Old 11-15-2012, 02:12 AM   #15
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
was any of the non-strengthened engines blown yet?
we all saw crazy psi taken by the stock engine with ease
why forge then?
I know it's a matter of longtime reliability, but still... WHY?
MSTiFK8R is offline   Reply With Quote
Old 11-15-2012, 02:17 AM   #16
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
why forge then?
Because Racecar.
TyperRspec789 is offline   Reply With Quote
The Following 2 Users Say Thank You to TyperRspec789 For This Useful Post:
dsmx17 (11-16-2012), EN2_Squirrel (11-17-2012)
Old 11-15-2012, 02:40 AM   #17
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
why forge then?
"I know it's a matter of longtime reliability..." Lol you answered your own question
Freeman is offline   Reply With Quote
Old 11-15-2012, 02:58 AM   #18
serialk11r
Drives: '06 AM V8V Coupe
Increased rod length...what's the new rod length? Those stock pistons didn't look like they had much room to move the wrist pins up.
Old 11-15-2012, 04:54 AM   #19
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
I think his question was has anyone blown up a stock engine yet due to mods.
pixel67 is offline   Reply With Quote
Old 11-15-2012, 04:56 AM   #20
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
I know who i'm calling if i blow my motor, or get a bad "CEL"...
Ravenlokk is offline   Reply With Quote
Old 11-15-2012, 07:10 AM   #21
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Right, but another question was "why forge" and that one he did answer it "for long time reliability"
Old 11-15-2012, 07:18 AM   #22
Captain Insano
why forge then?
There is a list of toasted engines in the CEL thread due to a crappy factory tune and other factors.
http://www.ft86club.com/forums/showthread.php?t=15577
So yes, these blocks can go even without modifications!! Obviously, if you get some detonation on a stock block, it's going to be alot more brittle than forged internals.
Don't you fret good sir. Some of the aftermarket fun will result in toasted blocks. It's inevitable. :-)
Captain Insano is offline   Reply With Quote
The Following User Says Thank You to Captain Insano For This Useful Post:
MSTiFK8R (11-15-2012)
Old 11-16-2012, 08:10 AM   #23
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
why forge then?
1.) Reliability as you stated
2.) It can be done, like I do on one of my EJ25 lines, and build it for a realistic power level and lighten the internals...instead of chucking beefy pistons and rods rate for 1200 hp into a car that might only run 500.
3.) This is more of to keep things in perspective but note of the boosted cars out there making good power, they are shop cars where someone is actually watching data like a hawk for various reasons. When you have Joe Blow Customer that comes up and wants the same power but doesn't have the same knowledge or keen eye on data, I suspect you'll see more popped engines from boost. The same thing already happened when the WRX and then STi's came to the market.
Originally Posted by TyperRspec789 View Post
Because Racecar.
Or that
Always a possibility, although in this case, it is probably only done as technique to reduce reciprocating mass, like I do with the forementioned EJ25 line (Honey Badger).
-Micah
3MI Racing is offline   Reply With Quote
The Following User Says Thank You to 3MI Racing For This Useful Post:
MSTiFK8R (11-16-2012)
Old 11-16-2012, 12:13 PM   #24
arghx7
Drives: car
Longevity... well it depends how you look at it. If you are getting strengthened internals, you are looking at better protection against a catastrophic failure. Typically with these aftermarket pistons though you have increased blowby and wear on the cylinder walls.
In a heavily modified boosted application though protection from catastrophic failure becomes a higher priority.
Old 11-16-2012, 01:34 PM   #25
dabocx
dabocx's Avatar
Drives: Scion FRS
The stock block is making huge numbers on e85 or race gas.
On 93 octane i think the compression ratio might be limiting
dabocx is offline   Reply With Quote
Old 11-16-2012, 03:29 PM   #26
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
HKS headgaskets anyone? Got these for a customer. Should have some nice pistons and rods for it on Monday
Also got him a Koyo Racing radiator
No Limit Motorsport is offline   Reply With Quote
Old 11-16-2012, 09:45 PM   #27
OrbitalEllipses
Drives: Attitude
Originally Posted by WolfsFang View Post
Why is it open deck? If its forged should it be closed or atleast mid deck?
I believe most closed deck built Subaru boxers have run into overheating issues. Phil at Element Tuning would know a lot more about that; he champions the open deck block.
Old 11-17-2012, 08:56 PM   #28
cf6mech
Drives: FRS Silver LS1 swapped.
I'm in process to going forged, waiting on Aria's custom pistons right now which will also lower compression from 12.5 to 9 to one,....track car and yes its for longevity with FI.
cf6mech is offline   Reply With Quote
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? Kostamojen Engine, Exhaust, Transmission 90 03-20-2022 06:05 PM
FBM/Arias Forged Pistons FullBlown Forced Induction 35 10-22-2012 07:05 AM
MMMMMM....forged pistons jadewbj Forced Induction 23 10-08-2012 06:46 PM
STi BBS Forged 18 x 8.5 ScottDRFT Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-10-2012 05:02 AM
FA20 Shortblock Ishii Motors Engine, Exhaust, Transmission 16 08-04-2012 09:28 AM
