#43 | |||||||
I can't quite give out a price yet, as we're still working on some options/details/design but I will as soon as possible.
There will be a video, and perhaps more pictures fairly soon. As far as some of the suggestions so far go: I will be looking into the cosmetic carbon fiber tube covers as a possible option. Stainless steel strut bodies could also an option, but would raise the cost quite a bit (you would really have to want that shine). I love reading how many people are already interested, especially those willing to dump the junk they already bought. I will keep this thread updated, and keep the suggestions coming! Chase Now to answer a few questions: Quote:
Great idea, I'm looking into it Yes sir, we love Australia too! Last edited by GrimmSpeed; 11-23-2012 at 11:30 AM. |
#44 |
Pull my finger...
Drives: Silver Scion Slushbox
I'd go for the shiny too.
I've been holding out for the NRG innovations product for far too long and those run 140+ if that gives you any indication. Having seen your products and your dedication to quality etc I'm stoked to see this come to fruition. |
#45 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I would love simple and black, maybe with a white GS logo embossed on it. Simple, quality and a competitive price is what you guys do best and that's what I'd really be looking for here.
#47 |
Drives: Subaru BRZ
Interested. Count me in for black. Would like to see color options for branding, as to match (closely) the color of our cars. I'd also be down for red branding to go along with the interior stitching.
Glad to see y'all are working on these. Love what you guys do. |
#48 |
Serious question. What makes your hood struts any better than the Gimmick Motorsports, Circuit Sports, or Greddy hood dampers that are already on the market? I see all of these people responding "would definitely buy" but if they were so serious, wouldn't they have already purchased one of the three that already exists?
| The Following User Says Thank You to st0k3d For This Useful Post: | developer (11-24-2012) |
#49 | |
Drives: BRZ Limited
#50 | |
#51 | |
I have "brand x" here installed. Two of the companies that you listed sell the exact same products. The gas springs might be different (which I would hope explains the extreme difference in cost), but the design of the brackets are IDENTICAL. These pieces appear to be universal, and were not designed for this car, but rather were picked based on their extreme low cost (looks like stamped sheet metal). First thing I asked myself when I saw the brackets: "Why are there so many extra slotted holes in this bracket, and what do they bolt to?" They don't bolt to anything because they are an off the shelf part you buy, and then try to adapt to your "design." Another good question is: "Why is the upper bracket that bolts to the hood so much wider than the stock hood bracket, and with its additional width, why isn't it butted up to the stock bracket to prevent rotation?" Again, it is obvious that this part was NOT designed for this car, and rather is just something off the shelf that they have adapted. Also, these brackets are very thin, very flimsy, and look terrible in gloss black. There is nothing built into the design to prevent the brackets from rotating over time with use. The current solution are the star shaped washers that bite into your paint to attempt to resist motion. Our brackets are designed specifically for this car, they will not fit anything else. The upper brackets were designed in with the aid of our FARO arm, and the result is a piece that perfectly contours the hood. This helps the design function perfectly, but also gives an OEM look that these other designs seriously lack. Both brackets also have two anchor points to prevent rotation. We have even considered how bulky the hood is, and have designed the upper bracket in such a way that guarantees you will not accidentally unbolt the hood and potentially damage your car. I've worked on LOTS of different cars, and removed lots of hoods, so I knew that manhandling a hood around while trying to line up holes and thread in fasteners would be completely unacceptable. Small features like this are the reason why you want to buy parts from GrimmSpeed. The people who are designing your parts LOVE cars and actually work on them all the time, so we design parts the way we wish others designed their parts. Their gas springs are of substantially lower quality as well. The hardware on them is heavily painted (not plated), and requires hand greasing them yourself to prevent rust and seizing problems. The diameter of the gas spring is smaller as well, which is usually a good indicator that ours will exhibit a more desirable and a more flat spring characteristic. Also, per the design, our gas spring has a longer stroke. A longer stroke means a smaller required spring force to do the same job, and less reaction forces at the joints. This decreases fatigue, and increases reliability. Clearly, we put a lot of time into design for our hood struts. I won't get into it in this particular post, but it was certainly not easy to achieve the goals we set out to as far as hood "handling" and opening distance goes. I was over joyed after installing "Brand X" and seeing the extreme difference between something that was slapped together to be sold, and something that was meticulously designed with absolute goals. Not only can you see the difference in quality, you also get to use and feel it. We'll release a video soon of how "Brand X" handles, and how ours handles. Just as a preview though: -"Brand X" does not open the hood any higher than the stock prop rod. Infact, in the temperature it is outside right now in Minnesota (19F), it opens to a height less than would be held by the stock prop rod by about an inch. - After this point, you can force the hood to go higher. Pushing hard up continues the extension of the gas springs and also significantly flexes the bracket to a point that I am a little worried about bending something, or destroying the threads on the inner fender. After you've forced the hood as high as it will go the hood still does not go as high as our design allows (and achieves automatically on its own). At this point, when you push the hood down to close you hear an audible "woosh" from the gas springs that seems to indicate that they were never meant to go to this height. Some might say the temperature might be affecting these results, but our design does not have these problems, and still functions very well in these low temperatures. - The neutral point in the middle is very stiff, it does not have the same "one-finger-lift" feel that ours does. - There is no "drop to close," meaning from the mid point below the neutral point you can not simply drop the hood to shut it, you must push it down as the gas springs are still acting against you, even when they should not be. So, there are many reasons why our design is better, and these are a few of the big ones. I'll update later when I have a bit more for you, but I think the video and pictures will speak a lot louder than even I can about the difference in design and quality. Chase Engineering Last edited by GrimmSpeed; 11-26-2012 at 07:48 PM. |
| The Following 4 Users Say Thank You to GrimmSpeed For This Useful Post: |
#53 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
so...who wants my gimmick hood struts
| The Following User Says Thank You to Jive Turkey For This Useful Post: | finch1750 (11-26-2012) |
#54 |
Drives: 2013 FR-S Matte Orange
I'm in
#56 |
Drives: Whiteout FR-S
Definitely interested in some quality hood struts and the wife has been asking for a Christmas list...
| Replacing Struts and Installing Coil Springs | DarrenDriven | DIY (Do-It-Yourself) Guides | 195 | 04-26-2017 04:15 PM |
| Stock Springs/Struts FRS | jadewbj | Brakes, Suspension, Chassis | 1 | 12-18-2012 10:00 AM |
| WANTED (GA) - Stock FR-S/BRZ struts | xwd | Brakes, Suspension, Chassis | 8 | 11-07-2012 10:43 AM |
| performance/aftermarker struts | karma003 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-07-2012 11:26 AM |
| JDM BRZ Struts different than USDM BRZ Struts? | switchlanez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-30-2012 10:21 AM |
