Old 11-12-2012, 08:05 PM   #169
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Same here, haha. I just haven't found the time to do it.
Old 11-13-2012, 03:22 PM   #170
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I did it on mine. Looks so good (check out my journal in my signature for some photos)
Old 11-20-2012, 08:49 PM   #171
celek
Resident Gear Head
celek's Avatar
Kill that chrome I like the look
Was thinking about tint not sure yet
celek is offline   Reply With Quote
Old 11-27-2012, 04:43 AM   #172
itisthumper
itisthumper's Avatar
Drives: WRB BRZ MT
How difficult is it to spray my taillights red? I really dont want to screw up
itisthumper is offline   Reply With Quote
Old 12-05-2012, 01:33 PM   #173
xxscaxx
Drives: 2013 SWP BRZ
Just wanted to bump this thread with an update.
I have been planning on spraying my taillights red, and after contacting a member and doing some research, I decided to go with Metalcast red, and a Urethane clear coat called Spraymax from automotivetouchup.com.
I wanted to test out both the paint color of metalcast, and the urethane coating of the clear. My little bro needed to replace his headlights on his bugeye so I used his old headlight as a test mule.
I sanded down his headlight with 800 grit, washed/cleaned it, then hit it with 3 coats of metalcast red. after the 3 coats were down, I then used 2000 grit sandpaper and wetcoated to get out any dust/imperfections. I then sprayed 2 coats of this urethane clear coat down.
I have not wetsanded the clear, and look how damn good this stuff came out. Its basically like glass and I haven't even touched it with polish. There is such a minimal amount of orange peel that you have to really stare at the damn thing in the right light to see it (basically non existent). There are a few minor spots that I think I could have avoided just being in a more paint friendly environment, but for someone who isn't too keen on sanding this stuff will be perfect for you. Not only that, i've used clear coats in the past and this stuff just feels nice and thick. The only downside to this stuff is it has a 24 hour shelf life after mixing. Not knowing this, I mixed it together (its a two part spray can, you have to push a button on the bottom and it mixes together), and now wasted a full can of clear just to do a test light.
Its a little expensive, but I feel that outside of bringing your taillights to someone to get clearcoated at a shop for you, this is the BEST DIY option for clear.
I have to now wait for another can of clear, so I will be doing my taillights next weekend. Had plans on doing them this weekend, but now I can't since I broke the seal on the one I have. The darker spot on the headlight is from the inside light bezel being painted, so the lighter area will be what my entire tail lights will look like when finished.
xxscaxx is offline   Reply With Quote
Old 12-10-2012, 01:28 AM   #174
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
i wanna try this but im afraid ill screw up. can i remove the paint/ tint if i dont like it? dont wanna buy a new set of tails..
Dispect is offline   Reply With Quote
Old 12-16-2012, 05:53 AM   #175
DarrenDriven
NW Region Moderator
Lacquer thinner will remove the paint quickly. I don't know if this will have any long-term effects for the plastic lens, but I had to redo my lights once (on my truck) and had no issues removing the paint.
Old 12-16-2012, 06:06 AM   #176
Dispect
Dispect's Avatar
Got it. Thanks. If weather permits ill do mine tmw. Wish me luck haha
Old 12-16-2012, 04:50 PM   #177
Dispect
Dispect's Avatar
Someone pls help. I'm doing it now but j can't seem to release the zip tie catch. Pls help
Old 12-16-2012, 10:17 PM   #178
xxscaxx
use a a pick tool, or a small flat head. Just work them off.
Just finished installing my lights after paint. Will post a pic tomorrow.
Old 12-16-2012, 11:44 PM   #179
Dispect
Dispect's Avatar
i cant idk why. i cant seem to release the catch. can u post pics of u releasing it? thanks!
Old 12-17-2012, 11:46 AM   #180
xxscaxx
I don't think I can capture that on camera, its such a small space to get a pic. Here is a fast drawing explaining in case you don't understand.
Here are my tails:
The Following 3 Users Say Thank You to xxscaxx For This Useful Post:
calis5nest (12-17-2012), suaveflooder (03-09-2013), Tylub (01-20-2013)
Old 12-17-2012, 01:51 PM   #181
KVDB31
KVDB31's Avatar
Drives: 2013 FR-S Asphault
Just cut the wire clips off. It's not absolutely necessary that the wire goes back exactly where you got it from.
KVDB31 is offline   Reply With Quote
Old 12-17-2012, 02:10 PM   #182
Dispect
Dispect's Avatar
Here are my tails:
That's a really helpful drawing. I'll try again later. Thanks
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 10:02 AM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 02:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 03:30 PM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 07:20 PM
