Old 11-22-2012, 11:54 AM   #421
empower-auto
Kouki-Monster
empower-auto's Avatar
Originally Posted by SkAsphalt View Post
why would you do this... 2 inches of stretch...
assuming OP wants to cut costs.
not a great area to do it but .. oh well I've seen worse
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-22-2012, 01:50 PM   #422
D1cker
Drives: B9 S4/ND2
I tried it on my 17x9 RPF1's and I couldn't get them to bead, and I'm used to running stretched tires (205's on 9.5's etc)
D1cker is offline   Reply With Quote
Old 11-22-2012, 02:39 PM   #423
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
mm just does not seem like the safest option, nor the most effective. Cost saving tho yes
Old 11-22-2012, 02:41 PM   #424
BigJyoungblood
Enthusiast
BigJyoungblood's Avatar
Drives: 2013 Scion FR-S (37J)
Thanks fellas. Looks like skinnier wheels for now.
Reason was to save cost. The Michelines are rated up to 8" so I figured it wouldn't stretch TOO bad and still be fine till a new set of tires.
BigJyoungblood is offline   Reply With Quote
Old 11-24-2012, 11:30 PM   #425
ayau
Drives: Some rust bucket
Originally Posted by rikdrt1 View Post
Im looking at the Enkei PF's -- in as close as stock as i can get --
I noticed that tirerack says to move up to 225/45/17 for this size... but is that the widest it can take safely ?
what happens or is it recommended to use the 215/45's - on a rim size that is bigger than the stock 7" ?
or does that strectch the tire ? - ive heard that term but not sure what that means ---
215 will take 7.5" wheels just fine. In fact, some 215 tires can accept 8" wheels and it won't look stretched. The stretched look will depend on the tire brand/model. Even though the tires are both 215, they're not necessarily the same width.
Old 11-24-2012, 11:40 PM   #426
dabocx
dabocx's Avatar
Drives: Scion FRS
Should be ok, im putting the stock 215s on 8inch wide wheels for a while.
dabocx is offline   Reply With Quote
Old 11-24-2012, 11:42 PM   #427
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
do you need spacers for an 8 inch wide wheel? with the same offset or do you need to change that ?
DanoFA20 is offline   Reply With Quote
Old 11-25-2012, 12:24 AM   #428
Hanakuso
What do you mean? For clearance for rubbing you will be fine. Most likely brake clearance will be fine but each wheel has different clearance for brakes and you cannot tell just by looking at offset and wheel size but 8 inch width is generally safe. I actually haven't heard it at all being a problem for the BRZ/FRS
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
DanoFA20 (11-25-2012)
Old 11-25-2012, 12:33 AM   #429
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
my nissan has 205/45 17 on a 9in wide wheel you will be a fine.alittle stretch stiffens the sidewalls for better handling response
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 11-25-2012, 12:37 AM   #430
Grip Ronin
The Mechanic
Grip Ronin's Avatar
there is a risk to streching but a 215 45 on a 8 isnt bearly noticable as a stretch. it would seat just fine at a normal tire shop
IG-Joey_Soul
Old 11-25-2012, 01:44 AM   #431
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
here are mines
17x9 et35 on michelin stock 215/45
Old 11-25-2012, 11:23 AM   #432
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
It would be best for you to stop in and talk with the Tire Rack people. They are the professionals, day in and day out.
BRZfan is offline   Reply With Quote
Old 11-25-2012, 10:29 PM   #433
Grip Ronin
The Mechanic
Grip Ronin's Avatar
looks good^
IG-Joey_Soul
The Following User Says Thank You to Grip Ronin For This Useful Post:
whitefrs (11-25-2012)
Old 11-25-2012, 10:30 PM   #434
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Thx
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
