Old 12-05-2012, 02:35 PM   #43
OrbitalEllipses
Drives: Attitude
Swapping the calipers side to side was if you wanted to keep the bleeders in their original location and then the pistons are in the wrong orientation. If you swap the bleeders then you keep the calipers on the same side as the STI, then you are good to go with the pistons in the proper orientation. If you look at a picture of an STI and my car you will notice they are oriented the correct way.
-_- I should leave this thread. Go back a few months and I'm saying exactly what you're saying but this week I've gotten everything wrong. I blame work.
Old 12-05-2012, 03:05 PM   #44
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I blame work.
I was going to call it lack of sleep. The two are not mutually exclusive...
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
Wankel Rex (01-01-2013)
Old 12-05-2012, 04:14 PM   #45
ADebelius
Taking Corners
Drives: 2014 FR-S Whiteout Monogram
Man I must have been tired. I get it. Basically you just rotated it around the rotor so the leading edge still hits the same piston first and swap the bleeder to the top. Doh....
What about the brake bias though? From what I read it seems our rears are actually stronger than the brembo's?
ADebelius is offline   Reply With Quote
Old 12-05-2012, 09:20 PM   #46
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Brake bias is just a pad change away. The STI rear calipers still have clear heat and pad swap advantages.
Old 12-05-2012, 09:43 PM   #47
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Good jerb
TouchMyHonda is offline   Reply With Quote
Old 12-05-2012, 10:40 PM   #48
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
nice work
Jesse is offline   Reply With Quote
Old 12-07-2012, 04:08 PM   #49
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
I managed to track down a set of these callipers on Yahoo auctions Japan probably going to cost about $1400US landed tho
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 12-10-2012, 12:39 PM   #50
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Are the stock rotors not compatible due to size? Thx
GTB/ZR-1 is offline   Reply With Quote
Old 12-11-2012, 06:48 PM   #51
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yep. The STI rotors are both thicker and larger diameter than the BRZ ones.
GTB/ZR-1 (12-11-2012)
Old 12-13-2012, 11:56 AM   #52
Jamifra
Jamifra's Avatar
Drives: 2013 Civic Si
so basically in order to isntall the calipers you have to buy thicker/larger rotors?
i have a set of 04-07 sti brembo at home.. does the larger rotors apply to this brembos too?
Driving Style: Highly Spiritual, Sometimes Aggressive, Never Abusive
Jamifra is offline   Reply With Quote
Old 12-13-2012, 12:10 PM   #53
Jamifra
Jamifra's Avatar
what brake lines are you using?
for example stoptech steel braided lines for frs/brz work with the brembos?
Old 12-13-2012, 04:14 PM   #54
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I used a set of Goodridge SS brake lines meant for the BRZ, so I am sure you can get the Stoptechs to work as well. The 04 sti rotors will work in the front because they are drilled for 5x100, but not in the rear is my understanding.
Old 12-13-2012, 07:39 PM   #55
Jamifra
Jamifra's Avatar
great!
i already have sti brembos from a 2006 sti, just need to get the 2004 rotors and the SS brake lines
Old 12-13-2012, 07:48 PM   #56
OrbitalEllipses
Drives: Attitude
That is correct. The 08+ rear hat design is completely different; in addition, the WRX went to the STI parking brake diameter (190mm) in this generation so using re-drilled STI rear rotors shouldn't be an issue.
Originally Posted by Jamifra View Post
great!
I have a set of 2004 STI rotors I'd love to sell you. Centric Premium blanks.
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 12:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 05:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 10:08 AM
