Old 11-22-2012, 10:40 AM   #29
Gardus@Supersprint
Drives: Clio TCE
Wow I never thought E85 made such a difference.
I'm really looking forward to see a car with E85, the correct tune and our headers.
Gardus@Supersprint is offline   Reply With Quote
Old 11-22-2012, 11:23 AM   #30
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Yea me either..I didnt really know about e85 like that until the tune came out. Im buying an exhaust, headers, and the e85 tune by march of next year. Im hoping to hit past 200hp. Heres the graph from that dyno day on 2forme's car. just for reference on 93w/intake/exhaust/tune he hit 179..big difference with e85
brichard0625 is offline   Reply With Quote
Old 11-22-2012, 11:30 AM   #31
Gardus@Supersprint
Drives: Clio TCE
We don't have E85 in Italy so we won't be able to test a similar tune on our dyno.
Old 11-22-2012, 11:47 AM   #32
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
You should get similar results if you tune for Race Gas. E-85 is just a inexpensive, High-octane alternative. There's no real magic in it.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 11-22-2012, 01:46 PM   #33
2forme
I think headers will be the key to making near 200whp on 93. If we can get a good set of headers to free up the top end (above 6500) and carry that torque a little longer, 200whp should be within reach.
Old 11-22-2012, 02:50 PM   #34
fatoni
Originally Posted by 2forme View Post
When you consider how fast the engine bay heat soaks on this car, it nullifies that effect. Look at the AIRAID dynos and the temperature testing I've done on them. They are around the same length as an Injen.
Also the AFE is the same length but pulls colder air from the front bumper.
I did over 60 dyno pulls when I did my intake reviews. There was no lying or fibbing. Hell, I even posted the dyno files themselves for people to view in WinPEP.
The car made 174 with just an SRT exhaust. That seems in line with everyone's results. Hit 180 with SRT/AFE/Tune. Hit 200 with SRT/AFE/E85/Tune. That's SAE corrected. STD made a few HP more. If you'd like the files let me know and I'll gladly send them to you because transparency.
if the intake is just as long as a cold air i dont really think we can call it a short ram.
Old 11-22-2012, 06:41 PM   #35
2forme
Well whatever you call it, it most certainly isn't a cold air intake. It sucks in hot air. Hot air intake?
Old 11-22-2012, 07:49 PM   #36
fatoni
haha im sure if they marketed that well enough they could get someone to buy it. you obviously have more knowledge than i do regarding the matter. my only argument was that the shorter the intake and the less volume it contains allow a short ram to breathe more air as the rpms increase. one of the nice advantages of a cold air is the higher intake speeds at lower rpms but that can cause issues at the top end. i guess we have to wait and see what happens as the aftermarket evolves. im glad the cold air worked out for you and from the sounds of it, its one of the better intakes on the market. thanks for sharing your knowledge.
Old 11-22-2012, 07:58 PM   #37
2forme
You're absolutely right. We are lucky with our intake placement to not need super long tubes for a CAI. It's no problem. I just want to make sure the data is out there
Old 11-23-2012, 04:59 AM   #38
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Ok I have to say ... people not getting that E85 (which is essentially 98 octane ((using r+m/2 aka the US standard)) at MINIMUM), will help make power on a 12.5:1 compression motor.... is uh, well surprising to say the least.
E85 is the SINGLE BIGGEST factor.
That being said, I'd be willing to bet that at sea-level on a decent temp day (55-65 degrees, not excessive humidity), a car with an intake/pulley/header/exhaust and e85 tune would make around 210whp.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 11-23-2012, 05:11 AM   #39
Gardus@Supersprint
Drives: Clio TCE
Wait a minute, E85 is like 98/100 ron fuel (euro-spec)?
We do all our dyno test with 100 ron fuel...98 is reccomended even on the fuel cap here.
I dont think a tune would do much of a difference as the stock map is already able to adapt...
Old 11-23-2012, 05:54 AM   #40
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
E85 in france is in between 105 and 110 RON depending on the season
because in winter it's more E75 ( 75 % ethanol)
Mars2 is offline   Reply With Quote
Old 11-23-2012, 05:56 AM   #41
Mars2
plus at stochio you burn more of E85 per stroke making it give you more energy out of each stroke about 5% by itself without using the ability to advance timing because of the High Octane
The Following User Says Thank You to Mars2 For This Useful Post:
brn12345 (11-23-2012)
Old 11-23-2012, 05:58 AM   #42
Mars2
very documented thread about E85
http://forums.nasioc.com/forums/showthread.php?t=803341
2forme (11-23-2012)
Bought it Friday tracked it Sunday!! NC Miata battle video inside... track_warrior Tracking / Autocross / HPDE / Drifting 311 02-28-2014 09:31 AM
When do you plan to get your BRZ? switchlanez BRZ First-Gen (2012+) — General Topics 33 08-16-2013 01:25 PM
Reputable tuners in GTA Philly CANADA 10 07-11-2012 06:38 PM
Tuners Delight: 2013 Scion FRS FRSDREAMER Scion FR-S / Toyota 86 GT86 General Forum 158 03-22-2012 08:09 AM
