#57 | |
OP, as far as your planning goes, I really like it. Don't be deterred to trying new things on new models. The porting is a good idea. With the E85 and your stage II listed, I think you are going to be at or past 200whp. This is dyno dependent of course, I think on your average dynojet, you will meet that power goal. |
#58 |
Drives: Over the hill WRX
I have seen some exciting na Honda with cam and internal engine support mods like light weight pistons, cam, porting and valve train to rev the engine to 10K. A stripped na 86 properly modded to rev to 10k will be exciting too. But it will be expensive and not cost effective as FI.
Air intake filter and 3 inch exhaust on a stock 86 make lots of horse power noises, not actual horse power. |
#59 |
AIM4APX
Drives: 2013 WRB BRZ Limited
Honda NA power is cheap. You can do a K20 cam change in 20-30m depending on how good you are.
Doing cams on our car will take hours and if you pay for it will likely cost 1k in labor (A reputable shop on here said 3K total wouldn't be out of the question for cams). This cost stopped me in my tracks when thinking about going NA.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
| The Following User Says Thank You to Superhatch For This Useful Post: | dabocx (11-24-2012) |
#60 |
Drives: Scion FRS
Yeah when you do cams you minus well drop everything in at once and do all the work you plan to do on the motor at once.
Didnt Crawford tear part the stock head as well a while back? Im not a expert but does anyone know if there was alot of improvement to be made there? |
#61 |
Drives: 2013 Asphalt FR-S
In theory it should, but I don't think its been tested yet on the FA20. I know when I had my S2k, I gained almost 10whp from switching from a 2.5 to a 3", both single exit exhausts. But the db's and drone were unbearable for me...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#62 |
AIM4APX
I had planned on doing I/H/E, cams and a tune. After looking at the numbers I figured it would be a perfect amount of HP for the car. But considering the hp gains from a SC kit far exceeds the gain of internals, and the cost would be only a bit more, going SC at this point seems like the better $/hp choice.
| The Following User Says Thank You to Superhatch For This Useful Post: | youcantseeme24 (11-25-2012) |
#63 |
Doing sc FI first. Cams too later.
#64 |
Kuruma Otaku
Did anyone hear about cams yet? SEMA?
Because titanium. Last edited by Dimman; 11-24-2012 at 02:57 PM. Reason: homonym spelling fail |
#65 | ||
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
![]() Quote:
For all motor? might give you like 1-3hp up top at most (might be no gain or 1-3 hp loss... you'll lose tq tho for sure. I figure 2.5 or 2.75 would be the sweet spot. Probably 2.75 if I plan on turbocharging later.
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
#66 |
Drives: Attitude
You can run far more timing with E85 compared to gasoline. That's how the power is made; it's been said a few different ways in this thread.
#67 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Stock diameter is totally fine with 250whp 225tq
#68 |
Drives: Scion FRS
[QUOTE=seven;573189]MIGHT AS WELL
![]() Would it make you more upset to know that I am a librarian?
#69 | |
Tells it like it is
![]() I had a good chuckle. :happy0180:
#70 |
KCCO From Canada
Drives: Asphalt FRS
thats what i was saying, but with less power density you need to inject more fuel to compensate for the losses. it takes timing better as well generating more power.
| Bought it Friday tracked it Sunday!! NC Miata battle video inside... | track_warrior | Tracking / Autocross / HPDE / Drifting | 311 | 02-28-2014 09:31 AM |
| When do you plan to get your BRZ? | switchlanez | BRZ First-Gen (2012+) — General Topics | 33 | 08-16-2013 01:25 PM |
| Reputable tuners in GTA | Philly | CANADA | 10 | 07-11-2012 06:38 PM |
| Tuners Delight: 2013 Scion FRS | FRSDREAMER | Scion FR-S / Toyota 86 GT86 General Forum | 158 | 03-22-2012 08:09 AM |
