#3963 | |
Drives: 2013 Scion Frs(Scarlet)
#3964 |
Drives: 2013 FRS Whiteout
I think we should post this else where as mentioned seeing that its not tune related, I sent John the log and maybe he could take a look at what's going on and see if the tune has something to do or not. To clarify I don't go around smashing the throttle without load on the vehicle, i was just trying to replicate the noises heard when rev matching for a downshift. Ill do a second and third gear pull and see if I get knock. Maybe this is the beginning of a soon to come cel
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#3965 | |
I dont think anyone should do anything until I take a look at some datalogs. |
#3966 |
Tall guys fit, too.
Drives: BRZ Premium 6MT (SWP)
Just paste the bare link, without any 'feature' or added junk in the url.
| The Following User Says Thank You to Symbiont For This Useful Post: | yomny (11-26-2012) |
#3967 | |
I went ahead and did some 2-4th gear pulls and if im looking at the correct title, there's some knock. I'll leave it up to John. PS- John i will upload the logs on to my ticket.
| The Following User Says Thank You to yomny For This Useful Post: | xjohnx (11-26-2012) |
#3968 |
Depends which one you are looking at because there is knock learning (which is usually positive) and knock correction (negative when problems occur) confirm which one you are looking at.
Also I would love to know the actual strategy used if someone could post that. Sent from my Nexus 10 using Tapatalk 2 |
#3969 | |
#3970 |
i was going to post something but because i dont know the whole stategy yet it dont want to post mis information. I will let visconti chime in.
To my knowledge knock learning in the positive is fine, if knock correction(negetive) is present a small amount of timing will be taken away from the knock learning column which will in turn reduce the total iginition timing used. What you are describing soundwise does not sound like pre detonation(knock) but rather something mechanical. Pre detonation or knock correction typically cant be heard unless it is quite bad and even then it would happen under load, not free reving. |
#3971 |
I have a ever growing list of logs to review..
I'll get to it soon enough, any positive knock correction is OK. Every tune will have knock from time to time - this is why the ECU has such a advanced Knock Control system -John Can I get a little more feedback on the RaceRom Traction control? It it too sensitive? -John Last edited by Visconti; 11-26-2012 at 11:41 PM. |
#3972 |
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Not sure what the Race rom traction control is. Or how it's turned on or off ect.
Gregg |
#3973 | |
Drives: Argento 6spd FR-S
Which versions of RR have the TC? Ill give it a try today if mine has it and I can figure out how to enable it. |
#3974 | |
SLO NO MO
Sent from my Nexus 7 using Tapatalk 2 Disregard - RR TC is not available until v1.08b3 (Pump Gas) Last edited by Foobar; 11-27-2012 at 08:52 AM. |
#3975 |
Pull my finger...
Drives: Silver Scion Slushbox
You guys need to look at the release notes on the support console and cross reference it to the tune you currently have.
P.S. from the release notes, it looks like the TC started sometime around v1.08b1 or v1.08b2 |
#3976 | |
SLO NO MO
Edit: looks like RaceROM TC isn't available until v1.08b3 (Pump is different than Corn, that's what confused me) Disregard |
| LED Front Signals with Resistor Flash Correctors | DarrenDriven | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 09-20-2012 02:05 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
| How to embed a flash gallery? | DarrenDriven | Site Announcements / Questions / Issues | 2 | 04-24-2012 07:43 PM |
| Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors | blur | BRZ First-Gen (2012+) — General Topics | 130 | 09-01-2011 01:42 PM |
