go_a_way1
Old 12-11-2012, 07:58 AM   #547
Foobar
SLO NO MO
Foobar's Avatar
Rota gets a lot of criticism since they had some failures early on that were highly publicized. Truth is they sell a lot of wheels and they're affordable. Any wheel will crack under abusive conditions. It was just more publicized with the Rota since the population set is huge. They make OEM tires for the big car makers in the Asian markets and comply with the Japanese standards. They aren't the lightest wheels around nor are they using the most advanced manufacturing techniques, but you have to ask yourself if you require that for your use case.
I think they're fine. That said, I'm going with Weds TC105N's because I really liked the look, it's not overly expensive, and RavSpec has a good deal and are local to me. I'd keep my primacy tires to burn through them but I'm going staggered with 17x8 / 17x9 so that's not an option. Had I stayed square with 17x8, I'd use them up first.
Sent from my Galaxy Nexus using Tapatalk 2
Old 12-11-2012, 09:08 AM   #548
wparsons
wparsons's Avatar
New compound coming out next quarter, I'd pass.
Not just compound, whole new tire.
flickr
Old 12-11-2012, 11:29 AM   #549
OrbitalEllipses
Drives: Attitude
Originally Posted by CircuitJerk View Post
I loved those tires! I didn't notice it so much with an exhaust, but when I got another car without an exhaust it was almost unbearable.
I didn't notice it too much in WRX, until I put crappy all-seasons on before I sold the car. Those tires sucked, but they were quiet! I LOVE the BFGs, but I'm positive I won't be able to handle the road noise due a quieter exhaust and likely less sound-deadening.
Thanks for the clarification.
Old 12-12-2012, 05:03 AM   #550
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Anyone running 225/40/18 on 18x8.5/9.5?
Recently received my Work Emotion Kiwamis in bronze and was wondering if anyone is possibly running 225/40/18 on a staggered 18x8.5/9.5 setup?
JordanWho is offline   Reply With Quote
Old 12-12-2012, 05:13 AM   #551
Nardi330
Nardi330's Avatar
Drives: 86
I have 225/40/18 on 8.5 but its too narrow for 9.5 so I run 245/35 instead.
Nardi330 is offline   Reply With Quote
Old 12-12-2012, 05:38 AM   #552
JordanWho
JordanWho's Avatar
Thanks for the reply buddy.
Can you link me to your build thread so I can have a peak...
Old 12-12-2012, 05:48 AM   #553
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
I have 225/40R18 on the front on mine and 255/35R18 on the rear its a good fit
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 12-12-2012, 07:42 AM   #554
JordanWho
JordanWho's Avatar
You guys finding 245/255 easy enough to slide?
Old 12-12-2012, 10:20 AM   #555
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I remember reading 225/245 (f/r) tire sizes allow the FRS to still have some fun with its stock power
Old 12-12-2012, 11:07 AM   #556
SoCal FRS
SoCal FRS's Avatar
Drives: FR-S Asphalt AT
what's your offset? I was thinking about running the same set up but for the Raijin's
SoCal FRS is offline   Reply With Quote
Old 12-12-2012, 01:21 PM   #557
Dezoris
Dezoris's Avatar
Both Star Specs and RS3 make noise when driven at the limit. The RE-11 howls before you're at the limit; the tone will change as you break traction. The noise is one of the features of the tire; it makes it much easier to approach the limit by providing you with multiple types of feedback, any one of which can be used to determine how much grip is left.
The RS3 is terrible in the cold. Completely agree there. The RE-11 has the widest heat range, but it also has the lowest heat range.
The Star Spec Z1 is by far the cheapest and best option for the performance you get. Yes the RE11 is the most refined, progressive but for the cost is way too high and I don't like how they howl on the street when you get close to the limits. Even having a little bit of fun they alert the town you are near the limit.
As for the KDW2...
The KDW2 are OLD! There are much better tires and options now.
Old 12-12-2012, 01:31 PM   #558
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
I tried researching the forums and learning, but all these numbers are making my head hurt and I'm not entirely sure which numbers to match to ensure fitment.
Can anyone confirm if these will fit the stock tires?
http://www.ebay.ca/itm/17X9-ROTA-GRI...03d839&vxp=mtr
Wheel size: 17x9
Bolt pattern: 5x100
Offset: +30
If they fit the stock tires, does that mean the stock lug nuts will fit too? If not, how do I find out which aftermarket lug nuts to buy?
i_4got is offline   Reply With Quote
Old 12-12-2012, 01:37 PM   #559
JoeBoxer
JoeBoxer's Avatar
Wheel size: 17x9
Bolt pattern: 5x100
Offset: +30
There is a set of 17x9 Rotas in the classified for sale if you want to see how they look on stock tires. For lug nuts you can get gorilla 12x1.25 tuner style on amazon pretty cheap.
Old 12-12-2012, 01:45 PM   #560
i_4got
i_4got's Avatar
Yeah, I saw that but I was wondering if it's one of those things where it's like "Yeah, they'll fit if you force it, but there may be issues in the long-run" kind of thing. I know that happens if you have to stretch the tire to fit bigger wheels, but not sure if a similar issue will occur here.
Also, does that mean the stock lug nuts won't fit? How do I know what size to get? Can I deduce that somehow from the wheel size?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
