#29 |
Drives: Clio TCE
Wow I never thought E85 made such a difference.
I'm really looking forward to see a car with E85, the correct tune and our headers. |
#30 | |
Drives: 2013 Scion Frs(Scarlet)
#31 |
Drives: Clio TCE
We don't have E85 in Italy so we won't be able to test a similar tune on our dyno.
#32 |
That guy
Drives: Ultramarine mt FR-S
You should get similar results if you tune for Race Gas. E-85 is just a inexpensive, High-octane alternative. There's no real magic in it.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#33 |
I think headers will be the key to making near 200whp on 93. If we can get a good set of headers to free up the top end (above 6500) and carry that torque a little longer, 200whp should be within reach.
#34 | |
#35 |
#36 |
haha im sure if they marketed that well enough they could get someone to buy it. you obviously have more knowledge than i do regarding the matter. my only argument was that the shorter the intake and the less volume it contains allow a short ram to breathe more air as the rpms increase. one of the nice advantages of a cold air is the higher intake speeds at lower rpms but that can cause issues at the top end. i guess we have to wait and see what happens as the aftermarket evolves. im glad the cold air worked out for you and from the sounds of it, its one of the better intakes on the market. thanks for sharing your knowledge.
#37 | |
#38 |
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
Ok I have to say ... people not getting that E85 (which is essentially 98 octane ((using r+m/2 aka the US standard)) at MINIMUM), will help make power on a 12.5:1 compression motor.... is uh, well surprising to say the least.
E85 is the SINGLE BIGGEST factor. That being said, I'd be willing to bet that at sea-level on a decent temp day (55-65 degrees, not excessive humidity), a car with an intake/pulley/header/exhaust and e85 tune would make around 210whp.
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
#39 |
Drives: Clio TCE
Wait a minute, E85 is like 98/100 ron fuel (euro-spec)?
We do all our dyno test with 100 ron fuel...98 is reccomended even on the fuel cap here. I dont think a tune would do much of a difference as the stock map is already able to adapt... |
#40 |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
E85 in france is in between 105 and 110 RON depending on the season
because in winter it's more E75 ( 75 % ethanol) |
#41 |
plus at stochio you burn more of E85 per stroke making it give you more energy out of each stroke about 5% by itself without using the ability to advance timing because of the High Octane
| The Following User Says Thank You to Mars2 For This Useful Post: | brn12345 (11-23-2012) |
#42 |
very documented thread about E85
http://forums.nasioc.com/forums/showthread.php?t=803341 |
| The Following User Says Thank You to Mars2 For This Useful Post: | 2forme (11-23-2012) |
| Bought it Friday tracked it Sunday!! NC Miata battle video inside... | track_warrior | Tracking / Autocross / HPDE / Drifting | 311 | 02-28-2014 09:31 AM |
| When do you plan to get your BRZ? | switchlanez | BRZ First-Gen (2012+) — General Topics | 33 | 08-16-2013 01:25 PM |
| Reputable tuners in GTA | Philly | CANADA | 10 | 07-11-2012 06:38 PM |
| Tuners Delight: 2013 Scion FRS | FRSDREAMER | Scion FR-S / Toyota 86 GT86 General Forum | 158 | 03-22-2012 08:09 AM |
