Old 12-04-2012, 03:01 PM   #43
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I shouldn't have mentioned it but did want to compare that i have had both tunes.
Old 12-04-2012, 03:03 PM   #44
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by JoeBoxer View Post
Yes, map 4 is set up for E85 and maps 1-3 are pump gas. I turn the key to the on position, change to map 4 then start the car. It has been really warm here but i haven't had any troubles. When it gets colder i will stick to 93 octane because it's still way more fun than stock.
By the way, is this a recent development? I thought I saw a post from FA20club a couple of weeks ago saying he can't have different base maps across the different maps - it was basically just features that he could turn on and off for the same base map. If you have Pumpgas on 1-3 and E85 on 4, that's definitely worth getting.
Old 12-04-2012, 03:05 PM   #45
Foobar
SLO NO MO
Foobar's Avatar
PM please i was hoping this wouldn't go there.
I hear ya - deleted.
I think it's bound to happen in any ECUTek thread though, as the real differentiation between these choices comes down to response time now.
The Following User Says Thank You to Foobar For This Useful Post:
JoeBoxer (12-04-2012)
Old 12-04-2012, 03:06 PM   #46
JoeBoxer
JoeBoxer's Avatar
I'm not sure how recent it is but yes it is definitely worth it, i have no need to flash anymore unless datalogging and getting an updated file everything is there on maps 1-4 that i need.
The Following User Says Thank You to JoeBoxer For This Useful Post:
Foobar (12-04-2012)
Old 12-04-2012, 03:12 PM   #47
Foobar
SLO NO MO
Foobar's Avatar
Awesome, looks like I'm spending a few more bills today
By the way, here's the post from 18-Nov I was referring to:
Originally Posted by FA20Club.com View Post
The way map switching is setup right now is based on features not complete different maps. Such as i can add launch control and auto blip to a map, then add flat foot shift to another. The way how E85 is tuned right now we use supplementary maps that cant be changed. SO basically that map stays the same for all 4 settings so switching fuel wont work. ECUTEK current has a 55gal drum of E85 so they are working on the flex fuel function as well as a fuel based map switching function. Until then you can use your laptop. Also mixing fuel wont give you max octane and power out put i dont see why you would want to. I can drive 38 miles once my light comes on for the fuel. So im sure is you wanted to switch fuel you could get toa station in under 38 miles. You do also realize E85 is consumed quite fast so if you fill up twice a week on pump you'll be filling up x3 weekly. Your other option is to just change the fuel and switch maps later when you get to your laptop. The car drives just fine. You just cant go WOT. The ecu does a decent job of maintain economy without the map switched over using fuel trims.
Old 12-04-2012, 03:13 PM   #48
2forme
I'm so confused, I got quoted, but then it was deleted.... PM me?
Old 12-04-2012, 03:17 PM   #49
JoeBoxer
JoeBoxer's Avatar
Trying to keep wait times for Visconti discussed in his thread or pm, not here.
The Following 3 Users Say Thank You to JoeBoxer For This Useful Post:
2forme (12-04-2012), Sportsguy83 (12-04-2012), Yruyur (12-04-2012)
Old 12-04-2012, 03:28 PM   #50
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
you guy's should also do some virtual dyno with your logs, it's free and pretty accurate. http://www.bradbarnhill.com/projects/VirtualDyno/
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
The Following User Says Thank You to WatchmaN For This Useful Post:
Old 12-04-2012, 10:48 PM   #51
Yruyur
Yruyur's Avatar
Fuel gauge is definitely wonky. Thought I was running on fumes trying to get to an e85 station. Got stuck as a train was crossing 100 feet from the station. Waited 5 minutes thinking it was going to die. Looked down and I had half a tank. Topping off confirmed it.
Sent from my flux capacitor using Taptalk
Old 12-04-2012, 10:53 PM   #52
Vicious LED
Drives: Scion FR-S Asphalt
I've been extremely curious/interested in an E85 tune for two reasons:
1- Economically more feasible. It's 3.29 a gallon right next to my house versus the 3.70 for 91.
2. The big gains everyone has been talking about. I feel like that's exactly what the 86 really needs.
My only concern is, with this being so new, does anyone have any sort of idea if this, over time, will corrode fuel lines/the engine itself? Everyone I've asked has had mixed feelings on it since there's really been no long term testing on an 86 since they're so new. If I did decide to get this tune, should I take precaution and upgrade to better fuel lines? Any thoughts/ideas? It'd be greatly appreciated...it's the only thing holding me back from the E85 tune!!
Vicious LED is offline   Reply With Quote
Old 12-04-2012, 11:00 PM   #53
Yruyur
Yruyur's Avatar
Price wise yes it is lower however you use more of it. So you only get about 80 of the miles. That said the power makes up for it I think. I read a while ago someone calculated they would be paying 400 more a year.
I also read that a complete fuel system break down was done after a bunch of tests and things looked ok. Of course this is short term.
I would search around and see what else is being said.
Old 12-04-2012, 11:02 PM   #54
Vicious LED
What sort of mileage are we talking compared to 91? On an average, under 4k RPM shifting pattern? (No stop light launching, etc.)
Old 12-04-2012, 11:07 PM   #55
JoeBoxer
JoeBoxer's Avatar
I don't plan on running it all the time, I will probably run pump gas to e85 4 tanks to 1 so I don't see any ill effects in the future.
Old 12-04-2012, 11:09 PM   #56
Vicious LED
Is it a simple push of a button to switch from e85 to 91?
APEX-i SMART Throttle Controller - preliminary test. Moto-P Engine, Exhaust, Transmission 33 05-24-2015 07:01 PM
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley draggin_az Engine, Exhaust, Transmission 21 04-29-2013 04:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
FA20CLUB.com E85 Goodness FA20Club.com Engine, Exhaust, Transmission 45 11-13-2012 01:05 PM
Tunehouse BRZ Tuning program preliminary details Hachiroku Engine, Exhaust, Transmission 42 06-25-2012 07:40 PM
