Old 12-06-2012, 01:36 PM   #15
jm1681
Drives: MKVI VW GTI
Originally Posted by flatline View Post
He has a point. If you remove that little amp, those speakers and all the wire become completely dead weight. That's easily another 3-5 lbs.
And if he stopped there, I would have acknowledged that.
Originally Posted by Brody602 View Post
Removing your amp, will END all audio capabilities of your car, the HU will power up, but thats it, you won't have any sound output whatsoever if you remove the amp.
The stock head unit will work, just not the speakers in the doors.
Sooooo.... who is right?
If I'm going to lose my door speakers, but still have those mounted on the dash and rear, I don't particularly care. If I'm going to lose everything, then yeah, won't happen.
Just to clarify for everyone, yes, I DO realize that by suggesting something like this, I am indeed grasping at straws. I'm not looking for some secret change-the-world weight savings by doing this. I'm just trying to do what I can, when I can to make it lighter. Weight doesn't come off in big junks when you're on a tight budget. You've got to take what you can get, or more precisely, lose what you won't miss in the first place.
jm1681 is offline   Reply With Quote
Old 12-06-2012, 01:41 PM   #16
be6sti
be6sti's Avatar
Drives: 2013 scion frs
If you remove the amp your radio will have no way of sending power to the speakers in the car. The hu sends signal to the amp then the amp sends signal to all speakers no amp no signal no sound easy peasy
"Fuck it lets go!"
be6sti is offline   Reply With Quote
The Following User Says Thank You to be6sti For This Useful Post:
TouchMyHonda (12-06-2012)
Old 12-06-2012, 01:47 PM   #17
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
I drove my completely stripped minus the dash. Cagged, radio and speaker less, one fiberglass bucket civic for a daily. If you think you can tolerate it do it. I just rock headphones and pandora.
TouchMyHonda is offline   Reply With Quote
Old 12-06-2012, 01:52 PM   #18
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
I guess the thick sarcasm in my post wasn't obvious to all.
I'm not sure what the audio setup is in the frs, if the amp powers ALL the speakers or just the components idk. Assuming it powers them all- if a 0.1% weight savings is worth more to you then music, bluetooth, etc- then it's really not that unreasonable to think that you value weight savings > comfort and amenities. If the car no longer has any functional speakers removing the head unit, and all the related wiring would probably get you another 0.1% weight savings. You could then definitely run a much smaller battery- which would be far more significant of a weight reduction.
Ravenlokk is offline   Reply With Quote
Old 12-06-2012, 02:03 PM   #19
JayNutter
If you want to know who is right then just disconnect the wires to the amp and see what happens. It is unlikely it is only powering a couple speakers, but is plausible.
JayNutter is offline   Reply With Quote
Old 12-06-2012, 05:25 PM   #20
jm1681
Drives: MKVI VW GTI
The only reason I ask in the first place is I'd SWEAR I read that the stock head IS powered, and that the amp was just MORE power, or something along those lines.
Old 12-06-2012, 06:34 PM   #21
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
Yeah but power routes THROUGH the amp to the speakers. Cut out the middle man and you've got no way to connect the two other than to splice them together.
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline   Reply With Quote
Old 12-06-2012, 07:07 PM   #22
rbizzle004
Don't know if the speakers in the FRS are same as in the BRZ. But in the BRZ the amp only powers the 8" subs in the door. The HU powers the rest.
rbizzle004 is offline   Reply With Quote
Old 12-06-2012, 08:11 PM   #23
jm1681
Drives: MKVI VW GTI
I'm fine with a little splice
And if that IS the case, I'm good.
Old 12-06-2012, 10:36 PM   #24
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
Same thing for the frs. Quite the surprised when i found out.
rhood168 is offline   Reply With Quote
Old 12-11-2012, 05:06 PM   #25
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
This has been an informative thread actually, I had no idea there was an amp in the back of the FRS. Does this mean I can just plug a trunk sub into that and not have to run cables up to the head unit? Or can that amp be easily swapped out for another amp with additional ports if it's already maxed out? Pardon the lack of audio experience. I'm considering just adding a sub to add a little extra oomph but I'm not unhappy with the rest of the stock audio gear and I have a light budget.
oldpueblo is offline   Reply With Quote
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno xwd Tracking / Autocross / HPDE / Drifting 16 08-07-2014 10:04 PM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 04:14 PM
WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses Sony Engine, Exhaust, Bolt-Ons 0 11-21-2012 12:10 AM
FS: Ecutek Cable, stock axleback exhaust, stock springs Philly Canada Classifieds 4 11-02-2012 09:50 PM
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels eckoflyte AUSTRALIA 11 06-18-2012 09:17 AM
