Old 12-06-2012, 04:36 PM   #15
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
If you like the way the car handles with 0 camber, trust me you'll like it MORE with a little negative. It went from taking corners well to getting sucked into corners like it's being pulled. The difference is insane, it's been a couple of weeks and it still makes me grin.
Personally, I'm not a fan of the lip sticking that far out either. I'm also not a fan of wheels that are wider than necessary for the tire. My wheels are 9" wide, but +28mm offset and they stick out too much for my tastes. Yours stick out 3.65mm farther than mine, with 0 camber. I changed to a lower eccentric bolt and now it looks much better, but still not how I want it (I never planned for these wheels to be permanent anyway).
You'll notice a lot of people are going staggered: 8.5" front and 9.5" rear. The few I've seen with 9.5" in front are often lower offset than this and are using camber bolts or something to that effect. TIC has 9.5 +30 with 255s all around and somehow it looks great. They do have camber bolts/plates, though.
I believe this car has a wider front track also. So that combined with a narrower fender means that "square" wheel setups aren't going to look the same front/back. If you swapped to 8.5s all around, the front would be perfect and you'd need spacers in back to get that same flushness.
Please rotate pics before uploading. That's just good form.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 12-06-2012, 04:41 PM   #16
2point0
2point0's Avatar
Originally Posted by maj75 View Post
You mean mis-aligned?
I'm thinking that the 18x8 +45 should be flush, like the rear, without having to mess up the alignment with a lot of camber.
I recently bought my exhaust from a guy with these wheels in 17x8 +45 (wrapped in 245 RS-3s) and they are still pretty well tucked into the fender. Not nearly so much as stock, but it's certainly not flush with the edge, if that's the look you're going for. I don't know what all the size are for RPF1s, but I think 8.5" might be more what you're looking for.
Old 12-06-2012, 04:44 PM   #17
empower-auto
Kouki-Monster
empower-auto's Avatar
IIRC the issue with this car is not too much "safety under-steer". It is the opposite, the tail can come out at almost any speed. I do have more camber in the rear, because it can't be adjusted out after the spring install. Hopefully the rear camber will make the car neutral.
I've already order the 18x8 wheels. I will post up the difference when I get one of them mounted, for a side to side comparison!
You must be kidding. I've never had the rear come out unless I forced it.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following 2 Users Say Thank You to empower-auto For This Useful Post:
raz0rbladez909 (12-07-2012), SkAsphalt (12-11-2012)
Old 12-06-2012, 04:52 PM   #18
jkonquer
Drives: 2005 Subaru STI
i think 9" are perfect for front. without going too much camber.
jkonquer is offline   Reply With Quote
Old 12-06-2012, 05:10 PM   #19
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
the pictures were correct on my phone, iphone must have autocorrected??
Old 12-06-2012, 05:13 PM   #20
Nardi330
Nardi330's Avatar
Drives: 86
I'm on the opposite. My 9.5+38 rear sticks out a little like your front. I don't understand why I seem to be the only one..... (Lowered on kw v3 with cusco lower arm)
I'm running 8.5+38 at the front and its flush with -0.75 camber.
Nardi330 is offline   Reply With Quote
Old 12-06-2012, 05:56 PM   #21
dale.m
Captain Slow
dale.m's Avatar
Drives: 2013 Firestorm FR-S
You must be in Australia! All your pictures are upside down!
Flying and Driving.
dale.m is offline   Reply With Quote
The Following User Says Thank You to dale.m For This Useful Post:
R2RO (12-06-2012)
Old 12-06-2012, 06:49 PM   #22
maj75
Drives: Blue FRS 6sp, 95 M3
Sorry, I did this on my I Pad and it looks right to me. Looks right on my phone too.
Don't know how to fix this...
maj75 is offline   Reply With Quote
Old 12-06-2012, 07:17 PM   #23
wparsons
wparsons's Avatar
Originally Posted by empower-auto View Post
1 degree of camber will get you 9mm of clearance.
You have .. nearly positive camber?
By my rough math you'll only get ~7mm from 1* of camber, but even if you do get 9mm from a single degree you would need over 3.5* to get enough clearance for 1.25" (~32mm).
flickr
Old 12-06-2012, 10:47 PM   #24
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
The problem is at the front:
Any rubbing problems with this setup?
shu5892001 is offline   Reply With Quote
Old 12-06-2012, 11:20 PM   #25
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
roll/pull the fender!
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 12-06-2012, 11:22 PM   #26
stanm
stanm's Avatar
Drives: 2013 Asphalt FR-S 6MT
Looks perfect IMO but to each their own!
stanm is offline   Reply With Quote
Old 12-06-2012, 11:25 PM   #27
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I do
Anybody want 2 18x9.5 gold Enkei wheels
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 12-06-2012, 11:31 PM   #28
JoeBoxer
JoeBoxer's Avatar
Originally Posted by ngabdala View Post
I do
Yes you do get a pair of 17x9's for the front and be the guinea pig.
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
5x100 18x9.5 +40 Enkei NT03+M SBC anyone know were i can get a set of these ? FRS-HHH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-28-2012 02:15 AM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
17x9 +35 front .... 18x9.5 +38 rear kinryu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-30-2012 02:19 AM
