Old 11-26-2012, 07:16 PM   #3963
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Originally Posted by RandyP View Post
You probably shouldn't be mashing the throttle repeatedly on an unloaded engine. It's tuned on a loaded engine where it doesn't spin-up as fast and there is time for the engine controls to retard knocking. Does it knock just as bad at highway speeds when you mash the throttle with the car in gear?
For me it doesnt matter if im standing still or driving the noise still appears.
brichard0625 is offline
Old 11-26-2012, 07:54 PM   #3964
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I think we should post this else where as mentioned seeing that its not tune related, I sent John the log and maybe he could take a look at what's going on and see if the tune has something to do or not. To clarify I don't go around smashing the throttle without load on the vehicle, i was just trying to replicate the noises heard when rev matching for a downshift. Ill do a second and third gear pull and see if I get knock. Maybe this is the beginning of a soon to come cel .
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline
Old 11-26-2012, 08:55 PM   #3965
Visconti
Drives: 05 STi
I dont think anyone should do anything until I take a look at some datalogs.
Visconti is offline
Old 11-26-2012, 08:56 PM   #3966
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
How did you embed the video?
Just paste the bare link, without any 'feature' or added junk in the url.
Symbiont is offline
The Following User Says Thank You to Symbiont For This Useful Post:
yomny (11-26-2012)
Old 11-26-2012, 09:31 PM   #3967
yomny
yomny's Avatar
I went ahead and did some 2-4th gear pulls and if im looking at the correct title, there's some knock. I'll leave it up to John.
PS- John i will upload the logs on to my ticket.
yomny is offline
The Following User Says Thank You to yomny For This Useful Post:
xjohnx (11-26-2012)
Old 11-26-2012, 09:39 PM   #3968
fenton
Depends which one you are looking at because there is knock learning (which is usually positive) and knock correction (negative when problems occur) confirm which one you are looking at.
Also I would love to know the actual strategy used if someone could post that.
Sent from my Nexus 10 using Tapatalk 2
fenton is offline
Old 11-26-2012, 09:57 PM   #3969
yomny
yomny's Avatar
I get both, i get knock learning up to 5 counts and knock correction on my second gear pull i get starting at 2300rpm -1.4 knock corr and increased up to -2.1 by 2700rpm's then went to 0. The other logs i get up to 5 knock learn and no knock corr. I'm perplexed here, i could be looking at the wrong thing but something sounds bad and its tune sensitive for me. I just flashed back the latest racerom tune and the knocking noise was there instantly, loud and clear when sharply pressing on the accel pedal, mostly NOT under load(free reving, on acceleration between shifts before clutch engages).
yomny is offline
Old 11-26-2012, 10:33 PM   #3970
fenton
i was going to post something but because i dont know the whole stategy yet it dont want to post mis information. I will let visconti chime in.
To my knowledge knock learning in the positive is fine, if knock correction(negetive) is present a small amount of timing will be taken away from the knock learning column which will in turn reduce the total iginition timing used.
What you are describing soundwise does not sound like pre detonation(knock) but rather something mechanical.
Pre detonation or knock correction typically cant be heard unless it is quite bad and even then it would happen under load, not free reving.
fenton is offline
Old 11-26-2012, 11:28 PM   #3971
Visconti
Drives: 05 STi
I have a ever growing list of logs to review..
I'll get to it soon enough, any positive knock correction is OK.
Every tune will have knock from time to time - this is why the ECU has such a advanced Knock Control system
-John
Can I get a little more feedback on the RaceRom Traction control?
It it too sensitive?
-John
Visconti is offline
Old 11-27-2012, 12:31 AM   #3972
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Not sure what the Race rom traction control is. Or how it's turned on or off ect.
Gregg
jdzumwalt is offline
Old 11-27-2012, 01:19 AM   #3973
cruzinbill
Drives: Argento 6spd FR-S
-John
-John
Which versions of RR have the TC? Ill give it a try today if mine has it and I can figure out how to enable it.
cruzinbill is offline
Old 11-27-2012, 06:36 AM   #3974
Foobar
SLO NO MO
Foobar's Avatar
-John
Doesn't seem to be active in any of my maps.
Sent from my Nexus 7 using Tapatalk 2
Disregard - RR TC is not available until v1.08b3 (Pump Gas)
Foobar is offline
Old 11-27-2012, 08:40 AM   #3975
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
You guys need to look at the release notes on the support console and cross reference it to the tune you currently have.
P.S. from the release notes, it looks like the TC started sometime around v1.08b1 or v1.08b2
CircuitJerk is offline
Old 11-27-2012, 08:43 AM   #3976
Foobar
SLO NO MO
Foobar's Avatar
I have v1.08b1 and have been testing it out in slick conditions with factory nannies off, I don't seem to notice any type of traction control kicking in.
Edit: looks like RaceROM TC isn't available until v1.08b3 (Pump is different than Corn, that's what confused me)
Disregard
Foobar is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
