Old 12-08-2012, 12:28 AM   #505
RZ86
RZ86's Avatar
Drives: 2012 Toyota GT 86 Manual
offset usually helps lol
Current: '12 Toyota GT 86 Pearl White Manual
Previous: '96 Toyota Supra SZ-R
RZ86 is offline   Reply With Quote
The Following User Says Thank You to RZ86 For This Useful Post:
20valvewynn83 (12-10-2012)
Old 12-08-2012, 01:46 AM   #506
ayau
Drives: Some rust bucket
Entirely false. There are plenty of 18" wheels that weigh less than the stockers. Most added weight when doing a tire/wheel swap is from the tire carcass itself.
i was talking about aftermarket 17'' vs aftermarket 18'', not stock 17'' vs aftermarket 18''. for example, rpf1 17'' vs rpf1 18'', i see no reason to get the 18'' unless you have a big brake kit.
Old 12-08-2012, 01:48 AM   #507
Mathewgzlz
Mathewgzlz's Avatar
Drives: 2013 SCION FR-S FIRESTORM RED
40offset
Mathewgzlz is offline   Reply With Quote
Old 12-08-2012, 02:09 AM   #508
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
http://www.ft86club.com/forums/showthread.php?t=11885
Search function works wonders. Also look in the fitment sticky at the top of the board next time.
And I hope those aren't the wheels you're looking at... Because what you posted is 4 lug.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following User Says Thank You to deucethemoose For This Useful Post:
stout90 (12-08-2012)
Old 12-08-2012, 06:43 PM   #509
Jeffboyarrdee
Jeffboyarrdee's Avatar
Drives: 2013 Subaru brz limited wr blue
Do you guys agree with going aftermarket 17 rather than 18? (Ie 17x8 vs 18x8) for performance? But for looks as well I like the fit of an 18 and nothing larger.
Jeffboyarrdee is offline   Reply With Quote
Old 12-08-2012, 07:07 PM   #510
Foobar
SLO NO MO
Foobar's Avatar
You can get lightweight 18's, so no I don't agree that 17's are the definitive must-have size for performance. For saving money? Definitely 17's. For staying in a particular stock class? Yes.
Old 12-08-2012, 07:08 PM   #511
ayau
aesthetically, i think 18 looks too big on those tiny brake rotors. you can always upgrade to a big brake kit, but that's an entirely different story.
Old 12-09-2012, 12:57 AM   #512
Mathewgzlz
Mathewgzlz's Avatar
No not these exact ones but Thts the style the ones I'm looking at are 5x100 18x9.5 with +30 offset in rear and 8.5 fronts
Old 12-09-2012, 01:16 AM   #513
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
that should fit ok, depending on what the front offset is and the tire.
but the rim size alone is safe
dori. is offline   Reply With Quote
Old 12-09-2012, 12:55 PM   #514
Jeffboyarrdee
I will upgrade the brakes and suspension if I swap to larger wheels. But if I stuck to 17" I could just keep my brakes and suspension...to support a wheel assumingly similar Specs and possibly lighter weight. Hmmm I'll have to decide what I'd want to spend my money on. Once I buy those wheels...I buy those tires...haha.
Old 12-09-2012, 04:55 PM   #515
jeebus
I bet you could stretch them onto a 17x10 MAX. It would look retarded. 17x9 would look pretty dumb too. 17x8 would fit fine.
jeebus is offline   Reply With Quote
Old 12-09-2012, 07:25 PM   #516
Foobar
SLO NO MO
Foobar's Avatar
Whtefrs has a post in the member classified wheel section that shows his 17x9 Rotas for sale with stock tires on them.
If you're into stretch, I guess its acceptable, but I personally wouldn't do it. The stock Primacy's are pretty narrow to begin with.
Here's the pic:
Old 12-10-2012, 12:11 AM   #517
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
17" +45 v +35
Ok, so im read so many thread that i got a headache after weeks - let me ask this a different way. I dont want to hear about how much more flush 35 is then 45 - i get that. i also get the pretty factor of how it looks better.
if i go with 17x7.5 and were to go with the 35 offset - what is the pro-con in the handling dept ? I love the stock handling - which is why i wont go to 18x8.. i heard too heavy and different handling characteristics.
btw, im not a track guy but i love to drive agressively and want to keep the stock feel with better tires.
so , that being said - if i were to get new 17x7.5 @ 225/45-17 -- what do i do ? recommendations ? 35 or 45/48 ? will the 35 do anything bad ? ive heard everything from putting extra strain on the wheel bearings to changing the handling characteristiccccs. ugh too much info
rikdrt1 is offline   Reply With Quote
Old 12-10-2012, 12:26 AM   #518
dori.
Señor Member
dori.'s Avatar
basically the +35 is going to give you a wider track
engineers/scientists please correct me if I'm wrong but:
all else equal you'll get more cornering power but slightly more steering effort
track will be increased by 20mm compared to the +45, which is only like 3/4 of an inch?
honestly it doesn't sound like a huge change and it will look way better on +35.
but if you like the stock handling then why are you changing the wheel/tire combo to begin with?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
