Old 10-02-2012, 01:28 PM   #1
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Wonky rear camber
So I installed my KW coilovers on Friday. Has anybody had a major differentiation between left and right rear camber. I'm looking at 1.7 on Rear left and 2.7 on rear right nothing appears to be bent just kinda weird.
jdzumwalt is offline   Reply With Quote
The Following User Says Thank You to jdzumwalt For This Useful Post:
Guff (10-02-2012)
Old 10-04-2012, 03:36 AM   #2
german86
german86's Avatar
Drives: GT86(ordered), Avensis T22 Wagon
Hi, its a pity that the camber is not adjustable!! I have -2 at both sides and i search for adjustable camber bolts!! Greets Jörg
sent via brain 1.1
german86 is offline   Reply With Quote
Old 10-04-2012, 11:04 AM   #3
jdzumwalt
Motor Sports slut
Just ordered White Line Rear arm bushing Kit
Old 10-08-2012, 10:20 PM   #4
brzzz
Drives: White BRZ
Sitting on an even surface? Heavy things inside the car on one side?
brzzz is offline   Reply With Quote
Old 10-08-2012, 10:53 PM   #5
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Ive put 2 different frs on my alignment rack and none were straight.
Silverdub is offline   Reply With Quote
The Following User Says Thank You to Silverdub For This Useful Post:
usptwins (12-30-2012)
Old 10-08-2012, 11:34 PM   #6
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
In some cars, you can loosen up the subframe and push it towards the side with not enough negative camber and then re-tighten it to make both sides a bit more uniform. I haven't tried on my BRZ but its worked on some others.
TomR
ABQautoxer is offline   Reply With Quote
Old 10-11-2012, 01:43 AM   #7
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Mine is bad too i have -1.4 on the left and -2.5 on the right with just Tein H Tech springs, i am looking at the SPC and GTSpec lower control arms i don't know if i can get my tech's to install the camber bushing kit.
JoeBoxer is offline   Reply With Quote
Old 12-07-2012, 11:40 AM   #8
Toyobaru808
so anyone know what the best rear control arms are?
Im also lowered on kwv3s and have a rear of -1.9 and -2.6. (trying to achieve -1.5 in the rear)
SPCs price looks good but I dont know if they are quality, they dont look as beefy as DME, Cusco, or AP.
Toyobaru808 is offline   Reply With Quote
Old 12-07-2012, 11:41 AM   #9
JoeBoxer
JoeBoxer's Avatar
Turn In Concepts is using the SPC's which was good enough for me, i haven't had any trouble out of mine.
The Following User Says Thank You to JoeBoxer For This Useful Post:
ATL BRZ (12-07-2012)
Old 12-07-2012, 11:43 AM   #10
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Same here; love my SPC's and their ease of adjustability.
The Following User Says Thank You to ATL BRZ For This Useful Post:
JoeBoxer (12-07-2012)
Old 12-07-2012, 02:07 PM   #11
schtebie
Drives: CBS BRZ Limited
I also have KWs and installed Cusco arms. I'm sitting at -1.2 in the rear.
schtebie is offline   Reply With Quote
Old 12-07-2012, 04:26 PM   #12
Toyobaru808
Can anyone chime in on dme, AP, or gtspec LCAs? What make AP so much more expensive?
Sent from my SGH-T989 using Tapatalk 2
Old 12-07-2012, 05:05 PM   #13
JoeBoxer
JoeBoxer's Avatar
I would most definitely get Whiteline over AP for roughly the same price. GC and Esoteric have some in the works too i believe. Out of the ones listed in your post i'd go GTSpec.
The Following 2 Users Say Thank You to JoeBoxer For This Useful Post:
AZP Installs (12-30-2012), Toyobaru808 (12-07-2012)
Old 12-07-2012, 05:32 PM   #14
Supermassive
Supermassive's Avatar
I have the AP and love them, with every single other arm you have to remove the bolt to the subframe to be able to adjust it. With the AP setup you can just hop under the car loosen the lock nuts and adjust the length of the LCA without removing the bolt. Some people will say that the threaded rod is a weak point, but after seeing the Cusco arms and GT Spec which are just stamped and welded steel vs. the machined block of aluminum with steel fittings that comprise the AP unit, the extra cost is worth it. The Whiteline looks amazing, but i don't think it's even out yet but it would have been my only other choice if it was available when i needed mine. Also AP is red and I like red!
Supermassive is offline   Reply With Quote
The Following User Says Thank You to Supermassive For This Useful Post:
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
Rear camber adjustment options? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 09-12-2012 10:46 AM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
