Old 11-10-2012, 07:30 PM   #1
empower-auto
Kouki-Monster
empower-auto's Avatar
Arrow For those running 18x9.5 all around
1. What offsets are you using?
2. What tire size are you running in the front?
3. What is your suspension / alignment setup?
4. Finally .. got pictures?
Cheers
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
Asphaltfrs1 (11-10-2012)
Old 11-10-2012, 07:37 PM   #2
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I think you almost have to be on coilovers so they won't hit the strut, by my math you could probably do it with a +30 offset but that would poke a little more than i would want. I would think a +40 would look better but would require coilovers...
Old 11-10-2012, 07:40 PM   #3
empower-auto
Kouki-Monster
The setups I have seen so far are +35, +38 and are pretty awesome. 1 was running 225/40 all around which I don't like, the other 245/35 which is ideal for me.
I'm just trying to get as much info in before these wheels get bolted up next season.
Rich Anderson
EMPOWER AUTO
Old 11-10-2012, 07:52 PM   #4
JoeBoxer
JoeBoxer's Avatar
I agree 225 is way too small for 9.5's. +38 on a 245 or even 255/35 should be good.
Old 11-11-2012, 07:15 PM   #5
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
I am about to order 18x9.5+38 and run 245/35R18 rubber. Coil overs will be installed.
I have driven a set up with 18x9.5+30 running 225/40 and the poke was too much for my taste.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 11-11-2012, 07:38 PM   #6
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
If youre gonna run a 9.5 wide, please put atleast 255's on them. idk why people love buying tires too narrow for the wheels. Just buy a more narrow wheel if you only want to run a 245 or smaller.
Tansey86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tansey86 For This Useful Post:
coyote (11-11-2012), DannyFRS (07-03-2024)
Old 11-11-2012, 08:49 PM   #7
ebphoto
Drives: FR-S, NA8, S13
18x9.5 +25
225/40 (oh no!... must be because im butt hurt right?? ...)
bc coilovers f: -3 0 toe r: -3 0 toe (more aggressive alignment is next, had a roadtrip to ohio so went conservative... will be getting rear arms instead of the whiteline bushes)
you can run 235s on +30 in the rear.
fronts can fit way more easier.
if you are looking to fit tire though you will need to be in the high 30s or low to mid 40s in offset... but run the risk of touching inward.
ebphoto is offline   Reply With Quote
The Following User Says Thank You to ebphoto For This Useful Post:
dabocx (11-12-2012)
Old 11-11-2012, 09:20 PM   #8
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
I think you meant camber
And you thing -3 is conservative? You will be eating tires...
Car looks good, though
GTB/ZR-1 is offline   Reply With Quote
Old 11-11-2012, 09:26 PM   #9
Paragon
Guest
Posts: n/a
Most wheel faces only look good in the 9in+ versions ie RPF01, TE37s, Kiwamis etc. The car doesn't make enough power to overcome wide grippy tyres hence I have 225/40 on a 9.5+38 and looks and works great
Old 11-11-2012, 10:38 PM   #10
ebphoto
- 3 as in camber with 0 (zero) toe
didnt think id have to spell it out but i should have figured someone would have read it wrong and try and make me feel stupid about it.
also, the big misconception about negative camber is that it will destroy tires... while it is true that it will have adverse effect on tire wear it wont be "eating tires". ( unless you are retarded and run like -6 degrees )
the combination of toe and camber will eat tires.
my 8th gen civic si had -3 front and -2.8 rear camber, and even with bridgestone re01r (low 100s treadwear) the tires lasted extremely long (17k mi)... due to zero toe.
only way it "eats tires" is if you are too stupid to have it aligned properly.
..and i wasnt saying conservative in regards to camber... i was speaking of toe.
the car will be set up with more caster and toe out in the front for better response/turn in feel.
rear will be left with zero toe as it already gets out enough as is. ( car is my DRIFT car.. NOT grip car. )
ill leave my thoughts out on your first comment because saying anything further about it would be petty on my part.
Old 11-12-2012, 12:22 AM   #11
Stance86
Drives: Toyota 86 GTS
Has anyone fitted 18 x 9.5 + 38 with lowering springs only???? Anyone know if it will fit?
I just ordered 18 x 9.5 + 38 and I am on Eibach springs only... will they fit? (concern is wheel touching spring) I want to run 245/35 on the front and 255/35 on the rear.. HEEEEELLLLLLLPPPPPPPP..
Unrelated but I can't post up a new thread? Any ideas why?
Stance86 is offline   Reply With Quote
Old 11-12-2012, 12:30 PM   #12
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
A couple threads down, somebody is running 18x9.5 +38 on 245/40 tires and the same springs. Fits fine.
But you screen name is Stance86. Can't have that and run those weak offsets
Ebphoto did it right. I still have yet to see one that looks as good as his.
The Following User Says Thank You to TylerLieberman For This Useful Post:
dabocx (11-12-2012)
Old 11-12-2012, 12:38 PM   #13
JoeBoxer
JoeBoxer's Avatar
If you are talking about the Grids, that's what he is running in the rear, the fronts are 8.5's. I don't think 9.5 +38 will clear the factory strut up front.
Old 11-12-2012, 12:54 PM   #14
djdnz
1337
Drives: 2013 BRZ WRB S/C
Because you are new, probably need 10 posts would be my guess
djdnz is offline   Reply With Quote
Wheel Directory: SSR Professor SP3 18x9.0 +24 / 18x9.0 +20 RZ86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 05-18-2013 04:14 AM
Anyone running with Nitrous? JDMenrique Forced Induction 29 10-21-2012 10:02 PM
what height are you running Im_SPEED Tracking / Autocross / HPDE / Drifting 0 09-27-2012 11:29 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
