Old 11-30-2012, 02:20 PM   #15
Zadkiel
Drives: CBS BRZ Limited 6MT
Is there anyone who imports all the OEM stuff for this? I'd only want it if it would function like the OEM Foglight, only turning on when the foglight stalk switch is turned.
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 12-03-2012, 12:51 AM   #16
Timtamtt
Timtamtt's Avatar
Nice write up! now I gotta do this haha
Timtamtt is offline   Reply With Quote
Old 12-10-2012, 12:31 PM   #17
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Thanks for posting this up Chris. I decided to use a GM 3157 socket and white LED bulb. LEDs match up really well with the rest of the lights.
PhastekSport is offline   Reply With Quote
Old 12-12-2012, 02:10 AM   #18
nigel-jdmparts
nigel-jdmparts's Avatar
Drives: 86
FYI, if anyone want to save the hassle to drill the Scion housing.
We have the Toyota 86 Fog light housing available
Toyota 86 Fog Light housing
nigel-jdmparts is offline   Reply With Quote
Old 03-07-2013, 05:47 AM   #19
slidethis
Drives: Argento
How does that work?
Sent from my SGH-T999 using Tapatalk 2
slidethis is offline   Reply With Quote
The Following User Says Thank You to slidethis For This Useful Post:
zbt (03-07-2013)
Old 04-03-2013, 03:43 AM   #20
srt4_night_rider
Did this tonight with some custom LED's i built, turned out awesome! Wired mine up to only come on when the brakes are applied.
srt4_night_rider is offline   Reply With Quote
Old 04-03-2013, 11:53 AM   #21
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
for $200 I will go take my chances with the dremel and drill bits..
Huehuecoyotl is offline   Reply With Quote
The Following 3 Users Say Thank You to Huehuecoyotl For This Useful Post:
boredom.is.me (04-03-2013), Mikem53 (06-10-2013), russv (04-03-2013)
Old 04-03-2013, 02:33 PM   #22
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Cost me about $25. My bulb was $18. You have to do the same amount of work in the end if you get a rip off kit. Hell, I'ld make a kit and sell it for $50 shipped if anyone is interested.
Old 04-04-2013, 04:43 PM   #23
yohan04
yohan04's Avatar
Drives: Your sister
Is it possible to splice the wires to the front fog lights (BRZ limited)? So you have the option of turning it off/on?
yohan04 is offline   Reply With Quote
Old 05-28-2013, 07:23 PM   #24
taimysho0
Drives: frs
is it legal to use this as the 3rd brake light in CA? im planning to use the 3rd brake light delete DIY and use the triangle light as the 3rd brake light
taimysho0 is offline   Reply With Quote
Old 05-28-2013, 09:22 PM   #25
Gunman
Drives: 2019 Mazda Miata RF
No, it's not high enough. They call the 3rd brake light a "Center High Mount Stop Lamp" for a reason
S5.3.1.8 (a) Each high-mounted stop lamp installed in or on a vehicle subject to S5.1.1.27(a) shall be located as follows:
(1) With its center at any place on the vertical centerline of the vehicle, including the glazing, as the vehicle is viewed from the rear.
(2) If the lamp is mounted below the rear window, no portion of the lens shall be lower than 6 inches below the rear window on convertibles, or 3 inches on other passenger cars.
(3) If the lamp is mounted inside the vehicle, means shall be provided to minimize reflections from the light of the lamp upon the rear window glazing that might be visible to the driver when viewed directly, or indirectly in the rearview mirror.
Old 05-28-2013, 09:44 PM   #26
boredom.is.me
Custom User Title
look at the post above
I think you meant to quote someone else.
Old 05-28-2013, 10:40 PM   #27
Gunman
Yeah...sorry about that.
Old 05-28-2013, 11:56 PM   #28
taimysho0
Drives: frs
so from the sounds of it, it is illegal since it is more than 6 inche sbelow the rear window..
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 11:17 AM
Third brake light not working....what should i do before bringing it in? Hotlava86 Issues | Warranty | Recalls / TSB 11 03-10-2016 01:12 PM
Red triangle on rear, fog light? eriktherod Scion FR-S / Toyota 86 GT86 General Forum 50 12-22-2012 08:22 PM
rear triangle red light ncbluefr-s Cosmetic Modification (Interior/Exterior/Lighting) 2 07-15-2012 12:46 AM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 04:53 PM
