Old 09-08-2012, 12:02 AM   #1
Hotlava86
Hotlava86's Avatar
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
Third brake light not working....what should i do before bringing it in?
Well today i was informed by my friend that my third brake light was not functioning. Upon inspection....it's not. i inspected the wiring harness for the light and it is fine. and plugged in.
If i have to take it into the dealership what should i do?
I have a 12" sub and amp installed, an exhaust, an Intake and a crank pulley and an HKS oil filter. ( yes i know the performance parts have nothing to do with the brake light)
Should i remove anything before taking it in?
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/
Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152
Hotlava86 is offline   Reply With Quote
Old 09-08-2012, 12:06 AM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
The bulb is still good right...what about the fuse?
Old 09-08-2012, 12:09 AM   #3
Hotlava86
Hotlava86's Avatar
aren't there multiple bulbs in the third brake light? i thought there were 3-4 LED's in it? and i wouldn't think there would be a fuse just for the third brake light and not just tied in with the other brake lights. I would think the bulbs would be fine. However i have no idea how long they've been out...
Old 09-08-2012, 12:22 AM   #4
Lonewolf
Lonewolf's Avatar
Drives: Moped
I have no idea since I don't have an FRS yet, whenever my brake lights have gone out, it was always either a bulb or a fuse...easy stuff first
Old 09-08-2012, 09:21 AM   #5
gmookher
who installed the stereo and sub?
gmookher is offline   Reply With Quote
Old 09-09-2012, 12:05 AM   #6
Hotlava86
Hotlava86's Avatar
its not the sub...and it was done professionally. we did a continuity test on the light today. it isn't working at all. its getting power but its not functioning. SO WARRANTY TIME!
Old 09-09-2012, 10:39 PM   #7
White64Goat
If you used a test light to check for power at the connector or sockets, and you have power, then you have a bad ground. (Assuming all the bulbs are good).
Old 09-09-2012, 11:53 PM   #8
Hotlava86
Hotlava86's Avatar
we did a test from the battery with a continuity tested straight to the third brake lights connector. so gave it straight power and it didn't light at all. so the light assembly is bad...Toyota can't get it in until this coming friday...ugh
Old 09-10-2012, 08:39 AM   #9
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The third brake lights have been defective in a number of cars (if you haven't checked yours, do so.) The part can be replaced from inside the cabin. I don't know if they have to get to the plug in the trunk, but in case they do, make sure that's accessible.
Also, the part sometimes shows up as back-ordered in the Subaru parts system, just tell them to order it anyways. Mine was supposedly a couple months out, but it arrived in 2 weeks.
After you bring it in, keep a copy of the inspection in your glovebox so if you get pulled over you can show that you're getting it taken care of and are just waiting on parts.
The Following User Says Thank You to Draco-REX For This Useful Post:
HunterGreene (09-10-2012)
Old 09-11-2012, 09:12 PM   #10
TofuEater
Drives: White GTS 86
I just took mine in this morning for this problem. The metal bit holding the capacitor was loose and it got bent. 3 week back order for the whole led housing.
TofuEater is offline   Reply With Quote
Old 03-10-2016, 11:20 AM   #11
jochfr
jochfr's Avatar
Drives: 2015 BRZ Limited - Ice Silver
Just bought a 2015 BRZ and having the same issue... About to take it in.
jochfr is offline   Reply With Quote
Old 03-10-2016, 12:12 PM   #12
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
If anyone needs a spare, working, third brake light LMK. I took mine out a long time and it worked perfect lol.
Trying to sell off my stock parts so I don't have to move them.
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 10:17 AM
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 02:47 PM
Third brake light out? Longhorn248 BRZ First-Gen (2012+) — General Topics 21 11-23-2015 03:23 PM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 07:11 PM
The third brake light looks like a car! Longhorn248 BRZ First-Gen (2012+) — General Topics 12 06-06-2012 07:14 PM
