Old 11-09-2012, 10:20 PM   #15
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by cobrabyte View Post
Regular lug nuts fit these things or do you need open-ended lug nuts?
Regular nuts will not work on the extended studs. You can get open ones from pep boys for $6 for four lugs, $30 total or buy any number of more expensive options i have some project kics r40 lug nuts to put on the car.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
cobrabyte (11-10-2012)
Old 11-09-2012, 11:06 PM   #16
Yruyur
Yruyur's Avatar
Looks like these arp studs run about 7$ a piece...ouch. but nice diy.
Sent from my flux capacitor using Taptalk
Old 11-10-2012, 02:16 PM   #17
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yep. I paid a bit less than that, but they aren't cheap. However they are stronger and in my case I needed them to clear my front brakes with the OEM wheels (due to spacers)
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-10-2012, 02:20 PM   #18
Yruyur
Yruyur's Avatar
Do you have pics of the installed wheels with spacers. What spacers did you get and how much?
Old 11-10-2012, 05:49 PM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I haven't bought the spacers yet because I haven't measured how much I'll need to clear the brakes with the OEM wheels.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-10-2012, 05:56 PM   #20
gmookher
nice post
Old 11-10-2012, 09:05 PM   #21
TTGT
TTGT's Avatar
Drives: 2013 Whiteout FRS
what part number for rear studs?
TTGT is offline   Reply With Quote
Old 11-10-2012, 10:09 PM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Should be the same as the front.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-27-2012, 05:10 AM   #23
Junebug
Junebug's Avatar
Drives: 2013 scion frs firestorm m/t
So our studs are the same ones wrx models use?
Junebug is offline   Reply With Quote
Old 11-27-2012, 09:12 AM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yes
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-27-2012, 11:36 AM   #25
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Have the specs on the axle nut? Have not been able to track it down. May have to purchase a couple to see what fits. :/
cobrabyte is offline   Reply With Quote
Old 11-27-2012, 02:02 PM   #26
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I do not, but I'd assume WRX. I'll txt Opie and see if he can find out.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
cobrabyte (11-27-2012)
Old 11-27-2012, 02:47 PM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
@Opie checked. They are the same as a 2012 WRX. He doesn't have the thread pitch specs but you can buy them at any Subaru dealership. He has 8 in stock currently.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
cobrabyte (11-27-2012), CxG (05-17-2016)
Old 11-27-2012, 02:58 PM   #28
cobrabyte
cobrabyte's Avatar
Fantastic. Thanks a million!
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 04:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 02:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 10:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 02:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
