Old 12-07-2012, 05:44 PM   #15
Toyobaru808
What about DMEs? I want to wait for whitelines but it would be nice if we had a price estimate b/c if theyre priced over 600 id be turned off
Sent from my SGH-T989 using Tapatalk 2
Toyobaru808 is offline   Reply With Quote
Old 12-08-2012, 09:58 PM   #16
bpracer
Drives: Asphalt FR-S
Originally Posted by Supermassive View Post
...Some people will say that the threaded rod is a weak point, but after seeing the Cusco arms and GT Spec which are just stamped and welded steel vs. the machined block of aluminum with steel fittings that comprise the AP unit, the extra cost is worth it.
I would have to agree with being a bit nervous about that design. The threaded rod joint too far in the middle of the control arm and it will flex and fail on the threaded part of the adjustment rod. There's a reason they put rod ends at the very end of the other suspension arms.
I saw a similar setup for upper control arms. Easy to adjust, looked way over-built, but it failed because a threaded rod shouldn't be in any kind of bending moment.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 12-09-2012, 10:09 AM   #17
wparsons
wparsons's Avatar
I would rather have the "weak" point (threaded rod) inboard of the shock mounting rather than between the wheel and the shock.
All the force exerted on the shock is going to be from the wheel, if you put the weak point between those two then you have a potential failure point. With it inboard like these the only load it's carrying is the load required to keep the arm in place plus any side to side loads.
flickr
Old 12-09-2012, 01:14 PM   #18
bpracer
I agree with what you are saying, but the in-board rod end design in this case is not as "in-board" as I would want.
Asphalt FR-S
Ducati 848
Old 12-09-2012, 01:18 PM   #19
Dezoris
Dezoris's Avatar
My camber was. -0.1 rear left -1.1 rear right. Had the whiteline rear upper control arm eccentric bushings installed.
Old 12-09-2012, 01:53 PM   #20
Boosted
Boosted's Avatar
Drives: 13 brz, 06 STI
I used whitelines rear chamber kit. I have a even -2.3 on both sides. I have buddy club racing coilovers. The upper control arm kit is great but the old part is press fitted so its a pain to remove.
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car)
1988 CRX si- b16A1 (Sold)
RIP 2003 WRX
Boosted is offline   Reply With Quote
Old 12-10-2012, 02:55 PM   #21
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
So whats a good number we should be looking for? I currently have Eibach sportlines and -2 on rear left, -2.4 rear right. Was looking at adding the whileline bushings, will that get me back to .0?
Thanks
gdrider77 is offline   Reply With Quote
Old 12-10-2012, 03:55 PM   #22
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Thanks
You don't want to be at 0 camber, i am about -1.5 on the rear which is pretty conservative but i don't have as much drop as you. What you have actually isn't terrible is that with you in the car?
Old 12-10-2012, 04:28 PM   #23
gdrider77
gdrider77's Avatar
Thats with the printout the dealer gave me, how can i check with myself in the car?
Old 12-10-2012, 04:31 PM   #24
JoeBoxer
JoeBoxer's Avatar
It won't change much with your weight in the driver seat but if it closened the gap any at all i probably would be ok with it. What's the toe look like?
Old 12-10-2012, 06:27 PM   #25
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Do we really need more than a degree or so of static camber in the rear with the multilink setup? They're supposed to have better dynamic camber curves than a McPherson correct?
Nathan
SubieNate is offline   Reply With Quote
Old 12-10-2012, 06:51 PM   #26
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
threaded rods just scare me now.. i once had an R34 GTR go off in front of me on some touge when his rear ikeya formula adjustable arm threaded rod end sheared off. scared me for life.
Surok is offline   Reply With Quote
The Following User Says Thank You to Surok For This Useful Post:
nix (01-08-2013)
Old 12-11-2012, 12:42 PM   #27
gdrider77
gdrider77's Avatar
This is the printout from the dealer.
Old 12-11-2012, 12:58 PM   #28
JoeBoxer
JoeBoxer's Avatar
Get some oem camber bolts for the front you need some negative camber up there. Rear is a judgement call I'd probably get some spc lower control arms to bring it back down to -1.8 or so.
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
Rear camber adjustment options? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 09-12-2012 10:46 AM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
