Old 05-17-2012, 10:47 AM   #15
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I believe it's the DEKA ETX16 battery. Specs:
325 CCA
17 lbs
Size: 6 7/8(L) X 4(W) X 6 1/8(H)
Not great for runing an audio system by itself, but should be sufficient for starting the car.
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
ESBjiujitsu (05-17-2012)
Old 05-17-2012, 10:48 AM   #16
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
On a different note, does anybody know the amp rating of the stock alternator?
Old 05-17-2012, 06:41 PM   #17
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
I am going to say 100 for now... I will check it on the catalog in a bit...
and yes...Not a big audio guy..so no biggie there...weight savings for Autocross..yess please.....and IS sufficient to just start the car..
Bill
Scooby South is offline   Reply With Quote
Old 05-17-2012, 07:26 PM   #18
2pt5RS
Berz
Bill
Hey Bill...this car has an amp to go along with that stereo. It's not like your speedwagon. You may need a slightly bigger battery.
2pt5RS is offline   Reply With Quote
Old 05-17-2012, 07:38 PM   #19
Scooby South
Conedancer
Matt...that is SOOOOO true..
The plan is... to swap it out with the factory one..only when I race... so the stereo is a low priority....then swap it back for Daily/normal driving..
Bill
Old 08-22-2012, 02:54 AM   #20
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I finally settled for one of these:
http://www.braillebattery.com.au/ind...tteries/b14115
Just under $350(AUD) including tie-down, battery tender and freight.
stevo_12v is offline   Reply With Quote
Old 08-22-2012, 08:35 AM   #21
miodculae
FRS Adept
miodculae's Avatar
Drives: Firestorm FRS
nice. weight only 11.5 lbs.
wonder how it will perform compare to stock. please report back.
how much of a weight savings ?
miodculae is offline   Reply With Quote
Old 08-22-2012, 09:36 AM   #22
stevo_12v
Having a quick google at the code of "55D23L". The weights vary from high 14kg to mid 15kgs. ie: http://www.centurybatteries.com.au/s...asa_55d23l.pdf
So I believe at least a 9kg(20lbs) weight saving is to be had. Almost the equivalent of taking out your spare tyre out of the boot.
Old 08-29-2012, 03:17 PM   #23
stevo_12v
Update: Just installed the braille 20mins ago. Car starts fine. Haven't left it on a 'tender' yet. See how it fares in the morning.
Yes I know the install looks weird. I will have to get some type of lightweight enclosure made up to house it. Battery is tied down although it doesn't appear so. I can push the car(in neutral) while holding onto the battery.
Pushing it *backwards* towards the empty space..
more pics on my build thread in my signature.
The Following User Says Thank You to stevo_12v For This Useful Post:
86BRZ (12-04-2012)
Old 12-04-2012, 02:39 AM   #24
86BRZ
86BRZ's Avatar
Drives: BRZ Limited arrived on 9/1/2012
Stevo12v, imam thinking the same battery. Do you have any issue after replace? How about the driving feel after losing 20 lbs?
86BRZ is offline   Reply With Quote
Old 12-04-2012, 06:39 AM   #25
stevo_12v
No issues what so ever. Really good battery. It's been running excellent since I posted up above(30th August) Starts first time all the time. I don't even have it connected up to a tender.
You'll notice a slight bit of pickup. Similar as if you've removed your spare tyre. Highly recommend it. Get a DEKA if you can't afford the braille. They are the same battery.
86BRZ (12-04-2012)
Old 12-04-2012, 04:01 PM   #26
86BRZ
86BRZ's Avatar
Thank you. I am thinking about.. Both! Battery and spare tires to cut 50 lbs, and thinking hard for more ways to cut weight...
(like only fill up half tank...)
Old 12-05-2012, 12:26 AM   #27
stevo_12v
Wheels + Exhaust
Get lightweight rims in that case. Ideally WedsSports .. but Enkei RPF1's.. they are great, cheap and light.
And go for the HKS Spec-L exhaust, lightest exhaust so far - unless you want to go Ti.
I changed mine over on the weekend.. the weight of the stock muffler itself is heavier than the whole HKS CBE.
Old 12-05-2012, 12:34 AM   #28
gmookher
rotational and unsprung weight has the greatest effect
Tow hook specs? mufasis BRZ First-Gen (2012+) — General Topics 15 10-21-2012 10:41 PM
Aftermarket battery speed-wiz Scion FR-S / Toyota 86 GT86 General Forum 59 08-07-2012 11:23 PM
BRZ CDN specs up at Subaru.ca! Sport-Tech CANADA 17 04-05-2012 09:12 PM
Aussie specs sneaky AUSTRALIA 7 03-14-2012 12:37 AM
Two Ft86 Specs for Aus church Scion FR-S / Toyota 86 GT86 General Forum 17 06-19-2011 07:53 PM
