Old 11-15-2012, 09:08 AM   #71
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by TemeCal View Post
I tried to program my new TPMS IDs, but was unsuccessful. I'm able to scan my TPMS receiver, view the current TPMS IDs, tire pressure, etc... However, when I try to program my new IDs, I get the following error:
"Terminate initialization by connecting TC and CG of the DLC3 for 30 seconds. Then try the registration procedure again."
I found a TSB for other Toyota vehicles, which say to use a jumper wire from pin 13 (TC) to pin 4 (CG) on the DLC3. Has anyone been successful reprogramming the TPMS IDs? Did you have to go through this?
I had the same problem with programming TPMS. I have an ATEQ tool for doing it though so I haven't messed around with it much.
Old 11-15-2012, 09:11 AM   #72
neutron256
neutron256's Avatar
Originally Posted by Foobar View Post
Not sure if Techstream recognizes Bluetooth OBD interfaces. It may require a special driver. I know the Mini VCI cable I have required its own drivers (J2534 - Mongoose Pro) before Techstream would recognize it as an acceptable VIM interface. I have an ELM Bluetooth module as well, and I can't find a way to get it to work with Techstream. Let me know if you find the appropriate drivers.
Techstream is not using the OBDII bus. Even though it usese the same physical connection it's connecting to Toyota's propritary bus, and requires the Mongoose, or other special cable.
Old 11-15-2012, 09:42 AM   #73
Foobar
SLO NO MO
Foobar's Avatar
Yeah, I found that same info. I'd rather not start shorting pins on my OBD2 until someone else confirms that it's not gonna fry anything
Old 11-15-2012, 10:57 AM   #74
xcelir8brz
Drives: 2013 BRZ Limited
Exactly. Different command set. Found this out last night using my BT ELM327.
xcelir8brz is offline   Reply With Quote
Old 11-15-2012, 11:36 AM   #75
neutron256
neutron256's Avatar
I'll try it when I have some time. I'm not that worried about it. Did they have a suggested method for running the jumpper?
The Following User Says Thank You to neutron256 For This Useful Post:
TemeCal (11-15-2012)
Old 11-15-2012, 11:57 AM   #76
Foobar
SLO NO MO
Foobar's Avatar
Looks like it's just a straight wire that connects the two pins. Here's the TSB that has diagrams and instructions: http://www.toyotapart.com/TIRE_PRESS...SB-0084-09.pdf
Old 11-15-2012, 12:24 PM   #77
TemeCal
Drives: 86
That's the same TSB I found.
@neutron256 - let us know how it goes. Thanks!
TemeCal is offline   Reply With Quote
Old 11-15-2012, 12:32 PM   #78
xjohnx
Grip>Slip
xjohnx's Avatar
hell, a paperclip could work.
Old 11-15-2012, 02:05 PM   #79
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Originally Posted by 20valvewynn83 View Post
the reason i ask is because toyota sells it to their techs and i wasnt sure how it comes because i want one. I have been with Toyota for over 10 years
Anyone can buy it from http://techinfo.toyota.com
The yearly subscription rate is a tad steep unless your have a shop with a heavy Toyota workload however.
To the OP: I also have the software and have been using it since it came out, and I used the old TDT "gameboy" for 10 years before that.
FYI you cannot reflash an FRS with the Toyota software, but you can use the drewtechnologies MFC Pro cable and different software programs.
Boosted2.0 is offline   Reply With Quote
Old 11-15-2012, 02:14 PM   #80
Boosted2.0
Boosted2.0's Avatar
Putting TC to CG is fine - its used to handshake ECUs and put things in test mode on pretty much every Toyota for the last 15 years
The Following User Says Thank You to Boosted2.0 For This Useful Post:
Old 11-16-2012, 03:35 PM   #81
developer
Drives: BRZ Limited
Did anyone get this working?
developer is offline   Reply With Quote
Old 11-16-2012, 06:03 PM   #82
neutron256
neutron256's Avatar
Nope tried the TSB fix today multiple times no luck. I suspect its an issue with the knockoff Chineese cable.
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
developer (11-16-2012), soros151 (11-16-2012)
Old 11-16-2012, 06:50 PM   #83
Foobar
SLO NO MO
Foobar's Avatar
I'll try it with mine this weekend. If it doesn't work, I'm ordering the Quickset tool for $150.
Sent from my Galaxy Nexus using Tapatalk 2
Old 11-16-2012, 06:55 PM   #84
developer
Drives: BRZ Limited
I just ordered the ATEQ Quickset. I have to do my wife's care anyway (Nissan, Murano). The Quickset is back ordered until January, everywhere.
Production Toyota FT-86 Details and Design Previewed by Toyota Sports Vehicle Boss ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 541 11-18-2011 09:04 PM
Toyota FT-86 G's Sport Concept moved to Toyota Mega Web showroom at Odaiba Kenji FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 05-02-2011 01:11 AM
Toyota FT-86 G-Sport Concept car displayed with AE86 at Toyota Amlux, Tokyo Kenji FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 03-08-2010 11:09 PM
Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! Nemesis Scion FR-S / Toyota 86 GT86 General Forum 128 02-19-2010 11:36 AM
