Old 12-10-2012, 04:12 PM   #15
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I'm running another vendor's exhaust, and after the first 500-1000 miles the packing in the muffler settled down and the hum (not quite drone, but close) in the mid RPM went away. I've expanded it to a header back, and it sounds great. The new overpipe really picked up the sound level to make it beefy.
I'm glad you like it.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 12-11-2012, 09:26 PM   #16
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
Ok, here's another update. Turns out the locking rings were not put on. I installed the locking rings and what a difference. The exhaust does not move as much anymore. The tips still stick out more to the left. I thought they were perfect after figeting around with them for an hour and a half, but right after I drive, the heat must expand the pipes or something and cause the left tip to stick out more.
I realized that the car was quieter after I was done and turns out The seal was not tight enough, hence some exhaust leak that leads to the loudness. I ended up checking the front and what do you know, one of the front pipe bolts snapped. I attempted to put in a spare but the holes were not aligned, so I loosened up the other side, and that snaps under tension as well. great.
After another hour of work, I finally got it tightened and good to go. Exhaust is not a lot quieter, however now I need to bring it in to Toyota because the damn stero or something inside the car is rattling from 1800-2100 Rpms lol -.-
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 12-11-2012, 09:27 PM   #17
Tylub
Tylub's Avatar
Rasp is also significantly less as I suspect it was the piping vibrating off of each other due to improper install of the mechanic. If you want something done right, I guess do it yourself...
Now to get the tips perfectly aligned...
When everything is perfect, pics and videos will be up!
instagram @Tylub
Old 12-11-2012, 11:32 PM   #18
1strwdcar
Drives: 2013 scion frs Whiteout
Im glad you like it! Post some media yo!
1strwdcar is offline   Reply With Quote
Old 12-11-2012, 11:39 PM   #19
Tylub
Tylub's Avatar
I'll get right on it as soon as all my adjustments are perfect!
instagram @Tylub
Old 12-11-2012, 11:44 PM   #20
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Check out my review and instructions on how to install and adjust your exhaust.
http://www.ft86club.com/forums/showthread.php?t=16614
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following User Says Thank You to Sony For This Useful Post:
Tylub (12-12-2012)
Old 12-12-2012, 03:53 AM   #21
Tylub
Tylub's Avatar
@Sony I'll try the loose then slowly adjust tactic. Because for now, they are perfect when cold... but right after a drive the sucker on the left moves out. FML
hopefully it doesn't rain that bad tomorrow
instagram @Tylub
Old 12-12-2012, 08:01 AM   #22
Foobar
SLO NO MO
Foobar's Avatar
Is the drone gone now that you have it installed correctly? I'm switching from a GReddy Evo3 to a Perrin system because other reviews have maintained that the Perrin is drone-free. Sure hope I'm not just replacing one drone with another.
Old 12-13-2012, 09:07 PM   #23
Tylub
Tylub's Avatar
yeah, drone is gone, this was caused by an exhaust leak caused by this... the front pipe bolts snapped, i don't know why... had to get some spares and retighten everything. Now, the drone is 100% gone. The exhaust is starting to break in real nice. It's pretty quiet now that I've driven a good 650 miles. 6th gear on the freeway is barely audible. I'd assume a 1-2db louder compared to stock. It's that quiet. Once you step on it, however, PURE SEX
instagram @Tylub
Old 12-13-2012, 09:09 PM   #24
Tylub
Tylub's Avatar
Another update, still can't adjust those dang tips perfectly! when it's cold, perfect... after driven, the left tip just keeps coming out by 1/4 inch... barely noticeable, unless you're me.
Also heard the Berk's Muffler delete dual tip in person and driven. Drones in cabin. A lot... also really loud. with 10 being an open tube drag racer, the Berk's comes in at an 8 while the Perrin headerback (non resonated, catted front pipe, and overpipe) comes in at a 6.5. stock would be like a 2-3 lol
instagram @Tylub
The Following User Says Thank You to Tylub For This Useful Post:
MrTranxD (12-13-2012)
Old 12-13-2012, 09:11 PM   #25
Tylub
Tylub's Avatar
pictures of the unit installed!
sorry I lagged so long..
better pictures as soon as weather clears up
instagram @Tylub
Old 12-13-2012, 09:26 PM   #26
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
Omfg that Berk drones like no other. LOL
MrTranxD is offline   Reply With Quote
The Following User Says Thank You to MrTranxD For This Useful Post:
Tylub (12-14-2012)
Old 12-13-2012, 09:37 PM   #27
Burn
Slack Bum
Burn's Avatar
Drives: FT86
Same here.. tried adjusting it a couple of times but no avail..
Burn is offline   Reply With Quote
Old 12-13-2012, 09:50 PM   #28
FR-S Matt
Man, between Perrin and Nameless, it's a close one for me. Both such good companies with quality designs.
Perrin Headerback Exhaust System F1point4 Engine, Exhaust, Transmission 183 10-04-2013 04:02 PM
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 05:18 PM
Perrin Oil Cooler -Prototype, Installed today! gmookher Engine, Exhaust, Transmission 103 01-15-2013 10:47 AM
Brand New SRT Headerback Exhaust System prest1ge Southwest 5 10-16-2012 06:06 PM
Perrin Overpipe and Catted Frontpipe Installed gmookher Engine, Exhaust, Transmission 22 09-23-2012 04:11 PM
