Old 11-16-2012, 12:35 PM   #1
TRBO2NR
Speed Racer
TRBO2NR's Avatar
Drives: 94' Supra TT 6MT, 11' Subaru WRX
Fuel overflowing when filling...
I have filled my car up with gas twice so far since I have had it and both times the pump overflows and spews out all over my car when using the auto stop feature that is on the pump handles... Is anyone else having this issue? I thought maybe it was the particular pump I used, but I tried a different pump (at the same station) and it did it again! I always make sure I go in and buy a bottle of water to dump on my car to wash off the fuel so that it doesn't wreck my paint though.
If I am the only one that seems to be having this problem, I guess I will have to try a completely different gas station next time to see if it repeats or not. If it still persists, I guess I will be making a trip to the dealer to see if maybe the overflow hose is clogged or something...
1994 Toyota Supra TT 6spd - BPU+++
2011 Subaru WRX Premium Hatchback
2013 Scion FR-S 6MT Whiteout *SOLD
TRBO2NR is offline   Reply With Quote
Old 11-16-2012, 01:05 PM   #2
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
This has happened to me once with a pump that had the big accordian style boot on it. It seems every gas station in my area installed those. They all mysteriously disappeared after a month. I assume it was a common issue.
Do the pumps have the accordian rubber boot on them?
I think it prevented the nozzle from going deep enough in the filler for the auto shutoff to work properly.
TOMIMOTO is offline   Reply With Quote
Old 11-16-2012, 01:25 PM   #3
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I've read posts by a few people saying that this happened. I filled up mine 15 times so far and this didn't happen. If I were you, I would try another gas station.
Old 11-16-2012, 01:32 PM   #4
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
I had this happen on my second or third fillup ever with this car. I stopped going to the station that it happened at since it seemed like my car didnt like the fitment of that particular nozzle.
Though I notice with different pumps, sometimes I really have to cram the fucking thing into the car to get a good seal.
Most (all?) gas pump nozzles have sensors to stop the flow of gasoline once the fuel inside the tank gets to a certain level, so if the nozzle isnt fully seated down into the fuel filler neck then this overflowing can happen.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 11-16-2012, 01:37 PM   #5
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Do you always set it with the auto feature so you can walk away? Have you tried doing it manually to see if it would stop if you were holding it instead?
Nevermore is offline   Reply With Quote
Old 11-16-2012, 02:35 PM   #6
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
I have had this happen and it sucks. find a station with a better pump and stick with it if you can. on a side fuel related note when the pump stops dont try to squeeze in a little more fuel to even out the price. doing this soaks the evap canister and over time will destroy it causing a check engine light.
dorifuto is offline   Reply With Quote
Old 11-16-2012, 03:30 PM   #7
TRBO2NR
Speed Racer
TRBO2NR's Avatar
All,
Last time I tried it without using the trigger lock, but just had it shut off while holding it and it still did it... It did have the accordian style boot on it, but I purposely held the nozzle in as deep as possible since it overfilled the time before and I was trying to avoid it. That attempt failed... I guess based on what others are saying, I will have to find a different station, but that sucks since this is one station that always seems to be the cheapest in town and I purposely make a trip out of my way to get to it... Oh, and no I don't try to top it off after it automatically stops.
At least I know I am not alone on this one... Seems like a bad design to me if others have this exact issue.
Old 11-16-2012, 07:57 PM   #8
sf86
sf86's Avatar
Drives: Red Scion FRS AT
I pump gas many times already at many different places in the city and So far so no overflow.Try a different gas station.
sf86 is offline   Reply With Quote
Old 11-16-2012, 08:06 PM   #9
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
i dont know how many times ive filled up.. 7k miles worth of fuel in my car and i havent had this happen yet.. and in some of those po-dunk towns in the middle of no where texas still didnt have a problem... here in cali they all have the vapor seal nozzle.. it was weird filling up with out one.. and i never put enough tanks of fuel in to take advantage or feel the difference of 93 over or 91
Gixxersixxerman is offline   Reply With Quote
Old 11-16-2012, 09:08 PM   #10
roddy
roddy's Avatar
Drives: '13 Ultramarine
I usually listen for the "gurgle" of gas as it is getting near the top, then ease off on the nozzle. I don't recall spilling any on this car.
Old 11-16-2012, 09:21 PM   #11
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
happens to me at certain stations only. i think its nozzle related
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 11-16-2012, 09:48 PM   #12
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Never had this problem before as I always manually gas it instead of using the autofill function. Was kinda curious so I decided to Youtube it happening...
Kinda like this?...
[ame="http://www.youtube.com/watch?v=jc8WiocXXEE"]2007 JK Gas Tank Overfill - Auto-Fill - YouTube[/ame]
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 11-16-2012, 11:41 PM   #13
gily25
Drives: Silica BRZ 6MT
Daj I didn't watch your vid but I can see its a wrangler. It happens with my Jeep, the little car has been fine. It's a combo of the filler neck angle and the rubber neck of the nozzle. The auto shut off works on suction/vapor lock so if you don't have the right seal it blows over. With the jeep I just do a manual fill no problems...if you poke on any of the jeep forums you can probably find a lot of write ups (www.jeepforum.com)
gily25 is offline   Reply With Quote
Old 11-16-2012, 11:49 PM   #14
Texas BRZ
Imperfect
Texas BRZ's Avatar
Drives: 2025 C8 Z06s and more!
Hasn't happened to me unless I'm intentionally trying to top it off after the auto-stop (which isn't a good idea, therefore I try not to do it anymore).
I don't know what to say in regards to the OP's situation though...
Texas BRZ is offline   Reply With Quote
What fuel do you put on your FRS/BRZ? dhpinoy Southern California 61 06-15-2018 06:35 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
FUEL JDMSushi AUSTRALIA 23 07-19-2012 12:01 AM
I was planning on just filling out paperwork... Longhorn248 BRZ First-Gen (2012+) — General Topics 34 06-05-2012 08:31 PM
E85 Fuel? Siriusly.Andrew Scion FR-S / Toyota 86 GT86 General Forum 60 02-11-2010 06:00 PM
