Old 12-08-2012, 09:46 PM   #169
BRZranger
As far as the holes above the rear struts in the trunk, I have driven through some hard rainstorms and I've not had any water intrusion or mildew in the trunk.
BRZranger is offline   Reply With Quote
Old 12-08-2012, 10:04 PM   #170
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Me too; I think the most important thing here is to make sure the rubber grommets are in place underneath.
It should be fine with just that.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 12-09-2012, 07:26 AM   #171
Sigma6
Originally Posted by civicdrivr View Post
You wouldnt happen to know the size of the grommets you used, do you?
I do not know what size they are. They are a tad small too small and don't fit completely snug.
All I know is that my rear window would completely fog up to the point of where I had to kick on the rear defrost multiple times. It has been bounds better since plugging the holes.
Sigma6 is offline   Reply With Quote
Old 12-09-2012, 09:17 AM   #172
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
In my opinion you get more water in the car with you shoes each time you get it and out in rainy weather and all that get absorbed in the mats and released in the cabin, it's more of a problem than 2 tiny holes. And the ventilation system does a great job at spreading that toward the rear.
Also If people are scared with rust in these areas, why cover it up? You want to make sure the humidity stay there and water can't evaporate? I'd just shoot a bit of rust prohibitor in there and call it a day.
Rayme is offline   Reply With Quote
Old 12-09-2012, 11:29 AM   #173
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I went to the Scion dealer and ordered them.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 12-09-2012, 02:51 PM   #174
Sigma6
Lol, ok.
I park in my garage. The rear window would fog up after pulling out and cruising a few miles. Shoes would be dry because they never touched a wet surface. *shrug* Seems to be fine now but since you know more about me and what I do on a day to day basis then... *shrug*
My car will never touch road salt so I am not worried about my car rusting. Just making an observation and covering the holes won't prevent rust.
Old 12-09-2012, 03:14 PM   #175
_F-R-S_
Drives: 13 whiteout scion frs
Becuz racecar
_F-R-S_ is offline   Reply With Quote
Old 12-16-2012, 12:50 PM   #176
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
This thread made me go out and check my under my car if they installed the grommets. They did. Not to mention its 1:48 am here. Haha! I know for a fact that the holes in the trunk have no plugs cause I installed coilovers already. I actually welcomed it thinking they might have thought of people installing coilovers.
Tye300 is offline   Reply With Quote
Old 01-08-2013, 09:16 PM   #177
convoy
convoy's Avatar
Drives: 2013 Subaru BRZ Limited(White)
My BRZ also did not have the plugs near the rear wheels(or in the glove box). I work in parts and have easy access so I ordered the Toyota part number in this post. Just got them in today and will put them in soon. Hopefully it will help with the odd smells I get in the the cabin. If not maybe I will try plugging the noise generator. I haven't checked my rear struts yet but probably will soon.
Not sure if you can see it in the picture but they are stamped Subaru and have what looks to be the Subie part number on them. 90371CA010
convoy is offline   Reply With Quote
The Following 2 Users Say Thank You to convoy For This Useful Post:
Lonewolf (01-08-2013), Marrk (01-08-2013)
Old 01-08-2013, 09:46 PM   #178
VROOOM
S5:F Gunmetal / Staggered
Drives: WHITEOUT 2013 SCION FRS
Just purchased a FR-S... popped the grommets in tonight!!! Another informative thread.
VROOOM is offline   Reply With Quote
Old 01-28-2013, 10:51 AM   #179
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Drives: AE86 Successor
Thanks went to dealership on the weekend to install the plugs in trunk!
SPEEDGOD is offline   Reply With Quote
Old 02-18-2013, 12:42 PM   #180
suaveflooder
Picked mine up last saturday. I didn't have them either over the strut or on the underside. Dealership found a set in a salesman's desk. Oops. Gonna go put them in. Dealer ordered me the top ones for the struts
suaveflooder is offline   Reply With Quote
The Following User Says Thank You to suaveflooder For This Useful Post:
Marrk (02-18-2013)
Old 02-19-2013, 08:16 AM   #181
akyp
Drives: 2012 86
Originally Posted by Laika View Post
Make sure you don't break any of these little buggers while you're doing this.
Excuse me for being a noob, but how do you put things back together? I'm trying to push these little things back in place, and all I'm getting are sore fingers.
What should I do? Tap with a hammer/screwdriver?
Edit: Nevermind, figured it out. And after that it was a 30-second job. *Hangs head in shame* I do wonder why a flathead screwdriver isn't included for this exact purpose, while there is a philips-head one in the trunk.
And my car doesn't have the round seals on the rear strut towers (only checked the left side, but there's no reason why the right side should be different), but does have the oval grommets on the underside (both sides).
akyp is offline   Reply With Quote
Old 02-19-2013, 12:41 PM   #182
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
That Phillips head is also a flat head on the other side
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
akyp (02-19-2013)
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 02:56 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 02:57 AM
Impressive boot space! BD AUSTRALIA 14 08-24-2012 04:30 AM
Fatal FRS Flaw!! Skin Scion FR-S / Toyota 86 GT86 General Forum 4 07-12-2012 04:21 PM
Pics of rear passenger area with plastic removed JRitt Cosmetic Modification (Interior/Exterior/Lighting) 20 06-12-2012 08:17 AM
