Old 12-05-2011, 03:41 PM   #1
ahausheer
Re-member
Drives: Toyota camry
Early locking transmission vs. Automated manual.
Can anyone provide insight into the tactile differences between an early locking torque converter and an automated manual. Is the Toyobaru auto going to essentially be a auto-manual with a single clutch?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 12-05-2011, 03:59 PM   #2
madfast
Drives: 2010 Evo X MR-T
When the TC locks up, the engine and transmission is directly, mechanically connected. so it should feel like an auto-manual, but obviously they both work in different ways.
madfast is offline   Reply With Quote
Old 12-05-2011, 04:21 PM   #3
ryude
Drives: Volkswagen GTI
Both automatics use a clutch, the only difference is one uses 2 clutches and one uses a clutch with a torque converter. Once the torque converter is locked, it's basically a manual transmission.
ryude is offline   Reply With Quote
Old 12-05-2011, 05:50 PM   #4
madfast
technically incorrect.
Auto-manuals use the conventional manual transmission gearset with an electro-hydraulically controlled clutch. dual clutches obviously use 2 gearsets and 2 clutches.
torque converter automatics use a torque converter, lock up clutch, and planetary gearsets. each planetary gearset has its own clutches/brakes to make up the different ratios
the in between transmission is AMG's MCT which uses planetary gearsets but replaces the TC and lockup clutch with a wet multiplate clutch
Old 12-05-2011, 07:04 PM   #5
ahausheer
Re-member
I don't care too much how they work but I appreciate your knowledge. My main question is how long will the clutch remain locked (within each gears range, I know it must unlock to change gears). Is it locked during cruising and hard acceleration or will it de-couple as soon as you accelerate hard.
Old 12-05-2011, 07:17 PM   #6
serialk11r
Drives: '06 AM V8V Coupe
What manufacturers are shifting towards is a lockup clutch that is more or less always engaged past 1st gear. See Mazda Skyactiv transmission, or Lexus ISF.
Old 12-05-2011, 07:24 PM   #7
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
This is correct.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 12-06-2011, 02:47 AM   #8
CXTKRS1
Drives: 2009 Scion xD
So if you throw both the FRS auto and manual on a dyno the RWHP numbers will be pretty the same?
CXTKRS1 is offline   Reply With Quote
Old 12-06-2011, 04:33 AM   #9
Snaps
Supra Owner
Snaps's Avatar
Drives: 1995 Toyota Supra UK Spec
Who cares? This car isn't about dyno numbers...
But to answer your question, yes, pretty much.
Snaps is offline   Reply With Quote
Old 12-06-2011, 12:00 PM   #10
ahausheer
Re-member
So what is the advantage of a manual over the locking auto? Stronger left foot?
Old 12-06-2011, 12:12 PM   #11
madfast
More fun. that's just about it.
and notice i said more fun. plenty of people can enjoy themselves in a well sorted AT. i'll never say an AT is more fun than a MT, but a good AT is fun enough, and that's good enough for me.
Old 12-07-2011, 06:31 PM   #12
arghx7
Drives: car
A transmission with a torque converter is going to feel a little bit different coming off a traffic light compared to a single or dual clutch automated manual.
arghx7 is offline   Reply With Quote
Old 12-07-2011, 06:41 PM   #13
Snaps
Supra Owner
Snaps's Avatar
But when it matters - when you're actually moving - it should feel very similar, as long as the TC locks up after first (as I would guess this gearbox does).
Old 12-07-2011, 09:19 PM   #14
serialk11r
for the better I think? I heard that automatic using clutches only aren't very smooth from stop.
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? Kostamojen Engine, Exhaust, Transmission 90 03-20-2022 06:05 PM
FT-86, manual or automatic transmission??? luisjr Scion FR-S / Toyota 86 GT86 General Forum 22 07-25-2012 03:00 AM
Another reason to buy a manual transmission car... xantonin Off-Topic Lounge [WARNING: NO POLITICS] 4 08-10-2011 11:30 AM
Automated Garage... Axel Other Vehicles & General Automotive Discussions 6 01-11-2010 05:58 PM
