Old 11-14-2012, 08:27 PM   #71
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
Originally Posted by jamal View Post
Rear rotors have to be for an 08+ STi with re-drilled holes. wrxbrakes carries them.
The 04 sti 5x100 rotors DO NOT work.
Where is this place at? Is it in socal?
mrha is offline   Reply With Quote
Old 11-14-2012, 08:57 PM   #72
RYU
RYU's Avatar
Drives: really slow...
pics? pics? pics?
RYU is offline   Reply With Quote
Old 11-14-2012, 09:22 PM   #73
jamal
jamal's Avatar
Drives: Legacy GT
East coast, they're a big online vendor for subaru brakes.
And actually the DBA rear rotors are dual-drilled. pn 42656 (as long as it ends in -10).
jamal is offline   Reply With Quote
Old 11-15-2012, 01:15 AM   #74
mrha
#1819
mrha's Avatar
Ah crap I tried taking out the screw to switch the bleeder and completely tore it up. I'm super screwed now.
The Following User Says Thank You to mrha For This Useful Post:
chanomatik (12-16-2013)
Old 11-15-2012, 08:42 PM   #75
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
May I see pics? Also which rotors did you use?
I used 08-12 STI DBA 4000 T3 rotors. As long as the DBA rotors have a -10 at the end of the part number, then they are dual drilled for 5x100 and 5x114.3. Parking brake works great. I got a great deal on the rotors and pads from a vendor on NASIOC. I will get some pics of the brakes this weekend.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
AyJay (04-16-2014), chanomatik (12-16-2013), mrha (11-15-2012)
Old 11-15-2012, 08:44 PM   #76
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Mine were used but in great condition. I just used a 3/8" socketed allen head and a 3/8" breaker bar and the screws came out with no issues. They were all red loctited, but still came out with no stripping of the allen head.
Old 11-15-2012, 10:41 PM   #77
mrha
#1819
mrha's Avatar
I used a socketed allen head too but it stripped. I have been having bad luck with any allen holes that are on this car.
Old 11-24-2012, 11:09 AM   #78
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
what size wheels and width and offset would you need to clear the brembos ? it may make or brake the wheels i want to order
DanoFA20 is offline   Reply With Quote
Old 11-24-2012, 11:22 AM   #79
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Use heat.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-25-2012, 12:56 AM   #80
bpracer
Drives: Asphalt FR-S
Some brake comparisons
So, people were getting a little hot and bothered by the possible comparisons, capabilities and drawbacks of various setups.
The STI setup is a bit heavy but will likely work well with some light weight 2 piece rotors. The AP stuff uses more "narrow band" rotors which should also work "better" than the STI stock stuff in the sense that the thermal balance of the inner radius and outer radius of the rotor will be more similar. An STI rotor has more swept area in its design but the inner radius is of decreasing benefit while adding a lot of weight. These weight numbers were taken from Essex, GiroDisk and I cannot verify them.
If you can really get STI Brembo calipers from RockAuto for less than $150 each you can make yourself a good brake setup albeit you may want some pricey ($700/pr) two piece rotors or they will weigh more than stock. The rotating mass is still likely heavier than stock, just me eyeballing things.
------------STOCK-- STI---ESSEX Sp---ESSEX End---STI 2pc Rotor
Caliper----- 11.6-- 8.2----- 5.6---- 5.6 --------- 8.2
Pads--------- 1.8-- 2.7----- 2.4---- 2.4---------- 2.7
Rotor------- 17.0-- 20.5--- 12.2--- 17.6--------- 16.5
Misc--------- 0.8-- 0.8----- 0.8---- 0.8---------- 0.8
Total------- 31.2-- 32.2--- 21.0--- 26.4--------- 28.2
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 11-25-2012, 01:07 AM   #81
DanoFA20
Shift Down
DanoFA20's Avatar
If you can really get STI Brembo calipers from RockAuto for less than $150 you can make yourself a good brake setup albeit you may want some pricey ($700/pr) two piece rotors or they will weight more than stock. The rotating mass is still likely heavier than stock, just me eyeballing things.
and i thought i was the only one who noticed the remanned rock auto Brembos for cheap.
Old 11-25-2012, 01:26 AM   #82
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Use heat.
And LOTS of WD-40
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 11-25-2012, 01:54 AM   #83
mrha
#1819
mrha's Avatar
Those have been out of stock for the last two months. I got my set from good ol craigslist.
Old 11-25-2012, 05:23 AM   #84
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I contacted Rockauto about the remanned Brembos, and they are not Brembos. The A-1 Cardone calipers are a Tokico casting caliper.
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
