With Quote
Old 12-12-2012, 11:10 AM   #89
gily25
Drives: Silica BRZ 6MT
I think it's the same amount of chirping...my car is mostly moving at highway speeds so I'm not worrying about the chirp right now...it's inevitable it'll be a future recall/flash so I'm just holding out, especially since we know what it is, not like it's a loose belt or something in crisis.
gily25 is offline   Reply With Quote
Old 12-12-2012, 11:22 AM   #90
WRXcellent
Drives: 2013 BRZ Limited WRB & 2002 WRX WRB
Dropped my car off this morning for the Recall, GPS Fix, Crickets and Rear Deck Popping sound... I talked with the tech and he came out to listen to the crickets and he remembered my name since I took my WRX there for recalls... and he was honest and straight forward with me, saying they are still learning about the BRZ's and he'll pull up all the TSB's and check everything out, but they most likely don't have the parts and will have to get them and just to be patient. So I'm guessing the recall is the only thing that will get done today and I'll have to go back for the rest.
WRXcellent is offline   Reply With Quote
Old 12-12-2012, 12:15 PM   #91
MannyO
Night Owl
MannyO's Avatar
Drives: 2013 Subaru BRZ
I had the recall work done yesterday afternoon. Didn't notice any difference on the drive home aside from the idle. Idle was still at 600 and not 750 as others have mentioned. Actually noticed a bit of a fluctuation/dip at a few red lights where it dipped to 500 then back up to 600 on a 5-10 second interval.
MannyO is offline   Reply With Quote
Old 12-12-2012, 12:33 PM   #92
whtchocla7e
Did you have ac/windshield fan/defroster on?
Old 12-12-2012, 01:01 PM   #93
MannyO
Night Owl
MannyO's Avatar
Nope. Had everything turned off.
Old 12-12-2012, 02:16 PM   #94
jeebus
did your car ever idle like that before?
jeebus is offline   Reply With Quote
Old 12-12-2012, 02:30 PM   #95
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
After a day or two, I noticed mine dropped to 600 when I have no AC on. With AC it was about 650 to 700. I haven't really noticed it dropping to 500 yet. I'll give the ECU a couple more days to learn.
The Following User Says Thank You to jacjac3 For This Useful Post:
MannyO (12-12-2012)
Old 12-12-2012, 07:02 PM   #96
MannyO
Night Owl
MannyO's Avatar
Only once, about a week ago, did it idle like it did last night. I'm not overly concerned, just found it odd that most had their idle rise while I experience the opposite.
Old 12-12-2012, 10:01 PM   #97
WRXcellent
14 miles later on my car from the time I dropped it off.... the recall ecu flash was complete (didn't really notice a difference) and the rear deck popping/creaking noise was fixed... parts ordered for the gps and crickets.
Old 12-13-2012, 01:15 PM   #98
BRZ88
Drives: DGM BRZ
Dropped my car off at the dealership for the recall and tail light condensation only to receive a call later telling me the ECM crashed...and now my car is dead on their lot. Anyone run into this issue? any reason why it would crash? Perhaps a mistake the dealership made?
They did place an order for the new ECM which will have the update when it comes in...
BRZ88 is offline   Reply With Quote
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 03:46 PM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 05:13 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:23 AM
