Old 11-26-2012, 01:26 AM   #435
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
sick plate btw, did a double take as I dismissed it as regular plate at first.
dori. is offline   Reply With Quote
Old 11-26-2012, 09:51 AM   #436
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Thx
Old 11-26-2012, 10:12 AM   #437
White Shadow
Drives: 12,000 miles per year
Originally Posted by whitefrs View Post
You should dump the ugly yellow NY plate and get one of the custom white plates instead. It would look much better on your car. I don't know what the hell they were thinking when they went back to the old yellow plates. I got rid of mine right away because it looked horrible on my car.
White Shadow is offline   Reply With Quote
Old 11-26-2012, 05:19 PM   #438
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
@White Shadow
i know but in NY you can get pulled over for no front plates and i also have Limo Tint so dont wanna get pulled over for plate and then get a ticket for tints
Old 11-26-2012, 06:48 PM   #439
White Shadow
@White Shadow
No, I'm not saying that you shouldn't run a front plate, I'm saying that you should swap the yellow plate for a custom white plate instead. I have one on my car and it looks a lot better than the ugly yellow plates!
Old 11-27-2012, 03:41 PM   #440
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I just want to come in and apologize for wondering why it needs to be done and saying it would be stupid. I am looking at getting rims in the 8-9 inch range and stretching my tires would be a sweet way to save money for a year or two.
Old 11-27-2012, 07:34 PM   #441
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
wheel and brake fitment
I tried searching and didn't find an answer, and I want to make sure everything will work with everything else before I get it.
Will the Brembo 345mm BBK (front and rear) work with O.Z. Alleggerita HLT 17x7.5 (offset +48mm)
kurbkilla is offline   Reply With Quote
Old 11-27-2012, 07:46 PM   #442
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I don't think so without a spacer, will they fit with stock wheels because those OZ's are almost stock sizing just a half inch wider??
Old 11-28-2012, 10:54 AM   #443
kurbkilla
kurbkilla's Avatar
I have not run spacers before what are the problems with the performance if I went on the track?
Old 11-28-2012, 11:30 AM   #444
JoeBoxer
JoeBoxer's Avatar
If you get quality ones with extended studs they should be fine, check out project kics and H&R.
Old 11-28-2012, 11:33 AM   #445
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Doesn't Brembo have a template for checking fitment with your wheels?
Spacers can be used to help with fitment but can put more load on wheel bearings. Spoke design is more important than offset and width by itself (spoke shape).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-28-2012, 12:08 PM   #446
kurbkilla
kurbkilla's Avatar
Ya I thought it is always better to avoid spacers.
Would I solve the problem/clearance by going to 18x7.5 or is it still that 7.5 that cases the problem?
Old 11-28-2012, 12:25 PM   #447
JoeBoxer
JoeBoxer's Avatar
The +48 offset is probably the main problem but like Dave said spoke design is also important and you really need to know if they will work with stock wheels, that would at least give you a reference to start with.
Old 11-28-2012, 12:32 PM   #448
kurbkilla
kurbkilla's Avatar
The rims (per tirerack's website) will fit with out spacers. If the offset is the same as stock the extra 1/2" in the width wouldn't affect the brake caliper, it would just be 1/2" deeper into the wheel well, right? I just dont see were the spoke pattern effects it other then looks
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
