Old 10-01-2012, 12:53 AM   #29
jeffsides
AZ FRS 86
jeffsides's Avatar
Did mine today
@AZFRS86
Old 10-01-2012, 12:56 AM   #30
jeffsides
AZ FRS 86
jeffsides's Avatar
@AZFRS86
Old 10-01-2012, 12:58 AM   #31
jeffsides
AZ FRS 86
jeffsides's Avatar
Along with doing my calipers. Name:  ImageUploadedByTapatalk1349067489.514290.jpg
@AZFRS86
Old 10-01-2012, 01:00 AM   #32
jeffsides
AZ FRS 86
jeffsides's Avatar
@AZFRS86
Old 10-04-2012, 11:39 PM   #33
ZeN6
ZeN6's Avatar
Drives: Firestorm M/T FRS
Here's mine:
ZeN6 is offline   Reply With Quote
The Following 3 Users Say Thank You to ZeN6 For This Useful Post:
danthedirt (05-20-2013), ipothas (10-11-2012), sal (10-04-2012)
Old 10-05-2012, 12:54 AM   #34
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Originally Posted by ZeN6 View Post
Here's mine:
^ I like!
Nitro22 is offline   Reply With Quote
The Following User Says Thank You to Nitro22 For This Useful Post:
ZeN6 (10-11-2012)
Old 10-07-2012, 05:56 PM   #35
showbe
Drives: A nice one
Please dont use sharpie. I remember seeing the OP's picture and it looked horrible. If you do this please use paint or something similar like the other posters.
showbe is offline   Reply With Quote
The Following User Says Thank You to showbe For This Useful Post:
jeffsides (10-07-2012)
Old 10-11-2012, 03:21 PM   #36
ipothas
ipothas's Avatar
Drives: Whiteout FR-S
Here's mine:
Wow, that badge looks amazing. Mind I ask how you did it?
2013 Whiteout 6MT
ipothas is offline   Reply With Quote
The Following User Says Thank You to ipothas For This Useful Post:
ZeN6 (10-11-2012)
Old 10-11-2012, 05:59 PM   #37
ZeN6
ZeN6's Avatar
Originally Posted by Khalis View Post
This DIY is to turn your boring old USDM Piston Badge into a ghetto "JDM" Piston Badge.
@Khalis: I don't mean to Tread Jack. If you want to remove this I can.
This is how I did it:
I basically did the same thing as your DIY on painting your Scion Emblems.
I sprayed 2 coats of White DupliColor primer.
I then followed that up with 2-3 coats of Gloss Black DupliColor.
I left it to dry over night just in case.
Then I went ahead and did the red, which I used Simply Acrylic Scarlet Paint.
At first I tried doing as Jeffsides did and painted with a small paint brush but my hands are not that steady and I keep messing up.
So what I did instead was put down a blob of the paint in the areas that was to be red and then used a Q-Tip Cotton Swab and wiped the excess off leaving the red in the indents. I did a section at a time (inside the 86, then the circle outside, then the two lines on the pistons).
After I wiped off the red there was smears on the black portions. To clean that I dipped the Q-tips in water and carefully wiped away the red that I don’t want. (Wasted a lot of Q-Tips, I used both sides once and tossed them. Did not want to drag any red)
For the first piston it took me awhile (2-3hrs) because I use rolled up paper towels. I then switched to Q-tips and it worked great. The second one took me an hour but I was watching TV as well.
I let it dry over night just to be sure. The next day there was still some red hazing on the black portions and water wouldn’t take it off so I used Lysol Disinfecting Cleaning Wipes, and CAREFULLY wiped the haze away.
Then I put 2 coats of DupliColor Clear Coat.
Done
I got all the material from Wal-Mart.
I don’t have any pictures of the process but here is a couple where the pistons are on my car.
Chinadian (05-12-2013), danthedirt (05-20-2013), ipothas (10-11-2012)
Old 10-11-2012, 06:17 PM   #38
Khalis
Khalis's Avatar
Drives: 2013 Ultramarine 86
@ZeN6, Thanks for your input. I don't mind at all! My method is coming off anyway. Not much of a DIY on my part haha.
Khalis is offline   Reply With Quote
The Following User Says Thank You to Khalis For This Useful Post:
ZeN6 (10-12-2012)
Old 10-12-2012, 12:56 AM   #39
jeffsides
AZ FRS 86
jeffsides's Avatar
Very nice @ZeN6
@AZFRS86
ZeN6 (10-12-2012)
Old 12-02-2012, 01:14 AM   #40
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I did mine with Testors enamel, blue tape masking and tiny brush.
raul is offline   Reply With Quote
Old 12-02-2012, 11:43 AM   #41
jeffsides
AZ FRS 86
jeffsides's Avatar
Size:  61.9 KBName:  ImageUploadedByTapatalk1354466488.674201.jpg
Size:  74.2 KBName:  ImageUploadedByTapatalk1354466510.941439.jpg
Carbon vinyl
@AZFRS86
Old 12-02-2012, 09:14 PM   #42
chris's fr-s
@theexquisite86
chris's fr-s's Avatar
Drives: 2013 Firestorm FR-S
Where DI'd you get the carbon cut outs
chris's fr-s is offline   Reply With Quote
"vent" setting very warm to hot MTeator Scion FR-S / Toyota 86 GT86 General Forum 39 02-12-2023 09:35 AM
"86 Piston" License Plate Frame (part 2) 86_ZN6 Exterior Parts - The Rest 122 12-22-2013 05:35 PM
"86 Piston" License Plate Frame 86_ZN6 Cosmetic Modification (Interior/Exterior/Lighting) 13 08-05-2013 11:30 AM
WTB/Trade: Black FR-S fender "vent" panels with 86 badge JWA Exterior Parts (Aero, Lighting, Etc.) 7 09-19-2012 09:42 PM
"86 Piston" License Plate Frame 86_ZN6 Exterior Parts - The Rest 136 07-19-2012 11:00 PM
