#15 |
What about DMEs? I want to wait for whitelines but it would be nice if we had a price estimate b/c if theyre priced over 600 id be turned off
Sent from my SGH-T989 using Tapatalk 2 |
#16 | |
Drives: Asphalt FR-S
I saw a similar setup for upper control arms. Easy to adjust, looked way over-built, but it failed because a threaded rod shouldn't be in any kind of bending moment.
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 |
#17 |
I would rather have the "weak" point (threaded rod) inboard of the shock mounting rather than between the wheel and the shock.
All the force exerted on the shock is going to be from the wheel, if you put the weak point between those two then you have a potential failure point. With it inboard like these the only load it's carrying is the load required to keep the arm in place plus any side to side loads.
#18 | |
Asphalt FR-S
#19 |
My camber was. -0.1 rear left -1.1 rear right. Had the whiteline rear upper control arm eccentric bushings installed.
#20 |
Drives: 13 brz, 06 STI
I used whitelines rear chamber kit. I have a even -2.3 on both sides. I have buddy club racing coilovers. The upper control arm kit is great but the old part is press fitted so its a pain to remove.
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car) 1988 CRX si- b16A1 (Sold) RIP 2003 WRX |
#21 |
Drives: Subaru BRZ Limited
So whats a good number we should be looking for? I currently have Eibach sportlines and -2 on rear left, -2.4 rear right. Was looking at adding the whileline bushings, will that get me back to .0?
Thanks |
#22 |
Drives: Whiteout FR-S
You don't want to be at 0 camber, i am about -1.5 on the rear which is pretty conservative but i don't have as much drop as you. What you have actually isn't terrible is that with you in the car?
#23 | |
Thats with the printout the dealer gave me, how can i check with myself in the car? |
#24 |
#25 |
Drives: 2013 FR-S Ultramarine
Do we really need more than a degree or so of static camber in the rear with the multilink setup? They're supposed to have better dynamic camber curves than a McPherson correct?
Nathan |
#26 |
Wise old man
Drives: 86 GTS
threaded rods just scare me now.. i once had an R34 GTR go off in front of me on some touge when his rear ikeya formula adjustable arm threaded rod end sheared off. scared me for life.
| The Following User Says Thank You to Surok For This Useful Post: | nix (01-08-2013) |
#27 | |
#28 |
Get some oem camber bolts for the front you need some negative camber up there. Rear is a judgement call I'd probably get some spc lower control arms to bring it back down to -1.8 or so.
| Adjustable Camber Arms vs. Whiteline Camber Bushings | digital_assassin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 70 | 06-02-2013 06:06 AM |
| Rear camber adjustment options? | zooki | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 09-12-2012 10:46 AM |
| Camber plates | Captain Snooze | AUSTRALIA | 7 | 07-02-2012 06:51 PM |
