Old 11-12-2012, 02:22 PM   #323
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Some people just don't get it, the problem here is inner clearance not outer. I am about 99% sure it will hit the stock front strut/spring.
The Following User Says Thank You to JoeBoxer For This Useful Post:
gabeg86 (11-12-2012)
Old 11-12-2012, 02:23 PM   #324
just86
just86's Avatar
Drives: 2013 genesis rspec
18x9.5 is fine in the front with coilovers
just86 is offline   Reply With Quote
Old 11-12-2012, 02:37 PM   #325
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
Thanks So to tuck them into the wheel well, I need to run some pretty aggressive negative camber up front, correct?
It is interesting that TRD Japan chooses an 18x7.5 +46 setup with 225/40/18 tires (a mere increase of 0.5" in width and 10mm in tire size) and perhaps they feel that such an upgrade will maintain the optimal handling characteristics? blah im not too sure
brianlo622 is offline   Reply With Quote
Old 11-12-2012, 02:45 PM   #326
JoeBoxer
JoeBoxer's Avatar
Damn none of those offsets are very good, i would prefer a 18x9 +38 all around i think it's pretty close to ideal.
brianlo622 (11-12-2012)
Old 11-12-2012, 03:02 PM   #327
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
The TE37SL's are 18x9.5 +40 5x100. These are the ones with the concave face.The +45 was some disinformation that was spread.
No Limit Motorsport is offline   Reply With Quote
The Following User Says Thank You to No Limit Motorsport For This Useful Post:
JoeBoxer (11-12-2012)
Old 11-12-2012, 03:13 PM   #328
brianlo622
brianlo622's Avatar
Thanks! Is this particular car running 18x9.5 all around? Also, these wheels in the above mentioned dimension comes in the standard pressed graphite color, not just the black edition, correct?
Old 11-12-2012, 03:43 PM   #329
lightdir
Drives: 2013 Raven FRS 6MT
I thought wheeldude had their's on Eibach springs running 18x9.5 with 255/35/18.
lightdir is offline   Reply With Quote
Old 11-12-2012, 04:13 PM   #330
No Limit Motorsport
Yes that is 18x9.5 +40 square setup on these with 235/40 tires.
Yes they come in all of the colors, not just pressed graphite.
Adam
Old 11-12-2012, 04:21 PM   #331
JoeBoxer
JoeBoxer's Avatar
Those 9.5 +40's look good i would go that route if possible.
Old 11-12-2012, 04:23 PM   #332
ebphoto
Drives: FR-S, NA8, S13
was going to say x9.5 +40 would be perfect.
can run decent tire with just a little camber with a roll, probably like -2 to-2.5 for 245 (legit 245 not bigger fitting 245).. and probably -1 to -2 with 235s.
rears cant fit much without camber.. better off going with a x9 +45~+35 and 245 if you are going for a bigger tire... especially if you dont want to stretch... a small 235 could look pretty stretched on 9.5.
theres a car posted in this subforum with 17x9 +35 tc105ns with 255 that sounds like something youd be into :
http://www.ft86club.com/forums/showt...t=17x9+35+weds
ebphoto is offline   Reply With Quote
The Following User Says Thank You to ebphoto For This Useful Post:
Old 11-12-2012, 04:26 PM   #333
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Here is 18x8.5 +35 18x9.5 +40
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
Old 11-12-2012, 05:01 PM   #334
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
but Volk official website only shows 18x9.5 +45, there is no +40 5x100 in the size chart
http://www.rayswheels.co.jp/2009/pro...de=VOLK_TE37SL
adprokid is offline   Reply With Quote
Old 11-12-2012, 05:07 PM   #335
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
good call. 18x9.5 +38 with 255/35-18 all around. no rubbing on inner or outer edges. damn call me surprised lol
wheeldude's build thread
gabeg86 is offline   Reply With Quote
The Following User Says Thank You to gabeg86 For This Useful Post:
Dan@AWD (09-27-2013)
Old 11-12-2012, 05:35 PM   #336
JoeBoxer
JoeBoxer's Avatar
Their website doesn't show a lot of stuff they make.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
