Old 11-24-2012, 11:13 PM   #141
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Originally Posted by BuBlake View Post
<iframe width="560" height="315" src="
" frameborder="0" allowfullscreen></iframe>
Thanks for the update! They look a lot better now that they are somewhat tinted. IMO the light on it is way too faded/dim for my liking... Especially in rainy Vancouver here...
But great job!
Too bad the turn signals aren't the yellow ones and the park lights the red accents... You would think it should be the opposite... Unless you wired it up wrong.
P.S. That dog really scared the heck out of that camera guy. Haha... Is that white FR-S behind you his?
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 11-24-2012, 11:21 PM   #142
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
The video confirms both the rear running lights and brake lights are significantly dimmer than stock.
Also the rear running lights are yellow, which is not within compliance with DOT specs at all. Did they get the wiring harnesses backwards from the factory?
I appreciate you taking the risk in getting these and making a nice video. I wasn't a fan of these aesthetically but functionally it seems these things may leave much to be desired. Sorry for the bad break.
Also yes, please no drunk driving.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 11-24-2012, 11:23 PM   #143
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
yeah i think you wired that up wrong man..
Surok is offline   Reply With Quote
Old 11-24-2012, 11:27 PM   #144
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
mate, I'm fairly sure you've got the wiring backwards. Orange inners should be the turn signal and the red outers should be the running/parking lamps.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 11-25-2012, 12:13 AM   #145
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
There's only one way to plug them in, so this can only mean one thing: They were wired incorrectly from the shop or wherever they came from in Japan. Now I have to figure out how to swap the wires and which wires to swap, great... I'm sure as heck not going to send them back and wait two more months.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 11-25-2012, 12:30 AM   #146
BuBlake
BuBlake's Avatar
But great job!
Thanks man! I'll definitely get some video when I get the wiring fixed. I think I may have to do some soldering, but i'm hoping I can just use pliers and swap their positions at the connector. I am trying to contact the vendor on eBay right now for information on how to fix them.
As posted, the wiring seems to be wrong inside the light, unfortunately.
That's Enjoi23's Whiteout FR-S behind mine!
Old 11-25-2012, 12:39 AM   #147
cnk
Drives: '13 DGM BRZ Limited
Here's what I pulled from the BRZ wiring diagram for the tail light connectors. I would think it's the same for the FRS.
LG - stop light
B - ground
R - Side marker
W - RH turn signal
Y-G - LH turn signal
Old 11-25-2012, 12:49 AM   #148
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Thanks for the update! Pics and video look great! I laughed to myself when I read a few guys posting you wired them incorrectly as I knew they were plug & play
As far as your wiring issue goes, did you get these directly from japanparts or eBay seller ? Nevermind I just saw your post
Can you confirm they are wired incorrectly ?
Anyhow everything looks good and I look forward to getting mine installed. I already have a relay in place as I've been running aftermarket smd's front and rear to eliminate hyper flashing. So that should address that just fine.
They look great man
Sent from N7 CleanRom 2.5 JB 4.2
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 11-25-2012, 01:03 AM   #149
BuBlake
BuBlake's Avatar
They look great man
I bought them from an eBay seller, which is why I was ripped for about an extra $50 or so. Looking at them further, I think they cannot be fixed unless I drill into them, so I may be sending them back and getting a refund. I'm pretty t-d off, but life will go on. haha
Thanks for the info on hyper flashing. Looks like relays are cheap at least.
Hopefully you don't have the same problem... Hey anyone still want to trade for stock lights!? ha ha ha
Old 11-25-2012, 01:07 AM   #150
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Why can't you just rep in the connectors... Swap out the running light wire and turn signal.. Easy to do
Also I like the hyper flash.. Much more noticeable.. IMO... Most don't think so...
Gixxersixxerman is offline   Reply With Quote
Old 11-25-2012, 01:11 AM   #151
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
LOL you beat me before I edited my post
Can you confirm they were wired incorrectly ?
Yeah I thought you bought from eBay, they were advertised as used also were they not ?
2URGSE
Old 11-25-2012, 01:26 AM   #152
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
I just double checked mine up against your pics and they are identical as far as the wiring goes. Won't really know for sure until I hook them up. But if they light up the same, I would suspect that's how they were intended to be unfortunately
Swapping out and reconnecting a couple of wires should take car of that though
2URGSE
Old 11-25-2012, 01:28 AM   #153
BuBlake
BuBlake's Avatar
I was under the impression that hyper flashing was illegal for some reason, but i'm most likely wrong. haha I thought it would get the attention of people more effectively too.
Problem is that I don't know the wiring yet. You're right, it's probably fixable.
By watching the video, one can only assume that they weren't meant to function that way. What someone would think would be the turn signals are on when I turn my headlights/running lights on, and when I turn my signal on, my red/running light blinks. I'm pretty sure driving around with yellow tail lights at night that are only red when i'm braking would get me pulled over or worse.
They were advertised as "used" in the description but in the listing's title it clearly said "NEW! LED tail lights" blah blah blah, so I contacted the seller and he/she said that the tails were "NEW!". I took their word for it and bought them right after that, thinking that there was just a problem with their listing. Now i'm starting to think that there's something fishy going on.
Old 11-25-2012, 01:38 AM   #154
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Can you post a night video of the tails in action ? I wouldn't worry about it, they look new and the wiring should be an easy fix if you decide to keep them
2URGSE
TYC tail lights doggy Cosmetic Modification (Interior/Exterior/Lighting) 90 02-13-2014 02:03 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
frs tail lights.. frsguy707 Exterior Parts (Aero, Lighting, Etc.) 10 11-11-2012 04:53 PM
Fatlace FR-S/BRZ Tail Lights? Broz Cosmetic Modification (Interior/Exterior/Lighting) 69 11-02-2012 09:55 PM
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
