| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: FR-S, NA8, S13
#16 |
Drives: '24 GR86
Which is why you man up and go lower in offset :P
#17 |
Drives: 2006 STi
haha word ^
#18 |
Drives: 2013 genesis rspec
#19 | |
You really are one negative cat though and always have to make yourself out to be smarter then everyone else lol. You clearly wrote toe but couldn't take the time to write camber? Why even write or not write either? It's pretty obvious the way you wrote it that someone quickly reading it would get it wrong. Maybe you just wanted a reason to make yourself feel better lol. |
#20 |
Drives: Toyota 86 GTS
I think most people would agree that 18x9.5+38 is not a 'weak' offset as you say on an 86.. if it were an S14 then yes it would be weak. It's all relative. And for the record I also have an S13 with stock guards on 17x10+4 and 18x10+11.
#21 | |
Señor Member
Drives: white BRZ 6MT
and poke? lol pretty sure you're in the mexi set if you run 9.5 and like +20 or 15 or something on stock I agree though, go lower offset with coils
| The Following User Says Thank You to dori. For This Useful Post: | JoeBoxer (11-14-2012) |
#22 | |
Curious cat.
Drives: 86 GT base M/T - Red
Camber doesn't kill tires, camber AND toe does. Also reckon that @ephoto has nailed the fitment issue. Listen to this man. If you go lower offset that his setup (even with hella camber) you'll poke, will have issues fitting rubber and might need to do bodywork. If you want more rubber then you'd need to go higher offset. I'm on 8 inch wide Ultraleggeras with a 38 offset, 225/40/18s and around 1.5 camber all around on coils. Tires are tucked in to my arches quite a bit. Definitely room to run a slightly more aggressive offset it I wanted...guessing mid to low 30s with the same camber & tires, give or take depending on rim width.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#23 |
Yeah but you have remember not all wheels come in desired sizes and pcd. There isn't that many selections at the minute. It's different with 3p wheels because you can customise what size you want.
#24 | |
Señor Member
#25 | ||
.im just used to club4ag.. where not everyone is a trolling **** head. so tired of being on forums like nasioc, zilvia and everything is a negative rseponse looking for a reaction.. so i responded to this guy the same way he responded to me... with a tone of superiority and knowledgeability. |
#26 |
Señor Member
oh god, zilvia is just the worst. you'd think somebody killed each posters family when a question is asked
#27 |
Drives: Raven Scion FR-S
bump
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#28 | |
Drives: Subaru BRZ, Nissan GT-R, BMW X5D,
thnx |
| Wheel Directory: SSR Professor SP3 18x9.0 +24 / 18x9.0 +20 | RZ86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 05-18-2013 04:14 AM |
| Anyone running with Nitrous? | JDMenrique | Forced Induction | 29 | 10-21-2012 10:02 PM |
| what height are you running | Im_SPEED | Tracking / Autocross / HPDE / Drifting | 0 | 09-27-2012 11:29 PM |
| F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires | SsmoothyMonster | Wheels and Tires | 17 | 09-24-2012 01:52 AM |
| Running 19's | SocalBurt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 09-04-2012 02:45 PM |
