Old 11-24-2011, 03:30 PM   #1
speed-wiz
speed-wiz's Avatar
Drives: MR2
Thumbs up Aftermarket battery
One of my first mods to this car will be a lightweight battery. I have had good luck with Odyssey batteries in the past, but I haven't bought one in several years. I'm curious what other lightweight batteries people have used that are a good combination of weight savings, reliability, and reasonable cost.
speed-wiz is offline   Reply With Quote
Old 11-24-2011, 03:53 PM   #2
Neutral_Eyes
Softparker
Neutral_Eyes's Avatar
Drives: 2002 Mazda Miata
Brailles are pretty light. I've never had a good battery experience from units I purchased, though the original Panasonic in my Miata lasted 8 years in Arizona heat. What if... the stocker's decent?
Neutral_Eyes is offline   Reply With Quote
Old 11-24-2011, 03:56 PM   #3
speed-wiz
speed-wiz's Avatar
Drives: MR2
That would be great. Worth keeping for a while anyway.
I've seen Brailles in several Lotus.
Old 11-24-2011, 04:30 PM   #4
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
The Brailles are overpriced. You can get the Deka/Magnapower batteries for a lot less and are essentially the equivalent. I remember seeing a thread on the VW and Honda forum about guys using lawnmower/ATV/motorcycle batteries as long as the CC amps were the same and putting them on tenders when parked.
Old 11-24-2011, 04:35 PM   #5
MrVito
Grumpy Old Man
MrVito's Avatar
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
Ghetto fabulous
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
MrVito is offline   Reply With Quote
Old 11-24-2011, 04:41 PM   #6
RRnold
2 wheel member
RRnold's Avatar
Originally Posted by MrVito View Post
Ghetto fabulous
For guys who own motos with lightweight batteries, it's more common than you think.
My bike is actually connected to one as we speak and here is another Duc on a tender. That's the tradeoff for going with a smaller battery.
Old 11-24-2011, 11:11 PM   #7
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Ghetto fabulous
Actually, those alligator clips are ghetto fabulous. Somebody needs to buy that guy a quick disconnect for Christmas.
EDIT:
OP, take a look at Ballistic Performance. They're a bit spendy, but light as hell. Their batteries are intended for motorcycles, but they make one for big displacement, high compression Harleys that has more than enough juice for a 2.0L four cylinder. It weighs 3lbs and has more CC Amps and Amp Hours than a 18lb Braille AGM battery for only $60 more ($270 total). For comparison's sake, the lightest battery Braille makes, with similar capacity, weighs 9 lbs and costs $2000.
old greg is offline   Reply With Quote
Old 11-24-2011, 11:15 PM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Ghetto fabulous
Depends on the usage of the car. For a street car I agree, but for a race car it's just fine.
Speed: Since the battery on this car is right against (or basically against) the firewall on the passenger side a light battery will make a much smaller difference compared to a car that has a front mounted (right behind headlights, etc.. in front of the axle) battery.
Same weight difference on both battery locations, but the effects on handling are different. Just as I've done with my Hondas that have a similar placement (except literally against the firewall) I'll be leaving it alone.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-25-2011, 12:58 AM   #9
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
EDIT:
The Ballistic is on sale right now..
http://www.solomotoparts.com/product...0&cat=0&page=1
$242.95...for the 3 pound 16 cell EVO 2 lithium battery
tripjammer is offline   Reply With Quote
Old 11-25-2011, 02:28 AM   #10
RRnold
2 wheel member
RRnold's Avatar
EDIT:
They come with a quick connect so it all comes down to personal preference. <Mine is on quick connects.
Damn 242.95 for 3 lbs!! You can shit out 3 lbs and that won't cost you anything!
Anyone looking at the Braille, it's the same as the Deka and around under a $100.
http://forums.vwvortex.com/showthread.php?2353060
http://www.dekabatteries.com/default.aspx?pageid=510
Old 11-25-2011, 02:56 AM   #11
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
Cayman R battery
quik1987 is offline   Reply With Quote
Old 11-25-2011, 03:16 AM   #12
Racelex
Drives: Impreza GC8
On my previous car, I had a Deka battery that was approx 11lbs. Forgot the model and specs on the battery, but the results surprised me. I did not think changing to a lightweight one would have that much effect on handling. Lost about 35lbs under the hood, but the downside was that I had to switch back to OEM battery for winter. The Deka just didn't do well at temps below 10 degrees celcius and it won't crank the car at anything below 5 degrees celcius.
Overall if you're into making your car handle good, then it's a good modification. Switching batteries wasn't a big hassle for me.
Racelex is offline   Reply With Quote
Old 11-25-2011, 03:36 AM   #13
dominican
Lude Dude
Drives: 1998 Honda Prelude
I've been using an Odyssey battery in my Prelude for about 4 years now, never did me wrong. I'll be getting one for the FR-S whenever I buy it.
dominican is offline   Reply With Quote
Old 11-25-2011, 07:32 AM   #14
tripjammer
tripjammer's Avatar
Originally Posted by quik1987 View Post
Cayman R battery
Wow that is a tight battery! I wonder how much it weighs?
battery
Aftermarket wheels chopped onto Modellista 86 JDM-dono FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 32 12-20-2011 04:20 AM
What Aftermarket parts would you like to see for the FT86/FRS mkivalex Scion FR-S / Toyota 86 GT86 General Forum 78 11-14-2011 10:50 AM
Toyota FT-86: a goldmine for aftermarket parts Axel Scion FR-S / Toyota 86 GT86 General Forum 16 12-27-2009 10:16 AM
