Old 12-07-2011, 09:57 PM   #15
arghx7
Drives: car
Most of those automated manual transmission attempt to emulate a torque converter equipped transmission in the way it feels coming off a stoplight. I think subjectively speaking a lot of people prefer the takeoff of a "regular" auto. Ford's dual clutch transmission they have recently introduced has been criticized for not being enough like a slushbox. Now I'm talking about opinions from the majority of the automotive press and "regular" car buyers.
Old 12-17-2011, 07:16 AM   #16
CXTKRS1
Drives: 2009 Scion xD
Originally Posted by serialk11r View Post
for the better I think? I heard that automatic using clutches only aren't very smooth from stop.
The Veloster and Fiesta are actually quite when taking off from a dig.
CXTKRS1 is offline   Reply With Quote
Old 12-17-2011, 08:27 AM   #17
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by CXTKRS1 View Post
So if you throw both the FRS auto and manual on a dyno the RWHP numbers will be pretty the same?
Originally Posted by Snaps View Post
Who cares? This car isn't about dyno numbers...
But to answer your question, yes, pretty much.
:happy0180:
I love this!!!
SUB-FT86 is offline   Reply With Quote
Old 12-17-2011, 10:42 PM   #18
CXTKRS1
I rather not give up what little torque this car has to parasitic loss.
Old 12-19-2011, 01:15 AM   #19
Snaps
Supra Owner
Snaps's Avatar
Drives: 1995 Toyota Supra UK Spec
^ Parasitic Loss of which there would be almost no discernable difference between a Manual and an Auto with a locked Torque Convertor
Snaps is offline   Reply With Quote
Old 12-04-2012, 11:56 PM   #20
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
So is it safe to say that the AT should perform very similarly to the MT from gears 2 thru 6? I understand the gearing is slightly different between the AT and MT too, but if we were to assume the two had the exact same gearing, and you were both in 2nd going the same speed (say 15 mph), should the two cars both get to 100 mph at virtually the same time, assuming same redline shift-points, and assuming the MT driver is 40 lbs heavier than the AT driver to make up the difference in weight between the two cards. (?)
mit_peid is offline   Reply With Quote
Old 12-05-2012, 08:08 AM   #21
wlfpck
Drives: 2015 GTI
Originally Posted by ryude View Post
Both automatics use a clutch, the only difference is one uses 2 clutches and one uses a clutch with a torque converter. Once the torque converter is locked, it's basically a manual transmission.
The one with 2 clutches is a Dual Clutch Transmission (DCT)
The DCT is found in the VW GTI (DSG), Mitsubishi EVO X and Ralliart, Porsche, etc.
2013 GTI - Gone
2015 GTI
wlfpck is offline   Reply With Quote
Old 12-05-2012, 08:11 AM   #22
wlfpck
Drives: 2015 GTI
Assumming that the gearing is identical and the weight is equivalent, then for the most part yes. The performance would be the same as the torque converter locks up to provide a direct coupling (mechanical) as opposed to a fluid coupling.
2013 GTI - Gone
2015 GTI
Old 12-05-2012, 08:16 AM   #23
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Auto Dynos lower power than the MT because of parasatic losses.
Old 12-05-2012, 08:24 AM   #24
wlfpck
Drives: 2015 GTI
I thought someone dynoed the 86 and found that the performance was pretty much the same?
Or I am hallucinating. Maybe I'm thinking of something else.
2013 GTI - Gone
2015 GTI
Old 12-05-2012, 08:35 AM   #25
Sportsguy83
Drives: Limited BRZ
There are several Dynos posted in this forum from AT members showing less power on stock cars when compared to stock MT cars. Heck, the ECUTek tunes gain less HO and less TQ on Auto's than on MT.
Old 12-05-2012, 08:37 AM   #26
wlfpck
Drives: 2015 GTI
Hm... I wonder what car forum I was on yesterday after work. May have been something with a DCT... oh well.
2013 GTI - Gone
2015 GTI
Old 12-05-2012, 08:47 AM   #27
Sportsguy83
Drives: Limited BRZ
Here is one example.
It's not a huge difference, but it is noticeable in the top end.
http://www.ft86club.com/forums/showp...25&postcount=1
Old 12-05-2012, 08:56 AM   #28
zooki
Drives: waiting on a 2021...
The automatic will still have lower numbers because the auto transmission still
uses a hydraulic pump to operate, and it will cost some HP to drive, even with the converter locked up.
zooki is offline   Reply With Quote
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? Kostamojen Engine, Exhaust, Transmission 90 03-20-2022 06:05 PM
FT-86, manual or automatic transmission??? luisjr Scion FR-S / Toyota 86 GT86 General Forum 22 07-25-2012 03:00 AM
Another reason to buy a manual transmission car... xantonin Off-Topic Lounge [WARNING: NO POLITICS] 4 08-10-2011 11:30 AM
Automated Garage... Axel Other Vehicles & General Automotive Discussions 6 01-11-2010 05:58 PM
