Old 11-24-2012, 08:57 AM   #57
Captain Insano
Originally Posted by dabocx View Post
http://www.ft86club.com/forums/showthread.php?t=17780
Thats a 3 inch and it seems pretty quiet.
Are they even selling that yet? I bet the muffler in the midpipe is helping quite a bit. Nice exhaust.
OP, as far as your planning goes, I really like it. Don't be deterred to trying new things on new models. The porting is a good idea. With the E85 and your stage II listed, I think you are going to be at or past 200whp. This is dyno dependent of course, I think on your average dynojet, you will meet that power goal.
Captain Insano is offline   Reply With Quote
Old 11-24-2012, 12:40 PM   #58
FT_Monk
Drives: Over the hill WRX
I have seen some exciting na Honda with cam and internal engine support mods like light weight pistons, cam, porting and valve train to rev the engine to 10K. A stripped na 86 properly modded to rev to 10k will be exciting too. But it will be expensive and not cost effective as FI.
Air intake filter and 3 inch exhaust on a stock 86 make lots of horse power noises, not actual horse power.
FT_Monk is offline   Reply With Quote
Old 11-24-2012, 12:54 PM   #59
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Honda NA power is cheap. You can do a K20 cam change in 20-30m depending on how good you are.
Doing cams on our car will take hours and if you pay for it will likely cost 1k in labor (A reputable shop on here said 3K total wouldn't be out of the question for cams).
This cost stopped me in my tracks when thinking about going NA.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
The Following User Says Thank You to Superhatch For This Useful Post:
dabocx (11-24-2012)
Old 11-24-2012, 01:01 PM   #60
dabocx
dabocx's Avatar
Drives: Scion FRS
Yeah when you do cams you minus well drop everything in at once and do all the work you plan to do on the motor at once.
Didnt Crawford tear part the stock head as well a while back? Im not a expert but does anyone know if there was alot of improvement to be made there?
dabocx is offline   Reply With Quote
Old 11-24-2012, 01:50 PM   #61
Opposed
Drives: 2013 Asphalt FR-S
Originally Posted by wparsons View Post
Is 3" really going to gain any power on an internally stock engine over a good 2.5" system? In theory it won't, but I'm not sure about the reality.
I personally wouldn't bother with 3" unless it's a turbo car with only a 2L engine.
In theory it should, but I don't think its been tested yet on the FA20. I know when I had my S2k, I gained almost 10whp from switching from a 2.5 to a 3", both single exit exhausts. But the db's and drone were unbearable for me...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 11-24-2012, 01:56 PM   #62
Superhatch
AIM4APX
Superhatch's Avatar
I had planned on doing I/H/E, cams and a tune. After looking at the numbers I figured it would be a perfect amount of HP for the car. But considering the hp gains from a SC kit far exceeds the gain of internals, and the cost would be only a bit more, going SC at this point seems like the better $/hp choice.
youcantseeme24 (11-25-2012)
Old 11-24-2012, 02:01 PM   #63
gmookher
Doing sc FI first. Cams too later.
Old 11-24-2012, 02:57 PM   #64
Dimman
Kuruma Otaku
Dimman's Avatar
Did anyone hear about cams yet? SEMA?
Because titanium.
Old 11-24-2012, 07:43 PM   #65
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
MIGHT AS WELL
For all motor? might give you like 1-3hp up top at most (might be no gain or 1-3 hp loss... you'll lose tq tho for sure. I figure 2.5 or 2.75 would be the sweet spot. Probably 2.75 if I plan on turbocharging later.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 11-24-2012, 10:47 PM   #66
OrbitalEllipses
Drives: Attitude
Originally Posted by FreshFRS View Post
pretty sure it makes less power per liter, just that you use more per cycle and its knock resistance allows more timing to generate more power.
You can run far more timing with E85 compared to gasoline. That's how the power is made; it's been said a few different ways in this thread.
Old 11-24-2012, 11:07 PM   #67
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Stock diameter is totally fine with 250whp 225tq
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 11-24-2012, 11:08 PM   #68
dabocx
dabocx's Avatar
Drives: Scion FRS
[QUOTE=seven;573189]MIGHT AS WELL
Would it make you more upset to know that I am a librarian?
Old 11-25-2012, 12:17 AM   #69
seven
Tells it like it is
seven's Avatar
MIGHT AS WELL
I had a good chuckle. :happy0180:
Old 11-25-2012, 12:35 AM   #70
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
thats what i was saying, but with less power density you need to inject more fuel to compensate for the losses. it takes timing better as well generating more power.
FreshFRS is offline   Reply With Quote
Bought it Friday tracked it Sunday!! NC Miata battle video inside... track_warrior Tracking / Autocross / HPDE / Drifting 311 02-28-2014 09:31 AM
When do you plan to get your BRZ? switchlanez BRZ First-Gen (2012+) — General Topics 33 08-16-2013 01:25 PM
Reputable tuners in GTA Philly CANADA 10 07-11-2012 06:38 PM
Tuners Delight: 2013 Scion FRS FRSDREAMER Scion FR-S / Toyota 86 GT86 General Forum 158 03-22-2012 08:09 AM
